Old 10-21-2011, 02:05 PM   #256
chicky03's Avatar
Send a message via AIM to chicky03
Originally Posted by RoyU View Post
I got the center shock kit and it came with a blue spring, what is the rating of this spring, lbs?
Im not sure but its softer than 7lbs. Most of the time a 10-12lb spring works best.
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 10-21-2011, 04:23 PM   #257
RC MARKET's Avatar
Today released S120LT Kit !!
RC MARKET is offline   Reply With Quote
Old 10-21-2011, 08:30 PM   #258
LonnyJ1950's Avatar
Yeah, that's a T-bar spring. Chicky's right (as usual) you need to get a 10 and a 12. Maybe a 14 if you're bold.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 10-21-2011, 11:34 PM   #259
I couldn't find a part # for the 10lb spring. Only from 14lb and up. Anybody knows it? It would be greatly appreciated, thanks.
RoyU is offline   Reply With Quote
Old 10-22-2011, 02:04 AM   #260
RC MARKET's Avatar
http://rcmarket.com.hk/index.php?cPath=51_98_156_221
Old 10-22-2011, 06:31 AM   #261
cheehtae's Avatar
Trader Rating: 15 (100%+)
What degrees of castor block does the new kit comes with?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 10-22-2011, 11:12 AM   #262
avs
avs's Avatar
stormer lists the 12,14,16,18 springs as 411214, 15,16,17
the older series (tbar) springs black stiff (411175) is a 10lb i think?
Tony Shimko
avs is offline   Reply With Quote
Old 11-01-2011, 08:41 PM   #263
cheehtae's Avatar
when assembling the upper arm what do you guys do if it's binding? mine is pretty tight and I tried sanding it a little bit but its still a little tight. any suggestions or what shims do you use?
Old 11-01-2011, 09:06 PM   #264
LonnyJ1950's Avatar
Keep sanding
Lonny
Old 11-02-2011, 07:42 AM   #265
avs
avs's Avatar
are the inserts bottomed in the caster block? let it run in a little before you remove too much material.
also try using 12r5 caster shims (they are easier to adjust)
Tony Shimko
Old 11-09-2011, 04:57 AM   #266
cheehtae's Avatar
Any body here run their car yet? Any good set up?
Old 11-16-2011, 03:14 AM   #267
Rouge711's Avatar
Hello guys!
I'm finishing building my S120L with new chassis type and center battery.
I need spur gear and pinion, but i am afraid to get wrong ones looking at the space on the car; can you suggest me some combination?
My motor suggested 31,5mm and tyre diameter is 47mm.
Other question: have you got a good setup for hi traction carpet with mod?
Thank you!
Rouge711 is offline   Reply With Quote
Old 11-16-2011, 04:35 AM   #268
[QUOTE=Rouge711;9917279]Hello guys!
Thank
92 spur 20 pinion hits the mark.
Serpent 733 EVO
966 EVO
S120LT
TEMsport is offline   Reply With Quote
Old 11-17-2011, 04:57 AM   #269
cheehtae's Avatar
Run the carfor the first time, too loose and twitchy. I follorwd the box set up. Any suggestions in how eto calm it down. Thanks
Old 11-17-2011, 07:27 AM   #270
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
What tires, tires size, what surface, conditions ?
--> 12th scale Information Source <--
"Men do not quit playing because they grow old; they grow old because they quit playing."
― Oliver Wendell Holmes Jr.
Serpent S120 With ESC, Motor, batteries and Parts Arno R/C Items: For Sale/Trade 11 08-07-2009 09:29 AM
Serpent s120 and s400 present didrace Electric On-Road 18 07-29-2009 08:17 PM
Serpent S120 Futaba 3pk super E-clip Australia For Sale/Trade 8 05-13-2009 01:39 AM
Stormer Serpent S120 conversion. Bob-Stormer Electric On-Road 61 03-14-2009 12:30 AM
Stormer "Cobra" conversion for the Serpent S120 Bob-Stormer Electric On-Road 41 03-05-2009 07:05 PM
