Old 05-22-2013, 07:38 PM   #421
TOADYY's Avatar
Send a message via AIM to TOADYY
Originally Posted by Wes Briscoe View Post
CRC plastic is garbage, and IMO, so is their shock.
The hotbodies 1/12 shock is nice and will fit this car, and it comes long so you can cut it to the length you want. It's a little like the silva shock, which is also nice.
http://www3.towerhobbies.com/cgi-bin...?&I=LXUNN1&P=7
http://www.lefthander-rc.com/catalog...&categories_id=
Thank you I just purchased this shock.
Pro 10 / 10th scale pan GTP: Speed Merchant Road Kill 10 (one of the first 10 produced)
12th Scale: Speed Merchant Rev 8 PRO x2 and Yokomo YRX12
"Pro 10, the only way to fly around the track!"
TOADYY is offline   Reply With Quote
Old 06-05-2013, 08:13 PM   #422
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Chicky, may I use Fiber-lyte's ride height shims in the front of my S120lt from my Associated 12L4 to get me by for now?
CarlosG. is offline   Reply With Quote
Old 06-05-2013, 08:48 PM   #423
LonnyJ1950's Avatar
I think the screw spacing is different, so they probably won't fit. If you can get the serpent ones, they work great.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 06-05-2013, 08:56 PM   #424
CarlosG.'s Avatar
The screw spacing is not the problem with them, my concern is the surface area of the shims for the lower arm to sit on when mounting.
Old 06-06-2013, 05:08 AM   #425
chicky03's Avatar
Send a message via AIM to chicky03
I'm not sure about those, I have never seen them. I just use the stock ones, sorry I could not help.
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 07-13-2013, 11:22 AM   #426
nf_ekt's Avatar
Trader Rating: 113 (100%+)
Default s120L and s100 compatibility
How much of the s120 is also used on the WGT car? I'm getting a S120L and was wondering what the parts compatibility was. I'm assuming that most parts work on both cars. If WGT picks up locally I want to know what else I would need besides the S100 chassis to make a conversion. Thanks.
Up the Irons \m/
Powered by Hotwings, Rolling Rock, and the urge to race toy cars...
nf_ekt is offline   Reply With Quote
Old 07-13-2013, 10:22 PM   #427
TOADYY's Avatar
I think only the chassis parts and the stand offs is the only thing that is not compatible. I would download the PDF file of both manuals and compare the part numbers of both.
Old 07-13-2013, 11:11 PM   #428
nf_ekt's Avatar
Thanks. Will definitely be a good thing if the parts work for both applications, I like pan cars but it's hard to tell if 12th or WGT will be the class locally.
Up the Irons \m/
Old 07-14-2013, 12:28 AM   #429
LonnyJ1950's Avatar
The rear pod is the same and the front suspension parts are the same. The shock and side springs and links also interchange. The main graphite chassis, the upper deck, the front shock mount, front cross brace, tierods are all different. There is also a front subframe that is unique to the S100.
Lonny
Old 08-16-2013, 04:31 PM   #430
CarlosG.'s Avatar
Is there a new or updated rear pod bulkheads? I noticed that with a 64p 72t spur gear, I an only go up to a 58t 64p pinion. And if so, what are the part numbers? A friend of mine told me that their is a new one, just want to make sure.
Old 08-16-2013, 04:55 PM   #431
TOADYY's Avatar
Yes, there is an updated version but they only changed the rear brace from alum. to carbon. I don't think it extends the pod plates.
http://www.serpent.com/news/13674/Se...T-updated.html
Old 08-28-2013, 09:17 PM   #432
CarlosG.'s Avatar
Is anyone using a different rear axle and hubs for their car? I have ran the Associated 12r5 for a while before I got out of the hobby for a short break, and never had an issue with having a tweaked left and right side hubs after a hit like I took two weeks ago. I thought it might be the axle so I put on associated hubs and the axle was fine. I put new wheels on the serpent hubs to see if it was the wheels. Nope, it came down to the serpent hubs got tweaked. Are the hubs made out of the lighter aluminum or the heavier aluminum like the 7071 grade. I don't like to Frankenstein my car with other car company parts. I would like to keep it all one company if possible. Can anybody shed some light on the rear hub issue?
Old 08-28-2013, 09:32 PM   #433
LonnyJ1950's Avatar
Banged lots of stuff, never had an issue with the hubs. If you are not secure with the Serpent hubs, go ahead and change them, it's no big deal.
PS. I did crack a graphite axle once with no damage to the hub.
Lonny
Old 08-28-2013, 10:33 PM   #434
Had bend one before. It is the diff side hub. But it is a really solid hit, (got rear ended by a modified touring on the straight. ) Strange the axial donot break. But anyway, that is the only time I bent one.....
rc-man is offline   Reply With Quote
Old 08-29-2013, 12:58 AM   #435
Julius's Avatar
The original diff side hub was a bit thin. The latest version is a lot tougher. Haven't bent one of those yet....
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Serpent S120 With ESC, Motor, batteries and Parts Arno R/C Items: For Sale/Trade 11 08-07-2009 09:29 AM
Serpent s120 and s400 present didrace Electric On-Road 18 07-29-2009 08:17 PM
Serpent S120 Futaba 3pk super E-clip Australia For Sale/Trade 8 05-13-2009 01:39 AM
Stormer Serpent S120 conversion. Bob-Stormer Electric On-Road 61 03-14-2009 12:30 AM
Stormer "Cobra" conversion for the Serpent S120 Bob-Stormer Electric On-Road 41 03-05-2009 07:05 PM
