Old 01-13-2013, 10:09 PM   #376
SNIPR's Avatar
I use a tire truer & true the inside and outside of front/rear tires. Usually to 47 and run them till they are down to 45 before replacement. But this really will depend on what rollout you need for your track.
Originally Posted by fasteddie d View Post
Had alot of fun building the car . I was wondering if someone could give some insight into trueing and filing down the tires . When filing should we be filing the inside as well and the outside and if so and special suggestions for filing .
thevinylgarage.com - facebook.com/TheVinylGarage - facebook.com/THETrack806
Not Sponsored by:
Viper | Tekin | Trinity | Serpent | Durango | Gravity RC | Pro-Line | Radiopost
SNIPR is offline   Reply With Quote
Old 01-27-2013, 01:48 PM   #377
SNIPR's Avatar
I am in desperate need of this part for my Serpent S120LT SER-411166 (diff spring washers)
I am located in Amarillo, TX (USA) I have checked w/ A Main Hobbies and Stormer Hobbies as well as Serpent USA and can not find them anywhere other then Japan. I am needing these for this weekend (February 2nd)
any and all help is greatly appreciated
Not Sponsored by:
Old 01-27-2013, 02:40 PM   #378
Regional Moderator
CarbonJoe's Avatar
Why not use CRC belleville washers? All of the 1/12 scale axle parts are pretty much interchangeable. I use an IRS axle on mine.
http://ashfordhobby.com/detail.aspx?ID=3166
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 01-27-2013, 03:03 PM   #379
SNIPR's Avatar
I wasn't aware they were. Good to know and thank you for the help!!!
Not Sponsored by:
Old 01-27-2013, 03:05 PM   #380
LonnyJ1950's Avatar
The CRC ones will work, but they're not a best fit. You can get the Serpent ones in the diff rebuild kit but you will pay 10 bucks for them most places. I believe Serpent has discontinued these, so if you find some snap them up.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 01-29-2013, 10:57 AM   #381
SNIPR's Avatar
Serpent finally got back w/ me and informed me "This item 411166 has been replaced by 411024" 411024 are just washers. Not sure how you would adjust the diff w/ those instead of spring washer?
Not Sponsored by:
Old 01-29-2013, 12:42 PM   #382
Julius's Avatar
That can not be right. 411166 is the correct part and as it is used in all serpent pan cars it can not be a discontinued item.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 01-29-2013, 03:54 PM   #383
Check out this part number 411073 .Its the thrust bearing . Much better then the washers . Until I got them I was using the slapmaster thrust bearing .
http://www.facebook.com/VancouverRRR
http://joshuasouthoaks.blogspot.com for blog, pictures and video of race events
fasteddie d is offline   Reply With Quote
Old 02-20-2013, 09:01 PM   #384
Arahawak's Avatar
Trader Rating: 32 (100%+)
Hi, new to S120 and have a couple of questions...
Converting S120L to S120LT is possible right?
And getting the L to LTX is better off just getting the LTX.
I can't seem to find information on the difference from L to LT to LTX
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 02-20-2013, 09:39 PM   #385
chicky03's Avatar
Send a message via AIM to chicky03
L = battery in the rear/side to side position, center damper shock.
LT = Battery front to back, Tubes for dampening, longer wheelbase
LTX - Battery front to back, tubes for dampening, longer wheelbase, rear pivot moved forward and thinner chassis for more traction.
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 03-04-2013, 05:51 PM   #386
Suspended
It is with the conversion kit; the conversion kit however is not 100% complete. You also need the S120LT pivot. The pivot from the LT/LTX is also narrower mounting than the S120L.
I have not looked up the part number but I just ran into this myself doing the conversion from the 120L to the LT. I ended up using a pivot from an Associated 12R5.2.
Wes Briscoe is offline   Reply With Quote
Old 03-10-2013, 04:16 PM   #387
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
I just got my S120LT, I have came into a problem. The problem is that the rear pod bottom plate sits lower than the main chassis by about .5 mm. The instructions dont show any shims to put under the Pivot ball assembly on the main chassis side, is their anything I can do besides shaving the pivot ball down or ading shims to get it to be flat even with the main chasis?
CarlosG. is offline   Reply With Quote
Old 03-10-2013, 04:26 PM   #388
M7H
M7H's Avatar
Just drive it like that, it's not a problem.
Serpent
M7H is offline   Reply With Quote
Old 03-10-2013, 06:09 PM   #389
CarlosG.'s Avatar
Really, it won't affect anything? I am just use to the chassis being evenly flat all the way around.
Old 03-11-2013, 01:50 AM   #390
cmy55s's Avatar
On mine also the pod is sitting down about 1mm lower then the chassis. Still yet to drive the car
cmy55s is offline   Reply With Quote
Serpent S120 With ESC, Motor, batteries and Parts Arno R/C Items: For Sale/Trade 11 08-07-2009 09:29 AM
Serpent s120 and s400 present didrace Electric On-Road 18 07-29-2009 08:17 PM
Serpent S120 Futaba 3pk super E-clip Australia For Sale/Trade 8 05-13-2009 01:39 AM
Stormer Serpent S120 conversion. Bob-Stormer Electric On-Road 61 03-14-2009 12:30 AM
Stormer "Cobra" conversion for the Serpent S120 Bob-Stormer Electric On-Road 41 03-05-2009 07:05 PM
