Old 12-08-2009, 06:46 AM   #76
Exclamation
Originally Posted by bazspencer View Post
Hi everyone! Has anyone of you,guys,who are lucky owners of this speedo tested it on a 10.5 specTC car with foam tires? Does it make really the difference or it's better used with 13.5,17.5,21.5 stock motors? Tnx for your answers,Paolo
My question + what is the availability date in webshops?
Tnx again.
bazspencer is offline   Reply With Quote
Old 12-08-2009, 01:24 PM   #77
TommyBlazin's Avatar
Trader Rating: 29 (100%+)
yea im sold on one as well
Thinking on maybe a Tekno 1/8 Nitro Buggy?
TommyBlazin is offline   Reply With Quote
Old 12-08-2009, 05:49 PM   #78
nashrcracer's Avatar
R/C Tech Charter Subscriber
I think I was the first one that ran a production model in a race in TC and it was 17.5 the only other people to do it gave theres back to the people that they borrowed it from. I gained .3 to .4 a sec so did the others. they are rated for 10.5 2S but I'm not going to test one with that till I get another to back it up. but as I'm going to snowbirds I'll probably put my 13.5 in it and test with it. it didn't get at all warm with the 17.5 maybe 120 so I figure that running 13.5 in it should be fine but I don't know of anybody putting a 10.5 in it to run so far. it made a difference in 10.5 WGT but that is 1S
RC50 As you come into this world, something else is also born. You begin your life, and it begins a journey towards you. It moves slowly, but it never stops. Wherever you go, whatever path you take, it will follow — never faster, never slower, always coming. You will run, it will walk. You will rest, it will not. One day, you will linger in the same place too long — you will sit too still, or sleep too deep. And when, too late, you rise to go, you will notice a second shadow next to yours. Your life will then be over.
nashrcracer is offline   Reply With Quote
Old 12-09-2009, 01:13 PM   #79
Nash the speedo you used at Vegas did it look like the one they had on rctvlive? When Frank was talking?
microcrazy24 is offline   Reply With Quote
Old 12-09-2009, 01:19 PM   #80
I ran it at cleveland not vegas, only prototypes were at vegas and yes they look the same as the pictures I took of it on www.rc50.com when I was at vegas. if I think about it I'll post a pix of my tc with it.
Old 12-21-2009, 09:09 AM   #81
Trader Rating: 38 (100%+)
When are these supposed to be available again?
or8ital is offline   Reply With Quote
Old 12-21-2009, 09:16 AM   #82
1fastdude's Avatar
Trader Rating: 15 (100%+)
Speaking of Cleveland, when will you be updating your site (rc50)?
★RCAmerica •Xray •Hudy •BSR/Jaco •Absolute Hobbyz •Gravity RC •PROTOform •Avid •TQ Racing Wire •C & M Motorsports ★
1fastdude is offline   Reply With Quote
Old 12-24-2009, 03:15 PM   #83
DaveG28's Avatar
Trader Rating: 64 (100%+)
Looking on the website am I right in thinking there is a version which will do down to 3t on 2s as well, eg a mod version one?
Does anyone know the profiles yet, it mentions timing advance but presumably in mod you'd not want to run this, so can it be turned off?
Finally, are there recommended motors to use with them?
DaveG28 is offline   Reply With Quote
Old 01-07-2010, 09:59 AM   #84
gijoe64's Avatar
Trader Rating: 30 (100%+)
Hey guys just got my esc yeaterday. I wanted to know if you have to use a reciever pack with this esc?
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 01-07-2010, 10:24 AM   #85
Regional Moderator
CarbonJoe's Avatar
With a 17.5 in 1/12 scale (1s LiPo), I'm using a HobbyKing booster (basically the same as the TQ one) without issues. Works fine.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 01-07-2010, 11:53 AM   #86
Have you gone head to head with a Tekin 203? Does the BD still have the advantage?
Crashby is offline   Reply With Quote
Old 01-07-2010, 12:57 PM   #87
Regional Moderator
CarbonJoe's Avatar
I haven't yet. I do have both, so I can compare directly. I have run both (BD and RS 203) in my TC and they are very very close. They both make a 17.5 run like a 13.5.
I will say that the BD is much simpler to set up. For stock, just pick profile 5 and change gearing, with the option setting of drag brake. The Tekin gives you a lot of knobs to twist, but the trick is what setting each one needs to be set to, plus gearing.
Old 01-07-2010, 01:22 PM   #88
So you can say that the speedo's are almost the same.
Than racing is back to the best driver and not on who has the fastest speedo as they are about the same speed.
AE is like the LRP. easy to setup but you can update it and the LRP not.
An advantage of the AE above the LRP and I heard that the SXX is still slower than the AE.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline   Reply With Quote
Old 01-07-2010, 01:28 PM   #89
Default are these ESCs like the HOLY GRAIL
Will they ever be available, was hoping to have one for the Snowbirds.But may have to buy another Tekin RS .
Was planning to use my LRP SPX in 17.5 1/12th but from what Ive read im might as well not turn up.
Do you think these will for sake at the Birds.
tellan is offline   Reply With Quote
Old 01-07-2010, 04:19 PM   #90
the best thing to do if you are anxious for a black diamond is to keep a close eye on the teamCRC website. They are pretty good about posting updates and I'm quite sure that they will announce the arrival date as soon as they have confidence in it (just as they did with their first "for sale" batch of BD speedos). You could also try emailing [email protected] (see their "contact us" link for his email address). He's a helpful guy.
vafactor is offline   Reply With Quote
