Old 12-23-2012, 12:34 AM   #361
LonnyJ1950's Avatar
Originally Posted by Eddie M View Post
Hello guys, How do you free up the lower a-arm pivot balls on the S120 front end? They are very tight fit on my car even without installing the 2.5mm screw and lock nut.
If you have a pivot ball tool so you can do it easily, pop the ball in and out several times. That will usually loosen it up. If that doesn't work, use a screw to mount the ball on a Dremal or drill and gently sand it down slightly. Use very fine grit sandpaper and go just a little at a time. Be sure you are using the correct balls. There are 3 types in the kit, 5 large ones for the links and center pivot, several medium ones for the tie rods and shock mounts, and 2 small ones for the lower arm pivot,
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 12-23-2012, 08:05 PM   #362
avs
avs's Avatar
curious, serpent molded parts are usually pretty good, you want no slop but the ball should rotate smoothly.
rather than polishing the pivot ball, you can try opening the arm up a little, by sticking a flat head screwdriver in the slot where the 2.5mm screw passes and giving it a gentle twist.
if you open the slot up too much you can always tighten up the screw.
Tony Shimko
avs is offline   Reply With Quote
Old 12-23-2012, 11:06 PM   #363
Mine were the same but like the guys said you could work the stiffness out . Otherwise I am having a great time with the build .
http://www.facebook.com/VancouverRRR
http://joshuasouthoaks.blogspot.com for blog, pictures and video of race events
fasteddie d is offline   Reply With Quote
Old 12-27-2012, 02:36 PM   #364
Eddie M's Avatar
Got my car done and ready for the first track test this Saturday. Can't wait...so excited!
Eddie M is offline   Reply With Quote
Old 12-27-2012, 08:40 PM   #365
corallyman's Avatar
Trader Rating: 99 (100%+)
What speed controller is that? Can't quite tell on my phone
Steve
Team ORCA / ORCA USA / Pro Spec
Serpent America / Team Serpent S411 ERYX / On Point Racing OP12C, S120 / Xceed Products
Hangar 30 / Seattle RC Racers
Fasttrax Racing Series / NORA On Road Series
corallyman is offline   Reply With Quote
Old 12-27-2012, 09:43 PM   #366
Steve
looks like a speed passion.
duckman996 is offline   Reply With Quote
Old 12-27-2012, 11:29 PM   #367
Eddie M's Avatar
yes, it is a speed passion 1S ESC
Old 12-28-2012, 12:14 AM   #368
Suspended
very nice thanks for sharing
Brett Wilson
Don't Worry Be Happy..
brett546 is offline   Reply With Quote
Old 12-28-2012, 01:16 PM   #369
Julius's Avatar
Did you drill new holes for the steering servo? As it is opposite to the stock holes ont the ltx.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 12-28-2012, 06:40 PM   #370
Eddie M's Avatar
No, I didn't drill new holes for the steering servo. my ltx chassis only allow me to mount the servo in that orientation only. I was wondering why the ltx chassis doesn't offer two choices of servo orientations.
Old 01-07-2013, 01:58 AM   #371
SNIPR's Avatar
Has anyone converted their S120LT over to LTX? Just need chassis and pod plate?
thevinylgarage.com - facebook.com/TheVinylGarage - facebook.com/THETrack806
Not Sponsored by:
Viper | Tekin | Trinity | Serpent | Durango | Gravity RC | Pro-Line | Radiopost
SNIPR is offline   Reply With Quote
Old 01-07-2013, 07:28 AM   #372
TAMAK's Avatar
Trader Rating: 28 (100%+)
Basically ALL the carbon pieces lol... Chassis, Pod Plate, top deck, shock mount, link top and cross brace.
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 01-07-2013, 03:08 PM   #373
SNIPR's Avatar
I thought I read some where that only the chassis and pod plate were 2mm the rest remained the 2.5mm If that is not the case better off just buying OP12C.1
Not Sponsored by:
Old 01-08-2013, 12:45 AM   #374
Robert_K's Avatar
Can't disagree that :-)
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 01-08-2013, 03:27 PM   #375
Had alot of fun building the car . I was wondering if someone could give some insight into trueing and filing down the tires . When filing should we be filing the inside as well and the outside and if so and special suggestions for filing .
Serpent S120 With ESC, Motor, batteries and Parts Arno R/C Items: For Sale/Trade 11 08-07-2009 09:29 AM
Serpent s120 and s400 present didrace Electric On-Road 18 07-29-2009 08:17 PM
Serpent S120 Futaba 3pk super E-clip Australia For Sale/Trade 8 05-13-2009 01:39 AM
Stormer Serpent S120 conversion. Bob-Stormer Electric On-Road 61 03-14-2009 12:30 AM
Stormer "Cobra" conversion for the Serpent S120 Bob-Stormer Electric On-Road 41 03-05-2009 07:05 PM
