Old 11-12-2009, 09:22 AM   #1
Trader Rating: 40 (100%+)
Default Anyone use lrp sxx tc for spec??
Tried asking over at the lrp thread but not much going on there... Yes,I know the sox would be better suited to run a 17.5 but that's not an option. So, has anyone ran a 17.5 or such spec motor class with the sxx tc? I know it's mainly for mod, but again I really don't have much of a choice. I'm just trying to ind out if it can be done with no damage to the motor. If it can, then what profile?thanks!
AndysD8 is offline   Reply With Quote
Old 11-12-2009, 11:19 AM   #2
chicky03's Avatar
Send a message via AIM to chicky03
It will work perfectly fine. You'll want to use profile 10 for the power profile. Compared to others speedos with rampup timing speedos(spx, tekin etc) you'll have to gear higher because of the lack of extra timing. I have tried both ways in 13.5 and there is really no difference in laptimes as long as you get the gearing correct with both on a duo.
With the new X12 spec motors you'll be perfectly fine with the SXX as the motors are so fast the ramp up timing speedos are not needed. In 13.5 and 10.5 we have found that profile 10 on the SXX and profile 6 on the SPX are as high as you will want to go, any higher and you need to fully retard the timing on the motor and gear down at least 10 teeth. Even then it is still too timing on the speedo.
Hope this helps!
Paul
Serpent America, Picco, Desoto Racing, Motiv, J Concepts, Nitro Pro fuel, PT RC Racing Oils, TQ Wire(best wire ever!), BSR tires, Arrowmax, Xceed, Sanwa, Amain Hobbies, MIP, Getcustomized, EZ Customs
chicky03 is offline   Reply With Quote
Old 11-12-2009, 11:44 AM   #3
Hope this helps!
Paul
thanks! That's what I was wanting to hear! Ad I'll actually be using a duo, well a duo 2, but from the sounds of it I should be fine.
RC10B4/T4 Forum DerekL Electric Off-Road 14339 12-13-2017 11:20 PM
lrp spx stock spec chuckharrisjr Electric On-Road 1131 02-22-2017 11:58 PM
LRP Vector x12 Brushless Motors mok Electric On-Road 697 08-04-2013 01:35 PM
LRP SXX TC SPEC Stein Tumert Electric On-Road 190 08-20-2012 05:52 AM
Been out of the hobby for a little bit need a little refeshing C_Money Radio and Electronics 14 05-18-2009 11:13 PM
