Old 11-17-2011, 08:48 AM   #271
cheehtae's Avatar
Trader Rating: 15 (100%+)
Originally Posted by RedBullFiXX View Post
What tires, tires size, what surface, conditions ?
DP front and magenta s rear, carpet med bite, tire size is 42.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 11-17-2011, 09:49 AM   #272
avs
avs's Avatar
Originally Posted by cheehtae View Post
Run the carfor the first time, too loose and twitchy. I follorwd the box set up. Any suggestions in how eto calm it down. Thanks
you didn't mention where the car was twitchy, was it too loose on power and/or off power? also how much steering travel do you have, does it turn in 1meter or closer to 2meters?
i have the s120l OP tubes not the s120lt, but i looked at the 'default' setup on the serpent website and it has some settings that you might want to adjust. (i put my preference in parenthesis)
upper arm insert outside. ( inside for the longer upper arm)
0 toe ( a little toe out like 1 degree total)
track width 198, (a typo, i presume you are in the 171 to 172 range?)
pod droop 1.5mm ( 0.5mm droop with a little sag)
there is not tube damping specified ( 10k to 15k is a good start)
0 caster blocks (is this what you really have? and not the 9degree blocks)
caster shims centered (this may depend on which caster block you have)
no mention of front droop ( near 0)
no mention of side spring preload( near 0)
you might try these changes one at a time: (so you can tell us what mattered)
0) set front droop and side spring preload to 0
1) set steering to 2meter circle and reduce to get around the tightest corner
2) reduce rear droop to 0.5mm
3) longer upper arm
4) more tube damping if car rolling too much in chicanes, less if the rear axle is lifting
5) more caster if it turns in too hard
none of this matters if there is binding in the suspension or some other mechanical problem.
i also noticed, you stated tire size at 42 is that front and rear? you might try a 2mm stagger, leave the front at 42 and add a 44 to 45 rear. does DP mean double purple? you didn't mention if this was a stock motor or mod.
Tony Shimko
avs is offline   Reply With Quote
Old 11-17-2011, 10:12 AM   #273
avs
avs's Avatar
Originally Posted by Rouge711 View Post
Hello guys!
I'm finishing building my S120L with new chassis type and center battery.
I need spur gear and pinion, but i am afraid to get wrong ones looking at the space on the car; can you suggest me some combination?
My motor suggested 31,5mm and tyre diameter is 47mm.
Other question: have you got a good setup for hi traction carpet with mod?
Thank you!
with a D3 motor can i can fit from 112 to 129 teeth (pinion+spur)
so a 20/92 is 112 so it would put the motor near rearmost location, and so you would have room to increase pinion size with tire wear, but a larger tire would require a larger spur. i think 96 tooth is popular for mod.
Tony Shimko
Old 11-17-2011, 11:34 AM   #274
cheehtae's Avatar
3) longer upper arm
DP- dbl pink
It seems like there is no rear grip, as if it's sliding or tail whipping when I turn in to a corner. I know it's my set up because when I switch to my crc car it's totally different.
shock oil I'm using is 500
side tube is 15000 wt.
black spring on center shocks
.50 front spring
side springs are what ever that came with the kit
I will check on my droop when I get back home, but what it says on the default set up sheet is 3.5 droop setting (maybe I'm wrong) so that's prolly what I have it at. Oh running blinky 17.5.
.50 front spring and side springs are what came with the car
I will check on my droop when I get back home.
Running blinky
Old 11-17-2011, 11:36 AM   #275
cheehtae's Avatar
3) longer upper arm
DP- dbl pink
.50 front spring
Old 11-17-2011, 02:37 PM   #276
avs
avs's Avatar
DP- dbl pink
.50 front spring
are you using 2xpink/magenta on both cars?
on turn in, extra droop lets the rear lift more, putting more weight forward. i think the genxl has about 0.5mm drooop built into to it. 1.5mm is a lot and 3.5mm sounds undrivable. i forget now, but i recall having to trim the ball ends to get the droop adjustment in the ballpark.
i have been using 12R5 side springs, silver or blue, and 12R5 .020 front springs.
i had forgotten where it was, but check post 112 of this thread for a good starting point, i have made very few changes, just silver side springs
http://www.rctech.net/forum/8275278-post112.html
Tony Shimko
Old 11-17-2011, 04:16 PM   #277
GCT69's Avatar
GCT69 is offline   Reply With Quote
Old 11-20-2011, 06:51 AM   #278
cheehtae's Avatar
This maybe a dumb question, but how do you set your suspension insert to wide? Do you have to buy the wide insert?
Old 11-20-2011, 06:56 AM   #279
Regional Moderator
CarbonJoe's Avatar
Remove hinge pin holder and flip it so that the hinge pin is closer to the center of the car. Instant "long upper arm." Remember to adjust camber setting via pivot ball to compensate for longer upper arm.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 11-20-2011, 07:33 AM   #280
LonnyJ1950's Avatar
If you want the wide front, you have to have the offset inserts for the lower arms.
Lonny
LonnyJ1950 is online now   Reply With Quote
Old 11-20-2011, 07:59 AM   #281
cheehtae's Avatar
I thought that would make it shorter.
Old 11-20-2011, 10:20 AM   #282
cheehtae's Avatar
I was checking the manual fire the offset inserts, I don't think its listed there. Do you linknow what it is?
Old 11-20-2011, 10:51 AM   #283
LonnyJ1950's Avatar
These:
https://www.ssl-stormerhobbies.com/c...s&pn=SER411030
Notice how the holes are off center, you can make the front wider or narrower.
Lonny
Old 11-20-2011, 06:58 PM   #284
cheehtae's Avatar
These:
Old 12-20-2011, 04:23 AM   #285
Send a message via MSN to Cestaric
Default Engine auggestion
Guys, I'm preaty new on Pan Car, but I've bought a S120 linked car.
Any engine suggestion to buy ?
Cestari
// Cestari
Special thanks to RCW tires and wheels
www.sebrasltda.com
Cestaric is offline   Reply With Quote
Serpent S120 With ESC, Motor, batteries and Parts Arno R/C Items: For Sale/Trade 11 08-07-2009 09:29 AM
Serpent s120 and s400 present didrace Electric On-Road 18 07-29-2009 08:17 PM
Serpent S120 Futaba 3pk super E-clip Australia For Sale/Trade 8 05-13-2009 01:39 AM
Stormer Serpent S120 conversion. Bob-Stormer Electric On-Road 61 03-14-2009 12:30 AM
Stormer "Cobra" conversion for the Serpent S120 Bob-Stormer Electric On-Road 41 03-05-2009 07:05 PM
