Old 11-04-2009, 05:25 AM   #1
ddesros2's Avatar
Default Chassis Prep...Royal F-up on my new Gen-XL
I finally got my new Gen-XL kit in the mail. Opened it with loving care and began sanding it down and making it perfect. When I got to the step to add the CA (letting the bead run down the side)...some of it ran on the chassis face and back. I wiped with a wet cloth ASAP, but it dried so fast it did not come off. Now I have CA streak on top and bottom...
What is the best thing to do to make it look at least half decent. It won't affect perforamce, but man...it's my first new 12th scale in years and I wanted it to be perfect.
ddesros2 is offline   Reply With Quote
Old 11-04-2009, 05:35 AM   #2
billjacobs's Avatar
Trader Rating: 55 (100%+)
Default ca cleanup
Get some ca remover and remove it from the top of the chassis. Should work perfectly.
billjacobs is offline   Reply With Quote
Old 11-04-2009, 05:48 AM   #3
Skitee's Avatar
If you can't find ca remover then acetone will work too.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 11-04-2009, 06:54 AM   #4
sosidge's Avatar
One of the reasons why I never prep... if you mess up it looks terrible... you can't beat a nice precision-cut edge on the parts in my opinion!
Old 11-04-2009, 07:03 AM   #5
i agree. glueing the edge on the chassis is very overated. I have never done it and have had zero problems. yes ca remover will take care of it.
march to my own is offline   Reply With Quote
Old 11-04-2009, 07:04 AM   #6
cheehtae's Avatar
Trader Rating: 15 (100%+)
I usually use black nail polish, just double or triple coat em and make sure to let it dry before applying the next coat, and if you messed up it's an easier clean up. just make sure not to use it o your fingernails, not unless you really want to.
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 11-04-2009, 08:05 AM   #7
Send a message via Skype™ to slotracer577
I used CA on the end of Q-tip for my last chassis. Sealed the edges with a lot less mess. also quicker to do.
Team Epic
slotracer577 is offline   Reply With Quote
Old 11-04-2009, 08:32 AM   #8
snoopyrc's Avatar
I think thats a decent idea.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 11-04-2009, 08:59 AM   #9
Suspended
Trader Rating: 2 (75%+)
found CA in the hardware section at Walmart with a screw-cap and included little brush (like nail polish). WORKS GREAT!
justanotherdude is offline   Reply With Quote
Old 11-04-2009, 09:02 AM   #10
Suspended
second chassis I ever bought I decided to forgo the advised prep. maiden run in practice I hit a small stone, chassis started to split, was rendered useless in a month. never gone without prepping again, hit plenty of stones and never had a chassis de-laminate again.
Old 11-04-2009, 09:06 AM   #11
Randy Caster's Avatar
Trader Rating: 46 (100%+)
That's the best way to do it. Just soak the Q-Tip and dab it on a towel to remove the excess glue and run it along the sides of the CF pieces.
Old 11-04-2009, 09:12 AM   #12
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
I never glue my edges. When I put my XL togather I sanded every graphite part top and bottom. I use a piece of 240 grit sandpaper and a granite surface plate (tweek board will work too). Mine has a very dull finish, but it is FLAT!
-Wayne
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is online now   Reply With Quote
Old 11-05-2009, 06:39 AM   #13
ddesros2's Avatar
My usual method is the Q-tip soaked in CA. However, I tried the method of letting it run down the side from the CRC web site...did not work
The nail polish remover did not work.
It looks like ass, but it will work. The electronics will hide the top. I'll craft a sticker or something for the bottom. Next time..Q-tip only!
Old 11-05-2009, 11:20 AM   #14
A lot of newer nail polish remover no longer has acetone in them. You need to make sure to get one that still has acetone. Or just go to your local hardware store and get straight acetone.
Old 11-05-2009, 11:22 AM   #15
Personally I've never been able to get the q-tip method to work. For me it dries too fast and leaves fibers stuck to the sides of the chassis. And for some reason I get a chemical reaction with the q-tip that emits a white vapor.
