1s Lipo Chassis Kit for the GenX10 >
Old 12-14-2009, 07:06 AM
  #16
Would somebody be kind enough to post or email me a starting setup. Some pictures for electronics placement would be helpful too. [email protected]
I am running on newer CRC carpet, 75 X 36 fairly technical track
Jaco spec tires, Tekin RS Pro, Novak Ballistic 13.5, Novak booster, AMB up front and Sophia body if it matters.
All help would be appreciated, Thanks
Cam Mayor
Cammer is offline
Old 12-14-2009, 12:39 PM
  #17
joeymdz's Avatar
with the McKune chasis you can mount pretty much all the electronics in the rear. on set up: are you asking "how to set up your car" with this new chasis? answer: set up would be the same but lighter so you may need to add weights
joeymdz is offline
Old 12-15-2009, 03:51 PM
  #18
Troy Mckune's Avatar
Trader Rating: 46 (100%+)
Default Mckune Design welcomes Mark Smyka
Team Tekin/ Team CRC driver Mark Smyka will now be running a Mckune Design 1s Lipo Chassis. He joins Dave Ehrlich and Andy Wells as another top driver to be running our conversion.
Cam,
I sent you an email yesterday with my setup. A great place to start for high bite tracks is Bryan Wynns IIC setup:
http://www.teamcrc.com/crc/downloads...ICsetupWGT.pdf
As far as mounting electronics, check out the pictures of Andy Wells' and Dave Ehrlich's cars in my first post. I will have some new pictures up soon.
Troy
Troy Mckune is offline
Old 12-17-2009, 08:30 PM
  #19
smyka's Avatar
thanks troy got the packsge today will build it tommorw and run her on sunday looking forward to running the car now i will post some pictures of how i lay the car out and a setup as soon as i get it built and run on the track for a weekend or two
smyka is offline
Old 01-04-2010, 09:32 AM
  #20
smyka's Avatar
ok here is my set up from testing yesterday i will do a few more things tuesday and let you know if they worked
front
1/12 front .45 springs with murdock red tube on king pins
4 degrees of caster
1.0 camber
full long and wide
7/8 of tire sauced
trailing axles
center
losi shock associated green spring 35 wt oil
second hole up on tower and rear shock raised .110
rear
assocaited gold springs
30k in tubes
1.5 turrns of pre load
med link (no longer short link)
other things i have front are spaced up 2mm with 1/12 front brace cut,chassie stiff. plate across nose.
i am gonna try 1.5 camber blue center spring and red side springs tuesday then play with moving shock up one more hole
smyka is offline
Old 01-04-2010, 09:49 AM
  #21
Drillit's Avatar
Location: Oreganastan Pacific Wonderland home to Indoor Farming
OMG who wired Dave's car at the last moment so that DB Cooper could drive it at TZII?
It sure balanced well on the scales..........just ask Andy
Drillit is offline
Old 01-22-2010, 05:11 PM
  #22
gijoe64's Avatar
Trader Rating: 30 (100%+)
Here's my Gen X 10 with the McKune chassis. I love it!! What else are you working on? And when are you to make some decals!!
Attached Thumbnails 1s Lipo Chassis Kit for the GenX10-gen-x-10-002.jpg   1s Lipo Chassis Kit for the GenX10-gen-x-10-001.jpg   1s Lipo Chassis Kit for the GenX10-gen-x-10-003.jpg
gijoe64 is offline
Old 01-23-2010, 03:45 PM
  #23
Exclamation
Looks great, Gotta get me one, Stormer here we come, Should work good when we switch to 235mm wide cars for asphalt racing in the summer !!!!
THEBIGBULL is offline
Old 01-28-2010, 01:35 AM
  #24
Default Snowbirds Pics
GIJoe,
I am working on decals, hopefully I will have some within a few weeks. I also made up some custom pod rear plates with engraved and paint filled names on them. I made batches of Timezone and RC plus as well as I made up a bunch for top driver's of CRC cars at the Snowbirds. There is picture below showing the pod plate. If there is interest I will set up the website to accept custom orders.
Here is picture of Dave Ehrlich's car at the Snowbirds.
Pod plate with engraved and paint filled name.
Pictures are from www.rc50.com
Old 01-28-2010, 09:54 AM
  #25
PDX-Spike's Avatar
Hey Troy,
I'd like...(let's see, I have two of your chassis' and a CRC Gen XL)...three TZ cross braces.
PDX-Spike is offline
Old 01-28-2010, 10:21 AM
  #26
gijoe64's Avatar
Troy,
I would like to order 2 of the Back braces with my name on them, one for my Gen X10 and my Gen XL. Also what a bout a new front chassis stiffener? And decals two!!!
gijoe64 is offline
Old 01-28-2010, 11:13 AM
  #27
tallyrc's Avatar
I posted in the other thread but.... I'd like to see a chassis without the width adjustment plates. Just bolt the front end directly to the chasis.. looks nice anyhow and ill probably get one
tallyrc is offline
Old 01-30-2010, 09:44 AM
  #28
Default Snowbirds 2010 Mckune Design in the A
Congratulations to Dave Ehrlich and Brian Bodine for making the A-main in WGT at snowbirds! Both Northwest guys are running a CRC Gen X 10 with a Mckune Design Chassis.
Old 01-30-2010, 10:43 AM
  #29
PDX-Spike's Avatar
Great news Troy. Better ramp up production!
Old 08-12-2010, 12:24 AM
  #30
Default ROAR 2010 Paved Nationals
Congratulations to Dave Ehrlich for his National Championship!
Dave TQ'd the World GT class using a CRC Gen X 10 with a Mckune Design 1s Lipo chassis, our new O-ring Battery mounts, Carbon Front Brace, front suspension upper arm spacers, and of course a Dave Ehrlich personalized pod plate.
Dave TQ'd and won the 17.5 1/12th scale National Title with using our new Carbon Suspension Brace. 1/12th scale carbon braces are available in both short and long arm versions.
Our new products will be available for sale before IIC.
Attached Thumbnails 1s Lipo Chassis Kit for the GenX10-kff_9709-w.jpg   1s Lipo Chassis Kit for the GenX10-roartekin-1.jpg   1s Lipo Chassis Kit for the GenX10-100_0270.jpg   1s Lipo Chassis Kit for the GenX10-100_0285.jpg
