Old 02-25-2004, 09:09 PM   #1
fatdoggy's Avatar
R/C Tech Charter Subscriber
Default Magnet maintenance
I know that a zapper is the best way to keep your magnets in good shape but are there any other ways. I've heard of putting them in the freezer and also tapping the magnets to align the particals inside. Do you guys freeze your motors each week? This is for a johnson 540, stock motor(mvp) and a stock hybrid(orion rush stock motor can) I'll use if I run 19t, so every little bit helps. I only want LEGAL ways to make the mags stronger though.
Thanks.
fatdoggy is offline   Reply With Quote
Old 02-26-2004, 07:30 AM   #2
VenomWorldOrder's Avatar
from what i learnt i science in high school hitting the magnet with another peice of hard metal strengthens the magnetic powers. so yeah HIT IT! the strength will disapear after a while.
VenomWorldOrder is offline   Reply With Quote
Old 02-26-2004, 07:41 AM   #3
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Chilling the motor before a run works well. Electricity flows better at lower temperatures...the colder the better.
Blake
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 02-26-2004, 08:03 AM   #4
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
if you could only keep them that way........... hhmmmm
dontfeelcold is offline   Reply With Quote
Old 02-26-2004, 08:18 AM   #5
Maybe we could fit one of the computer cooling systems to the motor?
Old 02-26-2004, 10:49 AM   #6
PitCrew's Avatar
Get some Liquid Nitrogen, pour it in a styrofoam cooler, dunk the motor in it untill it stops boiling rapidly, pull it out with tongs, and hit it with a hammer.
On second thought, DONT DO IT.
I am sure the magnets will turn into hundreds of peices.
PitCrew is offline   Reply With Quote
Old 02-26-2004, 10:54 AM   #7
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
My motors powered by Bud Light at 2004 Snowbirds
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 02-26-2004, 11:12 AM   #8
PitCrew's Avatar
What I have done racing outdoors when it was really hot was get some dry ice in a cooler, and place the motors on the block of dry ice in a plastic bag. Seemed to work pretty good.
Also, i did the fan trick on my TC3. That worked even better. On 90 degree days when the track was 120-140, my motors hardly hit 150. Before, they were getting so hot as to melt the brushes off the hoods. (mod)
Old 02-26-2004, 01:43 PM   #9
Send a message via AIM to True R/C Racing
What you guys think on the reedy heatsink w/ fan? is it worth $22 Or should i purchase a different heatsink w/ fan?
True R/C Racing is offline   Reply With Quote
Old 02-26-2004, 03:58 PM   #10
PitCrew's Avatar
Make your own for the TC3. Get a small fan (5-12 volt) at radio shack, and mount it so it blows directly onto the endbell. You'll have to use a quantum speedo, or be creative with the mounting of the electronics.
I also dremeled out some of the brace material there to accomodate increased airflow.
Even though I am using a 12 volt fan, it still runs on 7, and the motors never come off over 150 degrees. The brushes and comm seem to last longer too.
Old 03-02-2004, 02:30 AM   #11
Registered User
Hi PitCrew,
How do you use with the Quantum speedo??? With the FET servo lead?? Can you post the pic of the fan in your car attached with the speedo.
Thanks Heaps.....PitCrew
TheNoi is offline   Reply With Quote
Old 03-02-2004, 03:18 AM   #12
anything you do to a magnet that is not in a zapper will weaken the magnet (except cooling). If you hit a magnet while it is being zapped then the zapping will be more affective but don't hit it any other time as it will have the opposite affect.
I have tried different fans to cool motors and find they are only good for cooling the com/brushes when pointing straight at the endbell as close as possible. don't wast time putting them at angles as they do very little (like reedy one). the lower the voltage the better it will work. if you want to keep magnets cool, put heatsink compound on your heatsinks as they do very little without it.
Dragonfire is offline   Reply With Quote
One-Way maintenance stiltskin Electric On-Road 10 02-01-2008 04:23 PM
MAGNET ZAPPER and MAGNET CHECKER F/S tazz888 R/C Items: For Sale/Trade 6 11-20-2004 05:49 AM
Maintenance For Your Gp Car mop_iko Rookie Zone 8 06-10-2004 01:07 AM
maintenance? cHckbOY5 Nitro On-Road 2 06-08-2003 07:22 AM
maintenance nitrosaurus Rookie Zone 7 03-18-2003 08:42 PM
