Old 05-24-2011, 09:25 AM   #181
What is the biggest 64pitch spur can be use in S120?
What is the gear ratio for 4.5 5.5 and 6.5T? thanks
ioxqq is offline   Reply With Quote
Old 05-24-2011, 12:23 PM   #182
No idea on the largets spur (not sure why you would ask).
For a 4.5 I gear 24/96 with a 1.68 Rear Tire.
Steve Dunn
sdunnmcp is offline   Reply With Quote
Old 05-24-2011, 03:33 PM   #183
avs
avs's Avatar
regarding gear sizing, i find it easier to determine the range of total number of teeth. (spur + pinion).
for a given motor can and pod plates, install the diff with whatever spur you have and find the smallest and largest pinion you can install. now you have the minimum and maximum total # of teeth that you can use.
then, for a target rollout and tire size, there are range of pinion/spur combos that fit within that adjustment.
Tony Shimko
avs is offline   Reply With Quote
Old 05-24-2011, 03:34 PM   #184
avs
avs's Avatar
Steve Dunn
hmm, i suppose the largest spur limit would have more to do with your minimum rear tire size?
Tony Shimko
Old 06-08-2011, 08:30 PM   #185
I heard the rear end is easy to break? There are 3 pieces of alu plates, which on should I keep for spear?
Old 06-08-2011, 09:03 PM   #186
LonnyJ1950's Avatar
I've been racing mine in 13.5 boosted for a year or so with no trouble. If you want to beef it up try these:https://www.ssl-stormerhobbies.com/c...c=ns&pn=OP102B
They are beefier and should last without a problem.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 06-08-2011, 09:22 PM   #187
RDOUBLEDAY's Avatar
how many of you are still using the stock chassis with side shock ? is the dampening tubes that much of a upgrade ?
Mugen Mbx6 Eco .
RDOUBLEDAY is offline   Reply With Quote
Old 06-09-2011, 10:53 AM   #188
I think it's better but can't really say how much. I think the best change I made was to put a R5 front end on mine (takes special parts from On-point). The car didnt over-rotate with the R5 like it did with the Serpent. With the mono-shock I had to keep increaing the oil thickness to get the feel I wanted and eventually I was up to 90wt which started to (hydra-lock) the shock. Another words too thick of oil for the size of shock. I think this is what started the Dampner Tube conversions.
Oh, If anyone is interested I have a anodized Serpent front-end I would sell for $60. The metal inserts are blck and the 10degree blocks are Orange. E-mail me for pictures.
Steve Dunn
[email protected]
Old 07-06-2011, 05:17 AM   #189
Send a message via ICQ to markrichards Send a message via AIM to markrichards Send a message via MSN to markrichards
Default confused
after seeing the news that serpent have released their own damper tubes i am a little confused at the "no other mods" statement about fitting them to the 120L car.
how the chuffin 'eck do they fit ??
markrichards is offline   Reply With Quote
Old 07-06-2011, 06:42 AM   #190
avs
avs's Avatar
looking at the picture it appears the tubes are very short and intended to fit in the same location as the monoshock.
but if the center ball studs stack above and below the one inserted in the plastic thing, i don't see how that center connection is stable. something tricky must be done to limit the center connection pivoting, or they just stack the center ball studs below the shock stay? just guessing.
Tony Shimko
Old 07-06-2011, 02:18 PM   #191
RC MARKET's Avatar
Tube Set !
RC MARKET is offline   Reply With Quote
Old 07-06-2011, 08:01 PM   #192
chicky03's Avatar
Send a message via AIM to chicky03
The newest kits have a different cross brace and top plate that accept the tubes. There will be a conversion available from Serpent or parts separate.
Until that is available On-Point makes a conversion that works really well. Available at Stormer.
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 07-06-2011, 11:58 PM   #193
well that's just cheating.
Does on-point have a Europe importer. I remember them saying they do but cant think who
Old 07-07-2011, 12:57 AM   #194
chicky03's Avatar
Markus Mobers
Old 07-07-2011, 03:29 AM   #195
He guys!
Yes, we are the distributors of On-Point racing. Check www.speedtechrc.de
and drop us an email. The homepage is not up to date, as we are creating a new page, that will be online in a few weeks.
I recently have left Team Serpent as a team driver, but we will continue working together with On-Point, based on AE and Serpent cars.
Take care.
Markus Mobers
Speedtech RC Germany-Home of MobGums tyres
--------12scale addicted---------
Mr. Blonde is offline   Reply With Quote
Serpent S120 With ESC, Motor, batteries and Parts Arno R/C Items: For Sale/Trade 11 08-07-2009 09:29 AM
Serpent s120 and s400 present didrace Electric On-Road 18 07-29-2009 08:17 PM
Serpent S120 Futaba 3pk super E-clip Australia For Sale/Trade 8 05-13-2009 01:39 AM
Stormer Serpent S120 conversion. Bob-Stormer Electric On-Road 61 03-14-2009 12:30 AM
Stormer "Cobra" conversion for the Serpent S120 Bob-Stormer Electric On-Road 41 03-05-2009 07:05 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
