Old 11-09-2009, 12:00 AM   #1
suparajicon's Avatar
Default Which pinion should I use with..Please help.
Car ratio: 2,25 Tamiya TA5MS
Motor: Tamiya GT Tuned (I think is a 25T)
Track: Small
Spur gear: 105 64 DP
I don,t know how to calculate the ideal pinion in this case as I only know for bruslles motors..can anyone help me please?
Living in a banana republic
suparajicon is offline   Reply With Quote
Old 11-11-2009, 11:12 PM   #2
anyone?
Old 11-12-2009, 12:09 AM   #3
gtfour93's Avatar
Trader Rating: 22 (100%+)
Divide number of spur with pinion, then multiply by 2.5, or refer to your TA05MS manual for a gearing chart.
www.activrc.com
gtfour93 is offline   Reply With Quote
Old 11-12-2009, 02:09 AM   #4
Yeah , I know how to do that.. But what I am asking, is for the ideal ratio using a 25T, as I only know for brushless motors.
Old 11-12-2009, 02:21 AM   #5
niznai's Avatar
That's interesting. And what method pray tell is that?
I am afraid you have some misaprehensions about what is ideal. Ideal ratio doesn't exist outside some well defined constraints. Which means the ideal FDR for a set of conditions (grip, track, esc setup, etc) is not going to be ideal at all for another set. As you mention none of these conditions, it is nigh-on impossible for anyone to help (which is why you didn't have any answers).
Besides, there is no calculation to help you here. Run the car, take temperature readings on the motor and see if you are on pace. That's how it's done.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 11-12-2009, 03:06 AM   #6
When I buy brushless motors,for example I was running a 10,5T, until my ESC got broken. Nosram says the final should be 6 (of course this depends on track, batteries,tires..).
Spur gear/pinion gear x internal car ratio= final ratio
Lets say I was gonna use the Brussless Nosram 10,5T:
105/40 x 2,25 = 5,90
5,90 is close to the 6 they recomend, of course that changes if I use Lipo,Life.. 5 cells, 6 cells...smaller or bigger wheels..etc
For a 25 turns brushed, there should be final ratio where start from,and this is what I don,t know.
Also I have no idea what the ideal temperature should be for brushed motors, so it makes it difficult to calculate for me.
Old 11-12-2009, 05:32 AM   #7
niznai's Avatar
I am not sure what you mean by saying Nosram says this or that. FDR depends on what you do with the motor more than what the manufacturer says. If they are serious about the FDR they suggest, then they should suggest some application the suggested FDR is good for. Otherways it's a joke.
Optimal temperature for brushed is reached when you are just about to burn it. This is learnt by experience. My suggestion is as above. Gear low, take temps, compare your speed/acceleration with the fast guys and gear up until you catch up provided the motor does not get too hot. Too hot is when you can't touch the motor without getting burned instantly. It will start to smell funny before it burns, so that's a giveaway you should stop gearing up or perhaps gear down a notch.
Team Greasy Weasel
Old 11-13-2009, 01:54 AM   #8
Thanks pal! How you say seems to be a good way!
Xray T1 David Galdo Electric On-Road 12705 07-04-2016 02:07 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 08:38 PM
Which Brushless setup can reach up to 100mph on a Elec tc3? RCbasher01 Electric On-Road 21 05-30-2010 02:08 AM
HELP : Info on Removing pinion gear from Clutch bell. akiraceo Malaysian R/C Racers 7 04-22-2009 10:42 PM
Can't choose between 3 Cars HELP. acutts Nitro On-Road 35 05-26-2006 05:40 PM
