Old 09-14-2012, 07:55 AM   #331
LonnyJ1950's Avatar
Anumber of companies make gears down to as small as 72 teeth, including Precision, Xenon, CRC, and Kimbrough.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 09-14-2012, 09:12 AM   #332
Regional Moderator
CarbonJoe's Avatar
Originally Posted by duggyload View Post
can you get a smaller spur than a 88
Sure you can. I'm running a 72 tooth spur on mine (17.5 blinky).
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 09-14-2012, 04:01 PM   #333
Going to give the car a try this coming winter season . Is there any crc parts that fit this car . Anything else that I should know about set up that might be different then the crc car .
http://www.facebook.com/VancouverRRR
http://joshuasouthoaks.blogspot.com for blog, pictures and video of race events
fasteddie d is offline   Reply With Quote
Old 09-14-2012, 07:15 PM   #334
LonnyJ1950's Avatar
No. You should find a source for Serpent parts, Ashford usually has a decent stock, Stormer and A-main also stock them. I've been banging mine around for almost 2 years and only broken a side link, a front axle, and upper and lower front arms. The front damage all occurred at the same time on a very cold day.
Lonny
Old 09-14-2012, 08:38 PM   #335
Toughbeard's Avatar
we have a small stock on S120 parts incase you need them....
Serdar Aytemiz
Racing since the 20th century
Toughbeard is offline   Reply With Quote
Old 09-26-2012, 10:31 AM   #336
mdwalsh's Avatar
Trader Rating: 26 (96%+)
i just bought one of these! im excited! anything i should know? i bought it used so im not 100% sure how its going to be set-up. planning to run it with a 17.5 on asphalt. any tips or rollouts to go by?
Matt
mdwalsh is offline   Reply With Quote
Old 09-26-2012, 11:14 AM   #337
Regional Moderator
CarbonJoe's Avatar
I highly recommend getting CRC 1/12 scale kingpins, a 5-40 tap, and tap the steering blocks so you can use the CRC kingpins. This is mainly because 1) The CRC kingpins are readily available and 2) The Serpent ones tended to snap right where the threads end, causing you to have to replace both the kingpin and steering block. The CRC ones just bend, so you can at least remove them and re-use the steering block. I've been running the CRC kingpins for more than a year and haven't had to replace a single one.
I also run an IRS 1/12 scale rear axle and left side hub, as the Serpent ones are kind of cheesy (at least compared to the IRS one).
Old 10-24-2012, 08:28 AM   #338
nitro rat's Avatar
Trader Rating: 5 (86%+)
Hi guys,
I'm new to 1/12 and was wondering if anyone has a Tekin 17.5 set up for a small track ?
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
nitro rat is offline   Reply With Quote
Old 10-24-2012, 09:24 AM   #339
SNIPR's Avatar
Go to Tekin's website and look up setups in all categories and adjust your settings from there. This is what I had to do for my 10.5/S120L on a small carpet track. You may also contact On-Point Racing for gearing or other setups to help get you on track.
Originally Posted by nitro rat View Post
Hi guys,
thevinylgarage.com - facebook.com/TheVinylGarage - facebook.com/THETrack806
Not Sponsored by:
Viper | Tekin | Trinity | Serpent | Durango | Gravity RC | Pro-Line | Radiopost
SNIPR is offline   Reply With Quote
Old 10-25-2012, 10:50 PM   #340
nitro rat's Avatar
Thumbs up
Thanks for your help I appreciate it
Next question, I've loaded a set up sheet from tekins website and I need to get 4.35" rollout. How do I get this with a 72tooth spur?
Thanks heaps
SMC BATTERIES
ALPHA ENGINES
TEAM DURANGO
Old 10-25-2012, 11:13 PM   #341
silvalis's Avatar
Trader Rating: 29 (100%+)
Thanks heaps
Check out gearchart.com -> click chart creator or something, select pancar, type in your spur, tyre diameter and put in a random pinion (try around 45) and click the rollout button. It'll give you 15 pinions and spurs either side
2013 QLD Champion Potato Sack Racer
silvalis is offline   Reply With Quote
Old 11-28-2012, 07:16 AM   #342
TAMAK's Avatar
Trader Rating: 28 (100%+)
Just picked this up from Stormer: http://www.stormerhobbies.com/cgi-bi...s&pn=SER410004. Kinda new to 1/12th scale and was wondering what are the essentials for the car. Really looking forward to this build, this car looks like a peice of art. lol
TrakPower Speed Equipment / Speed Passion
Serpent Natrix 748 TQ - Nova REX
D413 Reventon 1.1ex 13.5t; AE B6d Laydown Reventon Pro 1.1
DNX408V2-NovaP5, DETC410-Reventon 1.1ex-5.5t MMM
RC10 , RC10GT2- CV-R- SAVOX,
TAMAK is offline   Reply With Quote
Old 11-28-2012, 08:11 AM   #343
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Thumbs up
Welcome to 12th scale!
Here is a build article on the previous vers of that car
Some good info that still applies
http://www.markpayneblog.blogspot.com/
And more general info all things 12th scale related
http://www.rctech.net/forum/californ...ll-so-cal.html
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Old 12-04-2012, 09:08 AM   #344
SMOKE-DOG's Avatar
I'm trying to decide between the S120LT and the CRC xti. I like the fact that the Serpent is metric. But do the hubs on the newer LT use standard bolts or the metric 2.6 I was reading about?
SMOKE-DOG is offline   Reply With Quote
Old 12-04-2012, 09:14 AM   #345
LonnyJ1950's Avatar
The LT uses 3 mm screws throughout except for the rear pod and antenna shock mount. Hubs are 3 mm with the heads turned down to go in the wheels most tires come on.
Lonny
Serpent S120 With ESC, Motor, batteries and Parts Arno R/C Items: For Sale/Trade 11 08-07-2009 09:29 AM
Serpent s120 and s400 present didrace Electric On-Road 18 07-29-2009 08:17 PM
Serpent S120 Futaba 3pk super E-clip Australia For Sale/Trade 8 05-13-2009 01:39 AM
Stormer Serpent S120 conversion. Bob-Stormer Electric On-Road 61 03-14-2009 12:30 AM
Stormer "Cobra" conversion for the Serpent S120 Bob-Stormer Electric On-Road 41 03-05-2009 07:05 PM
