Closed Thread
Old 11-03-2009, 09:54 PM   #16
niznai's Avatar
Originally Posted by pakk View Post
I agree. By this time next year, we will be full capable of adding timing the way they do to full size cars. This timing thing is not anything new, just new to RC cars.
Because BL motors have sensors now, the ESC can calculate RPM. RPM with TP angle/position is all we need. We can now "dynamically" add timing. Eventually we will be dragging a line across a graph with X and Y being RPM and TP.
I think this is happening already.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline
Old 11-03-2009, 10:07 PM   #17
skypilot's Avatar
Trader Rating: 14 (100%+)
Originally Posted by mjc168 View Post
Does anyone can explain how to read motor timing? my speedpassion motor no advanced timing adjustable....but i want to know what is the factory timing....Please don't ask me send/call speedpassion to get this information...I want to know how to read from endbell....thanks....
the Speedpassion 17.5 and 13.5 are just about 12-14 degrees on the non adjustable motors. Which BTW is the same a Duo when its in the zero hole.
semi retired..
skypilot is offline
Old 11-03-2009, 11:04 PM   #18
mjc168's Avatar
Trader Rating: 25 (100%+)
how you read the motor timing from end-bell? can you explain to me? how do you know it is 0/15/30 degree? maybe you can show me in picture.... thanks...
http://www.pprcc.com/
1/10 On-road Touring: Schumacher MI3 + Tekin RS Pro + Orca RX-1 11.5t BL Motor
1/10 On-road Touring: Xray T3 2011 + Tekin RS Pro + Tekin Redline 10.5t BL Motor
mjc168 is offline
Old 11-04-2009, 04:41 AM   #19
when you have the new V3 sp motor than it's standard on 12.
http://www.mikky32.com
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline
Old 11-04-2009, 05:32 AM   #20
cyanyde's Avatar
Yes. They're called Orca Vritra and Novak Kinetic. Which I thought was also the Tekin RS. Should've done more research after leaving the hobby for many years before plonking down some hard earned cash.
Logic told me that with the modern day electronic technology available for many years now, this should be the norm in RC electronics. I was wrong.
cyanyde is offline
Old 11-04-2009, 08:10 AM   #21
niznai's Avatar
It will be, no doubt. Just as computers took over every little thing revolutionising everything in the process, it will keep driving ESC and motor development to the point that you will be able probably to shift between programs on the fly from your radio so you are adjusting timing in real time indeed.
Team Greasy Weasel
niznai is offline
Old 11-04-2009, 08:42 AM   #22
Adjusting the timing in RC cars is nothing new, we've been doing that for years with brushed motors.
What is new is the ability too adjust the timing and when it is applied electronically throught the ESC. It is the same principle but more refined and you can fine tune it to match your driving style unlike the old days where it was "set it and forget it".
AreCee is offline
Old 11-04-2009, 10:06 AM   #23
cyanyde's Avatar
What puzzles me is a semi-techie like me knew immediately that variable timing according to speed and load can easily be done by a brushless esc the very moment sensored motors was introduced, took a long time to become reality.
And the irony is, newcomers like Team Wave and Team Orca, both from Hong Kong I think, are the few who had it first!.....
Who'll be copying who now??
cyanyde is offline
Old 11-04-2009, 10:29 AM   #24
M-Technic's Avatar
Trader Rating: 15 (100%+)
There is no way to tell on the Speed Passion motors with fixed timing, because it doesn't really matter anyways (nothing to adjust). Some motors have markings on the back, like the Team Epic Duo2's.
I believe I read that the fixed timing Speed Passion motors have 11 degrees, but I don't know for certain.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline
Old 11-04-2009, 10:31 AM   #25
niznai's Avatar
There is very little new there. The brushless system is based on three phase asynchronous motors which are as old as time itself. The new part is the computer added to the speedy when microprocessors became small, powerful and cheap enough to become economically viable in the R/C market. From now on, it's all going to be software and that is easy to write for teenagers so it is not a surprise at all it is coming out of SE Asian countries.
Team Greasy Weasel
niznai is offline
Old 11-04-2009, 10:35 AM   #26
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
This thread is on it's way to getting out of hand already, lol.
I answered the questions most of you had in the RS thread.
Automotive and any other vairable rpm combustion engine has had variable timing for decades. Wether it was a distributor with flywheel weights and springs to todays cars with computer controlled timing based off of crank shaft speed, cam speed, variable cam phasers, etc.
I've spent some good years working on these systems in my previous years. These aren't "dynamic" neccessarily rather they're "reactive" to inputs. This isn't new and all brushless esc's have and are doing this now. It's in the "how" this info is applied that is the deteriming factor that makes each one faster than the other.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline
Old 11-04-2009, 11:00 AM   #27
The variomatic of Daf. The first to use it and when it was tested in a Formula 1 car, it was for bitten before the first race because the car was a lot faster than all the others
Now you find the Technic in cars that use automatic shifting.
Tekin RS pro
TOP racing Photon
Tekin Redline 10,5
Protoform LTC-R
mikky32 is offline
Old 11-04-2009, 12:31 PM   #28
Like Randy says, this thread is out of hand already. Some posts here are made in good faith, but are misleading. If you are looking for something definitive in the answers to all your questions, you are going to be out of luck.
What's clear is that someone who has got to grips with this stuff, and has found the right motor/gearing/timing combination is going to be faster than someone who hasn't. How is that different from the days of BL 27T and 19T motors? How is it different to the guys who could get speed out of almost any BR motor, whilst most others couldn't?
Nothing has changed. All the information you need to get a fast car is in the other threads. The question is (and I appreciate some people will be insulted by this) can you understand it well enough to work on your car, and do you drive well enough to notice the difference? History (of the BR situation) tells us most of us can't!
There is no definitive answer to all your questions, but there are set-ups that are known to work in the other threads.
Can we all get back to the original RS threads - one for 2S and one for 1S?
SlowerOne is offline
Old 11-04-2009, 01:44 PM   #29
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Having multiple threads for similar topics is very confusing. Therefore, I will close this one.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline
Closed Thread
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
