Old 11-10-2009, 09:43 AM   #1
Barry White's Avatar
Exclamation Glass Fibre Sheet Supplier
I am looking for glassfibre sheet material of 1,2 mm trough 1,8 mm in 0,1 mm or 0,2 mm incresements.
Barry White is offline   Reply With Quote
Old 11-15-2009, 05:50 PM   #2
pleez
Old 11-16-2009, 01:17 AM   #3
Troy Mckune's Avatar
Trader Rating: 38 (100%+)
Default Fr4 G10
Hello Mr. White,
I assume you are looking for T Plate material FR4/G10. I also am assuming you are not in the US by the use of commas. In the US .047" (1.20mm) and .0625" (1.60mm) G10 is available through many distributors such as Professional Plastics or Port Plastics. Most of the material is made by Norplex or Atlas Fiber. There may be a few others but that is where my distributor mostly buys from. As far as custom sizes the orders you will need are rather large. I believe to get a small run of custom thickness you would be looking at 5-10 4' x 6' sheets (roughly 125 to 250 square feet at $4 - $5 a sq. ft.). Another thing to consider is that the standard tolerance on this material is +/- .0035". When you are asking for different sizes by .1mm (.004") you may not end up with exactly what you want. If you request 1.40mm you could get 1.30mm to 1.50mm and this would be within their tolerance.
Hope I could help a little.
Good luck,
Troy
Mckune Design / facebook page / RC America / XRAY / Lunsford Racing
Mckune Design is a custom manufacturer of CNC machined carbon fiber, G10, & composite laminate parts for RC, Aerospace, medical, and high tech industries.
Troy Mckune is offline   Reply With Quote
Old 11-16-2009, 10:58 AM   #4
Originally Posted by Troy Mckune View Post
Hello Mr. White,
Good luck,
Troy
Thanks and U're right. I'm from Belgium. That's allready a big help. I e-mailed and rang all Belgian company's that had anything to do do with glassfibre and/or composite but no luck. I'll have to try elsewhere.
Old 11-16-2009, 11:20 AM   #5
Hi m8, I'm from Belgium as well and I use 2mm glassfiber with a slot between the hinge points on my T-Bars. Works great and Serpent does the same thing so its gotta work.
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
making lower chassis davioh Electric On-Road 55 07-17-2003 03:37 PM
