Old 02-24-2011, 04:27 PM   #166
Originally Posted by Pattojnr View Post
i saved that image, but i cant read it, its too blurry.
Send me an email and I will email it to you. [email protected]
On-Point Racing [email protected]
On-Point Racing is offline   Reply With Quote
Old 02-24-2011, 04:48 PM   #167
LonnyJ1950's Avatar
OK! Between the markings on the blocks and the ones on the ride height adjusters, Serpent must be trying to blind us Old Farts.
Lonny
LonnyJ1950 is offline   Reply With Quote
Old 02-25-2011, 07:33 AM   #168
avs
avs's Avatar
the ride height adjuster markings needed some help, i had a silver metallic pen marker, and wiped the area with an inked cloth to highlight the background. its easier to read but still a challenge.
i ended up just writing the number on the back side with the silver pen. (20 25 etc)
Tony Shimko
avs is offline   Reply With Quote
Old 03-14-2011, 07:52 PM   #169
RevMaxx's Avatar
Send a message via MSN to RevMaxx
do you guys have a picture of the car with a Speed Passion V3.0 motor on it? i just want to get an idea of how to run the wires through it.
does the 3 motor wires affect handling of the car? coz it does add a slight return spring action with the center shock.
RevMaxx is offline   Reply With Quote
Old 05-08-2011, 12:16 AM   #170
Send a message via ICQ to SKramer
Default New to me S120L
I just recieved a S120l and am seeking advice on setup, modification, and building of the stock chassis car.
Track we run on is low to mid grip, and I am a novice driver.
Thanks in advance for your tips,
Scott
SKramer is offline   Reply With Quote
Old 05-08-2011, 01:17 AM   #171
LonnyJ1950's Avatar
Hey Scott, Here's what I've been running:
Front springs-.o5o, 22# that come in the kit.
Green #3 shurlube on the kingpins.
Just take the free-play out of the springs, don't preload them.
Front set wide.
Center shock- 40wt oil with 2 hole piston, 16# spring, one higher than stock.
Side spring- 4.5#, the softest ones, just touching the links.
Side shock- 80wt oil with 3 hole piston.
Front shock mount 2ND from top.
4.5mm clearance front, middle, 4.0mm rear of pod
Orange rear tires, Lilac fronts. AMR body with small rear spoiler.
You may have to sand the plastic center ball pivot to remove any excess up and down play, don't get it too tight though, leave a very small amount of play.
Mark Payne talks about this in his blog, which I enjoy:
http://http://www.markpayneblog.blogspot.com/
Tell me how it goes and I hope we see you next Sunday.
Lonny
Old 05-11-2011, 03:26 PM   #172
Lonny, thanks for the info. Car needed a servo and some other things
so it wont be ready this sunday, but soon.
Scott
Old 05-12-2011, 12:25 AM   #173
LonnyJ1950's Avatar
Scott
You can take it for a test drive Sunday.
Lonny
Old 05-12-2011, 08:47 PM   #174
gearhead_22's Avatar
Send a message via AIM to gearhead_22
I am going to run my s120l outdoors at the on roads nats. in jackson NJ. in july, can anyone give me any advise on tires and setup for outdoors, thanks.
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
Old 05-13-2011, 03:02 AM   #175
Aza088's Avatar
Hi Guys i too am about to run My S120 Link for the first time and its my first attempt at electric onroad i will be running on asphalt so is there any tips i should know before i run a race will be practising first so i will have a play with the car but trying to get my head around the setup of these cars.
Also is there a setup guide like there is for the 1/10 nitro on road????
Shepherd | Brilliant RC | Matrix | Maxima | Xceed | KoPropo
www.bluerc.net
www.hobbyexpress.com.au
www.hootrc.com.au
Aza088 is offline   Reply With Quote
Old 05-13-2011, 07:43 AM   #176
LonnyJ1950's Avatar
We don't run asphalt, sorry. If I was going to, I would start with my set up above, but Pink rears, purple fronts, and I would leave them a little bigger, since asphalt usually has less grip. You may need to raise the ride height depending on how smooth your track is. I would also try a softer center spring and a harder front spring with the caster spacers both in front, if I needed more rear traction. Hope this helps.
Lonny
Old 05-13-2011, 07:55 AM   #177
thanks, I am going to run the pro cut crc out of the box.
Juwan Hunter
Old 05-13-2011, 11:45 AM   #178
chris moore's Avatar
Trader Rating: 88 (99%+)
The Mark Payne blog linked by Lonnie and this site.
http://richardchang.com/hobby.php?topic=112setup
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 05-15-2011, 02:11 AM   #179
Aza088's Avatar
I had a run with the S120 Link today and all i can say is what a car so easy to setup and enjoyed every minute with it running on asphalt on a GP track and still had a blast had bucket loads of steering and a tone of rear grip i just with the battery's lasted longer lol can't wait to run the car again .
www.bluerc.net
www.hootrc.com.au
Old 05-15-2011, 09:16 AM   #180
LonnyJ1950's Avatar
Post your set up please.
Lonny
Serpent S120 With ESC, Motor, batteries and Parts Arno R/C Items: For Sale/Trade 11 08-07-2009 09:29 AM
Serpent s120 and s400 present didrace Electric On-Road 18 07-29-2009 08:17 PM
Serpent S120 Futaba 3pk super E-clip Australia For Sale/Trade 8 05-13-2009 01:39 AM
Stormer Serpent S120 conversion. Bob-Stormer Electric On-Road 61 03-14-2009 12:30 AM
Stormer "Cobra" conversion for the Serpent S120 Bob-Stormer Electric On-Road 41 03-05-2009 07:05 PM
