Old 11-04-2009, 11:00 AM   #1
3rd-dan's Avatar
Lightbulb Associated RC10L3T need some help
Hi guys,
im thinking about to get the RC10L3T Chassis from my friend.
It is the one with the damper plate in the middle.
Now i have some questions.
Where will i find a shop who have spare and options parts in stock?
Which front end parts would fit the l3t?
Perhaps the front end of the RC12l4 oder RC10R5 or what else?
Is this car easy to drive and what will break easily?
Is the car still competitive?
Or would be the Corally CCT a better option?
I will drive with a 13.5 motor and a 7,4 lipo in a rc series that called Pro10S here in germany.
Thanks for replys.
Cheers Mike
3rd-dan is offline   Reply With Quote
Old 11-04-2009, 11:27 AM   #2
Joost K.'s Avatar
- Spare and options for the L3T are pretty hard to find. Maybe Ebay? A lot of RC12L4 parts will fit this car.
- Front end parts are the same as the: RC10L2, RC10LS, RC10L4O, RC12L4, CRC cars, HotBodies front end. The R5 front end will not fit because it has M3 bolts and the holes are no match.
- The car is good to drive, depends on the setup and your own skills.
- YES! It will be competitive. Last weekend I raced against one and got beaten by it.
- No, the CCT is not a better option. In the RC10L3T you can fit brushless and lipo easier and better than in the CCT.
JKMR P235-SE Stealth Edition Pro10 | Futaba | Orion | Trinity | Orion | BSR tires
*** JK Model Racing ***
*** MIX-RC.DE TEAM ***
Joost K. is offline   Reply With Quote
Old 11-04-2009, 11:45 AM   #3
3rd-dan's Avatar
Thanks Joost for your reply.
Its nice to hear that some parts of the newer 12L4 and HB Parts will fit.
Cheers Mike
Old 11-04-2009, 01:27 PM   #4
Joost K.'s Avatar
If you like you can send me your email adress. Then I can send you some manuals of some Associated cars so that you can check for yourself which parts fit and which won't
Old 11-04-2009, 02:05 PM   #5
3rd-dan's Avatar
That would be nice.
PM send
Cheers Mike
Old 11-04-2009, 11:08 PM   #6
Joost K.'s Avatar
You've got mail
Greets
Old 11-05-2009, 03:37 AM   #7
gramm's Avatar
You mention it has the damper plate, so it will be the sport edition, not the team edition. You'll need to get some bearings, that being the case.
I can say, the L3 works great with lipo and brushless (saddle pack 2s and 17.5)
Daniel
gramm is offline   Reply With Quote
Old 11-05-2009, 04:18 AM   #8
tallyrc's Avatar
the only things you cant get for that car are chassis parts and the front bumper.. everything else comes from the long line of rc10l cars.. the car runs great, but i'd get something modern cause the chassis issue.. unless you get a great deal...
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 11-05-2009, 05:26 AM   #9
2wdrive's Avatar
the sport version also has a frp chassis, not a carbon chassis.
I think i also had contact with your friend about that same car. Does it also come with a rc10l3 oval chassis etc?
I still have a rc10l2 (same as rc10l3 except 235mm) and spares is not a problem. Axles and hubs are IRS, and you can still buy the old crc aluminium bulkheads wich are the same as assosicated. T-bars are not a problem either.
All the parts are interchangeble from other brands 1/12 and 1/10 as long as they use the old version associated style front suspension.
For front suspension you can use crc's, hotbodies, bmi, corally etc etc. They are all the same copy from asso except for some small tweeks here and there. On ebay you can still find bottom and upper plates sometimes.
2wdrive is offline   Reply With Quote
Old 11-05-2009, 09:36 AM   #10
3rd-dan's Avatar
Hi,
thanks for all replys.
It has a carbon chassis and its not the sport version my buddy said.
He has the original side dampers and the upper plate for fix the dampers.
It has bearings .
@ 2wdrive
you are correct.
Did you talk to em or know em?
Where you interessted in this car too?
For me i will take this car.
And if the spares interchangeable with other brands, is that perfect.
Ill get new in this class and donīt want to buy a expensive new car.
If i like this, sooner or later i will buy a new car like the Xray X10 or something else.
Cheers Mike
Old 08-29-2016, 05:54 PM   #11
Default rc10l3t
i got one of these from a family member and would like to know some stuff about them.
fitchjay is offline   Reply With Quote
Old 08-29-2016, 09:12 PM   #12
Johnn27's Avatar
Trader Rating: 72 (100%+)
Thumbs up parts
Originally Posted by 3rd-dan View Post
Hi guys,
Thanks for replys.
As for the front end you wan the dynamic strut front end, corral also mage an associated based conversion you may be able to find cheap or yes if you find an old 12l4 that car has the dynamic strut front end as well
Johnn27 is offline   Reply With Quote
Old 08-30-2016, 06:33 PM   #13
can you tell me anything about this car?
Old 08-30-2016, 09:45 PM   #14
Johnn27's Avatar
Thumbs up rc10l3tc
I believe this car is 190mm version of the rc10L pan car
Old 09-01-2016, 10:11 AM   #15
thank you and what would be a good set up for this to be used as a speed run car?
