Old 03-20-2013, 11:19 AM   #406
Originally Posted by Bishop View Post
Odd, I just found after building my kit, that all the link balls (side bars and rear pod ball), that take a 3x5mm screw, won't do up tight on the carbon plate, they are loose on the chassis etc.
I found you need a .2-.5mm shim to get them tight, otherwise they just spin in place, kind of suspect it's because they went from a 2.5mm to a 2mm chassis?, I'm thinking, or hoping the shims won't effect anything drastically, my rear pod also now sits a tiny bit lower than the chassis because of the shim I fit there, but guessing from previous posts it's not a big deal?
you cant do that. You will need to make the screws shorter.
Steve Dunn
sdunnmcp is offline   Reply With Quote
Old 03-20-2013, 11:59 AM   #407
Bishop's Avatar
Ok then, thanks for the heads up, guess I'll grind all the relevant screws down .3mm or so.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 03-20-2013, 10:04 PM   #408
avs
avs's Avatar
or try a bag of the 12R5 pivot balls. their 3mm hex doesn't bottom the screw, you just lose engagement but there is still plenty. also the AE balls are teflon coated aluminum, lighter smoother but plenty strong.
Tony Shimko
avs is offline   Reply With Quote
Old 03-21-2013, 03:50 AM   #409
Julius's Avatar
And the issue with the center pivot is also solved as the ae balls are slightly lower. They improve the handling as well!
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 03-21-2013, 05:07 AM   #410
Bishop's Avatar
Are these the right ones?
http://www.amainhobbies.com/product_...eam-Pivot-Ball
If so I'll buy some, saves me grinding down screws, I need some bits from AMain anyway, was a tiny bit ham fisted during my build, and still need other parts for it anyway.
Actually the screws I needed to grind, I had to buy some more of anyway, I dropped one while figuring out why they had so much play, as luck would have it, can't find it, and nothing else RC I own uses a 3x5mm screw.
QRCCRA
www.qrccra.org.au
Old 03-21-2013, 07:40 AM   #411
avs
avs's Avatar
yes, those are them.
Tony Shimko
Old 05-14-2013, 09:55 AM   #412
TOADYY's Avatar
Send a message via AIM to TOADYY
I just recently purchased the S120 LXT and want to replace the stock shock with the IRS VCS Micro and was wondering if will fit. Thanks.
Pro 10 / 10th scale pan GTP: Speed Merchant Road Kill 10 (one of the first 10 produced)
12th Scale: Speed Merchant Rev 8 PRO x2 and Yokomo YRX12
"Pro 10, the only way to fly around the track!"
TOADYY is offline   Reply With Quote
Old 05-14-2013, 08:01 PM   #413
LonnyJ1950's Avatar
Not a fan of the stock shock myself, but it is much shorter than most shocks, so fitting something like the IRS shock is possible but difficult. you have to use really short ballcups and be sure the shock doesn't bottom out.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 05-14-2013, 09:54 PM   #414
TOADYY's Avatar
Ok, thanks. Are there any other alternatives?
Old 05-14-2013, 11:26 PM   #415
LonnyJ1950's Avatar
None that I know is a sure fit. Don't be discouraged from trial fitting the IRS, though I think CRC's newer shock is a better design.
Lonny
Old 05-14-2013, 11:28 PM   #416
TOADYY's Avatar
Okay, I'll also look at the crc shock. Thanks
Old 05-15-2013, 05:24 AM   #417
Bishop's Avatar
The CRC shocks looks good (the newer one), comes with different length end bits etc to make it work on most cars, just be aware I don't think Serpent springs will work on anything but Serpent, they are a larger size than most pan car shocks I think.
QRCCRA
www.qrccra.org.au
Old 05-15-2013, 07:03 AM   #418
avs
avs's Avatar
the serpent shock is fine, its the monochrome springs that i don't care for. the silva and cyclone shocks are a little long but you can just cut the shaft to length. the irs shock is short to start with and might fit nicely with little or no ball cup trimming.
Tony Shimko
Old 05-15-2013, 11:28 AM   #419
Trader Rating: 20 (100%+)
I'm selling my S120L with 1s Fantom 5600 battery and Futaba servo for super cheap. Look for it in the for sale section.
TamiyaMatt84 is offline   Reply With Quote
Old 05-22-2013, 07:12 PM   #420
Suspended
CRC plastic is garbage, and IMO, so is their shock.
The hotbodies 1/12 shock is nice and will fit this car, and it comes long so you can cut it to the length you want. It's a little like the silva shock, which is also nice.
http://www3.towerhobbies.com/cgi-bin...?&I=LXUNN1&P=7
http://www.lefthander-rc.com/catalog...&categories_id=
Wes Briscoe is offline   Reply With Quote
Serpent S120 With ESC, Motor, batteries and Parts Arno R/C Items: For Sale/Trade 11 08-07-2009 09:29 AM
Serpent s120 and s400 present didrace Electric On-Road 18 07-29-2009 08:17 PM
Serpent S120 Futaba 3pk super E-clip Australia For Sale/Trade 8 05-13-2009 01:39 AM
Stormer Serpent S120 conversion. Bob-Stormer Electric On-Road 61 03-14-2009 12:30 AM
Stormer "Cobra" conversion for the Serpent S120 Bob-Stormer Electric On-Road 41 03-05-2009 07:05 PM
