Old 11-12-2009, 08:30 PM   #1
mytto1's Avatar
Questions?? brushless w/NiMH batteries?
Can you still run a brushless motor with the batteries that you use with brushed motor w/ the long run times that a brushless would normally run?
(im running a havok 1/10 spec brushless system 17.5t). Will i lose some power w/o lipo if its possible?
mytto1 is offline   Reply With Quote
Old 11-12-2009, 08:37 PM   #2
SpraydbySprague's Avatar
Location: Conducting aggressive board meetings at my local track
Trader Rating: 64 (100%+)
Been running brushless with NiMh in 1/12 scale 4 cell NiMh for two years now. Works great!
How would I describe my holeshots?
Three words...
Ready... Steady... Confetti!!!! (gonna need a new one of those)
SpraydbySprague is offline   Reply With Quote
Old 11-12-2009, 09:02 PM   #3
mytto1's Avatar
so your not running on lipo?
Old 11-12-2009, 09:08 PM   #4
Not in 1/12 scale. In 1/10 off road I ran NiMh with brushless in 2008. In 2009 I made the switch to LiPo in 1/10 off road.
Three words...
Old 11-12-2009, 09:08 PM   #5
tom_chang79's Avatar
Me too. But 6-cell. I've been running nothing but NiMH since I'm waiting for my packs to die off before I plunge into LiPo.
So far, my NiMH has been super strong and hassle-free...
I run four packs of 3 cell + 3 cell NiMH saddle configuration for my B44, four packs of side-by-side 6-cell NiMH for the rest of my vehicles. Brushless systems I have are:
Mamba Max + 5700Kv
2nd Mamba Max + 4600Kv
Ezrun 60A V2 + 4300Kv
When I initially dove into the brushless system, I did have a fall out of a pack. It made my systems cog, so I found out that pack was really weak.
It's the odd-ball "Sanyo" Team Orion matched pack. I think it had a bad cell in there that couldn't handle the sourcing.
Rest of the packs, they're no prize winners either, they are 4 to 5 year old 3300 to 3600 mAH NiMH, most are GP-based cells (I think GP cells are the best NiMH out there, reliable and trustworthy). But they run strong though...
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 11-12-2009, 09:19 PM   #6
Wait til ya throw a Thunder Power 40c 5400 saddle in the B44. WOW! Best part is you can race 3 qualifiers and the main with just ONE pack. Just top it off after the 2nd round and it's all good.
Three words...
Old 11-12-2009, 09:24 PM   #7
mytto1's Avatar
So the NiMh still gave you a good brushless run time?
Old 11-14-2009, 09:40 AM   #8
Geezatec's Avatar
NiNh will do you fine, but for time It'll give you minutes depending you driving style. Lipos will give up to 20minutes depending on driving style. Lipo has better Accelleration and punch when you need it. May have to purchase a lipo charger, It does take a little more time to charge, but lipo you can charge them anytime. Just maintain them correctly. Learn more about lipo on the web. You'll find which one is best for you. NiMh's the past, lipo's the future.
Geezatec is offline   Reply With Quote
Old 11-14-2009, 09:58 AM   #9
Cheap NiMH packs will have more punch in stock then cheap Lipo packs as a rule.
We've been using brushless with NiMH for about 7 years now.
The advantage of Lipo over NiMH is weight and steady voltage. They weigh about a 1/3 less than an equivalent NiMH pack and the voltage is as strong at the end of six minutes as the start.
With 1/12 scale the trend is 1S 3.7V Lipo packs where you will need either a booster or a Rx pack to power the Rx and servo. With today's Lipo making 8 minutes is no problem and the voltage is steady.
AreCee is offline   Reply With Quote
