Old 12-20-2011, 07:46 PM   #286
LonnyJ1950's Avatar
What class are you going to run? I suggest you start with the slowest one they run at your track.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 12-20-2011, 07:53 PM   #287
Default Engine / Spur / Pinion ..
Hy guys ... We're starting a S120 class here in Brazil, and we're still making tests on our new track in Sao Paulo ...
I've just finished building my card, and I've never raced electrics before (6 years in nitro tough)...
I have a new X11 9.5T LRP, and we are running Turnigy 2S Saddle packs...
So far we're planning on running 9.5 or 7.5 in the races this year .. still testing .. but . since I have this engine laying around, I wanted to give it a try ...
I have a LRP SXX 2 ESC too ...
Wich Spur / Pinion I should start with here ... we have a track with a mixed chart, so I have a looong straight and some slow curves .....
Can anybody help me ;-)???
Thank you
Rodrigo
RMeira is offline   Reply With Quote
Old 01-02-2012, 01:22 AM   #288
RC MARKET's Avatar
S120 option parts !
RC MARKET is offline   Reply With Quote
Old 01-09-2012, 11:11 PM   #289
What does the numbers/letters mean/stand for for the center shock springs:
7t x4.0 x 1.0mm 5t x 5.6 x 1.0mm etc.?
RoyU is offline   Reply With Quote
Old 01-10-2012, 04:23 AM   #290
Lets just guess:
7 turns in the spring, 4mm apart (7x4=28mm long), wire thickness 1mm
5 turns in the spring, 5.6mm apart (5x5.6=28mm long), wire thickness 1mm
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
Old 01-10-2012, 08:48 AM   #291
Originally Posted by Quante View Post
Lets just guess:
OK, how is the spring rate/stiffness determined by the numbers/letters?
Old 01-10-2012, 11:50 AM   #292
Well, the more winds, the softer the spring (for the same wire diameter). But to know the lbs there's more to it so if its not given thats gonna be difficult.
Old 01-10-2012, 01:51 PM   #293
avs
avs's Avatar
the spring rate for a coil spring, N winds, D coil diameter, d wire diameter, G shear modulus (12+6 lbs/in^2 for steel in lbs, inch, seconds )
k = (d^4 * G) / (8*N*D^3)
the carat ^ indicate exponents so D^3 is D cubed.
Tony Shimko
avs is offline   Reply With Quote
Old 01-12-2012, 11:33 PM   #294
Where can I get the 401025 4.5 mm pivot balls? Nobody seems to carry them in the states.
Old 01-12-2012, 11:40 PM   #295
LonnyJ1950's Avatar
I had to go to RC Market. And though they were labelled correctly, the actual balls were slightly taller than the kit parts.
Lonny
Old 01-13-2012, 04:40 AM   #296
chicky03's Avatar
Send a message via AIM to chicky03
That part number was discontinued. It was replaced by 411253 in a pack of 4 to make it more cost effective.
http://www.amainhobbies.com/advanced...411253&x=0&y=0
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 01-13-2012, 10:38 AM   #297
Thanks Chicky03
Old 01-16-2012, 08:06 AM   #298
Send a message via MSN to Cestaric
Default Tec doubts...
Guys,
Some questions from new user:
What is the stock front spring (18, 22 or 26) ?
What is the stock center spring (10, 12, 14, 16 or 18) ?
What is the stock side spring ?
How I change front ride height ? Changing spacers or changing tire diameter ? The effect would be the same ?
How I change track width ? Different wheels, spacers ???
How I change rear ride height ? Axle insert ??? The right set up, the Pod have to be horizontal ?
What is Pod droop ? It is something like Down travel on the Buggies for example ? How I change Pod droop ?
How many steel balls should be used on the diff ? On the inside holes or on the outside roles ? Any difference in and out ?
Thank you very much for your help.
Cestari
// Cestari
Special thanks to RCW tires and wheels
www.sebrasltda.com
Cestaric is offline   Reply With Quote
Old 01-16-2012, 09:28 AM   #299
LonnyJ1950's Avatar
Originally Posted by Cestaric View Post
Guys,
Cestari
1. Stock front spring is 22.
2. Stock center spring is 14.
3. Stock side spring is 5.5.
4.Serpent makes shims to go between the chassis and the front block to change ride height:https://www.ssl-stormerhobbies.com/c...s&pn=SER411033
5.Rear track width is adjusted with spacers, front can be varied with these:https://www.ssl-stormerhobbies.com/c...s&pn=SER411030, or with spacers for fine adjustment.
6.Rear ride height is adjusted with these:https://www.ssl-stormerhobbies.com/c...s&pn=SER411072
7. Pod usually slopes slightly down back to front, but this is an adjustment you can use to change the handling of the car.
8.Pod droop is the amount the rear of the pod is lower than the front when you lift the car off the ground. You adjust it by lengthening or shortening the shock itself. I use the orange .5mm spacers between the bottom spring perch and the ball cup.
9.Use the outside row of holes, they have a longer lever arm and are under less stress. Fill all these holes with balls. I prefer ceramic ones because they last much longer.
Lonny
Old 01-16-2012, 03:22 PM   #300
Thank you Lonny
thank you very much.
A lot of information to be learned.
Gonna make some changes on my car, based on what you explained and check the new feelings of my car.
once again, thank you.
Cestari
// Cestari
www.sebrasltda.com
Serpent S120 With ESC, Motor, batteries and Parts Arno R/C Items: For Sale/Trade 11 08-07-2009 09:29 AM
Serpent s120 and s400 present didrace Electric On-Road 18 07-29-2009 08:17 PM
Serpent S120 Futaba 3pk super E-clip Australia For Sale/Trade 8 05-13-2009 01:39 AM
Stormer Serpent S120 conversion. Bob-Stormer Electric On-Road 61 03-14-2009 12:30 AM
Stormer "Cobra" conversion for the Serpent S120 Bob-Stormer Electric On-Road 41 03-05-2009 07:05 PM
