Brush Problems??? >
Brush Problems???
Brush Problems???
Old 02-26-2004, 09:06 PM
  #16
kuanseng1981's Avatar
Trader Rating: 15 (100%+)
Default Brush
I think how u are run in the is motor ok. but to me is too long
from my personnal exp which no think of is u are OVERGEARING or UNDERGEARING your motor cause u say that the comm looked bad after running 1 pack.
For the timing use back the stock timing when the motor come in and for the brushes spring use a bit harder that stock will be good enough.
kuanseng1981 is offline
Old 03-01-2004, 08:40 AM
  #17
AdR|aN's Avatar
Originally posted by AdR|aN
Thanks again crew.
Would try to make the necessity changes this weekend and run my mod again. Would post up any improvements on the motor if i have any.
Thanks for the help everybody. I feel the need .... the need for speed ....
GUys. Need help again.
What is a recommmended ratio for a 10tx2 Reedy Pt???
I am currently running it around 8.88.
AdR|aN is offline
Old 03-01-2004, 12:47 PM
  #18
PitCrew's Avatar
What car?
What gear ratios?
PitCrew is offline
Old 03-01-2004, 10:07 PM
  #19
AdR|aN's Avatar
Originally posted by PitCrew
What car?
What gear ratios?
XRAY T1 EVO2.
Internal drive ratio is 2.125.
AdR|aN is offline
Old 03-01-2004, 10:55 PM
  #20
Simon K's Avatar
I run all my motors in with a 4 cell pack(4-5 mins), doing it with 0 deg advance certainly makes life a bit easier for them too.
Simon K is offline
