Old 11-21-2010, 05:53 AM   #106
radio_car_racer's Avatar
anybody tried lowering the 5 pivot balls?
something they do in Europe on the V-Dezign CR4 to improve the handling
radio_car_racer is offline   Reply With Quote
Old 11-28-2010, 01:35 AM   #107
RDOUBLEDAY's Avatar
I just got this car and im looking for some setups.
Im running it all stock except-
Ae blue side springs and Ae .18 Fronts.
Im running 17.5 no boost.
Mugen Mbx6 Eco .
RDOUBLEDAY is offline   Reply With Quote
Old 11-28-2010, 06:41 PM   #108
Here is what I typically run....
Front
Mag Tires 1.60
20 Springs
30,000 lube on kingpins
9 degree blocks
servo mounted flat
4.5mm under steering arm
Middle
black stiff shock spring
35wt oil
1.2 to 1.5 droop
Blue Side springs sometime gold
rear
Pink Tires 1.70
172mm width
make sure axle slide free through bearings.
Steve Dunn
sdunnmcp is offline   Reply With Quote
Old 11-28-2010, 09:11 PM   #109
RDOUBLEDAY's Avatar
Front
Mag Tires 1.60
20 Springs
9 degree blocks
servo mounted flat
Middle
35wt oil
1.2 to 1.5 droop
rear
Pink Tires 1.70
172mm width
Steve Dunn
How Are you mounting you servo flat?
Mugen Mbx6 Eco .
Old 11-29-2010, 08:05 AM   #110
miller tyme's Avatar
Using the On-Point Lipo Chassis is best option. My primary car is set-up this way along with most of the settings Mr. Dunn posted. However it is possible to mount the servo flat with the stock chassis. On by mod car I have the original chassis using Associated B-4 mounts and spacers to move the servo forward, just clearing the lower A-arm, works great.
By the way, the Serpent S-120 along with On-Point upgrades performed flawlessly at the US Indoor Champs this weekend. In the talent filled 1/12 Masters class Serpent was 1 of only 2 manufactures to make the A Main. I have driven a lot of 1/12's in the last 25 years and none have ever been as calm and predictable and as able to turn such fast laps.
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is offline   Reply With Quote
Old 11-29-2010, 03:56 PM   #111
Hi All
I got some time this weekend to update http://markpayneblog.blogspot.com/
with info on the On Point Racing parts for the Serpent S120L.
Hope it's of interest.
Cheers
Mark
Mark Payne is offline   Reply With Quote
Old 11-29-2010, 06:03 PM   #112
chicky03's Avatar
Send a message via AIM to chicky03
Thank you to everyone who ran Serpent and On-Point prododucts at the Champs!
Here is my setup that I ended up with. I wish I would have switched to it earlier, but dosen't that always seem to be the case, Too little too late! LOL.
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 11-30-2010, 12:32 AM   #113
Default servo stands
hi Everyone,
I would like to modify my s120L by laying down the steering sevro instead of stock version. So does any one here can tell me that which servo stands(for lay down position)would fit into the s120L main carbon plate? As far as I know, Xray Xii has one , but is it fit to serpent? Thanks
Alfred
airyu is offline   Reply With Quote
Old 11-30-2010, 12:53 AM   #114
corallyman's Avatar
Trader Rating: 99 (100%+)
Originally Posted by airyu View Post
hi Everyone,
Alfred
Alfred,
I am not sure about the stock chassis but the on point chassis which seems to be the chassis to have is drilled for the laydown servo. Some servo's have extra mounting tabs on them when new and I believe you can use them. I am sure someone can correct me if i'm wrong or give more detail to you.
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 11-30-2010, 08:50 AM   #115
Originally Posted by corallyman View Post
Alfred,
Steve
Correct.
Get a futaba 9650 or bls651 and use the tabs on the bottom of the server and you wont need any swervo mounts.
Steve Dunn
Old 11-30-2010, 09:02 AM   #116
hi Everyone,
Alfred
For the stock chassis the holes are not in the correct position for the laydown servo. If you need some measurements to redrill the chassis email me, [email protected]
On-Point Racing [email protected]
On-Point Racing is offline   Reply With Quote
Old 12-01-2010, 11:05 PM   #117
LonnyJ1950's Avatar
Why swap the caster blocks side to side? And what is the part number for the 10# center spring. How much did you shave off the steering blocks, I can't make it out on the sheet. Thanks in advance.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 12-02-2010, 04:34 AM   #118
Swapping the blocks provides a slightly shorter upper arm length. The steering block has 0.8 MM shaved off bottom. Center spring is 41175
Ken Miller
Old 12-02-2010, 06:29 AM   #119
LonnyJ1950's Avatar
Lonny
Old 01-07-2011, 05:52 PM   #120
avs
avs's Avatar
there seems to be 2 sets of 1/12 springs.
the front springs, 411053,054,055 which are rated by wire diameter 0.45, 0.50, 0.55 and 411218,219,220 which seem to be rated by stiffness, 18, 22, and 26 ? the setup sheets show both designations.
are they equivalent or has anyone compared them? or should i just use associated which seem to be readily available?
The setups show 10lbs but 411214, 215, 216, 217 are rated at 12 14 16 and 18 lbs? the center springs, 411174, 175 are suggested in the notes.
it looks like 411215 is the kit spring. and 174 175 springs are both softer? do i just get the 174 and 175 parts or is anyone using the newer stiffer ratings? it seems like softer is the trend these days on carpet?
Tony Shimko
avs is offline   Reply With Quote
Serpent S120 With ESC, Motor, batteries and Parts Arno R/C Items: For Sale/Trade 11 08-07-2009 09:29 AM
Serpent s120 and s400 present didrace Electric On-Road 18 07-29-2009 08:17 PM
Serpent S120 Futaba 3pk super E-clip Australia For Sale/Trade 8 05-13-2009 01:39 AM
Stormer Serpent S120 conversion. Bob-Stormer Electric On-Road 61 03-14-2009 12:30 AM
Stormer "Cobra" conversion for the Serpent S120 Bob-Stormer Electric On-Road 41 03-05-2009 07:05 PM
