what if I go over charging cell # capacity? >
Old 02-27-2004, 08:09 AM
cyba888's Avatar
Default what if I go over charging cell # capacity?
I have the Novak Digi Peak charger. It says do not charge more than 8 cells. What would happen if I did charge more than 8 cells? I plan to charge 12 cells but at a lower amp.
cyba888 is offline
Old 02-27-2004, 09:43 AM
RCTech Member #2
TSR6's Avatar
It probably wouldn't peak the cells. Once the cells reach the charger's max voltage, it would shutoff, instead of charging to the pack's full voltage.
TSR6 is offline
Old 02-27-2004, 09:47 AM
cyba888's Avatar
As long as the charger wont blow up I dont mind
cyba888 is offline
Old 02-27-2004, 10:58 AM
sosidge's Avatar
Your charger won't blow up.
But the pack won't be charged either.
Kind of makes it pointless to try.
sosidge is offline
Old 02-27-2004, 04:06 PM
PitCrew's Avatar
I would think your charger could over heat because the input voltage is only going to be around 14 volts. 12 cells is 14.4 (1.2 nom) and gp peak at about 1.4-1.5 Therefore in order to compensate, the charger will draw more amps.
PitCrew is offline
