Old 11-01-2009, 08:25 AM   #1
gijoe64's Avatar
Trader Rating: 30 (100%+)
Default 1C Lipo 1/12 Racing Questions
I know some of the answers are in the 1/12 scale fourm but looking for the answer is hell! I have a few questions that I can't find.
1. If you use a lipo reciever pack (I use a 180mah 2C pack) will you need a voltage regulator to bring it down to 6v for the reciever.
2. I will be racing 13.5 at our track. The track is med size, I ordered 72,73 and 74 spur. What size pinions should I buy?
3. I am using the LRP SPX stock spec esc, should I use any of the breaking profiles on this esc?
Thank you guys for your help.
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 11-01-2009, 08:45 AM   #2
TVMRocket69's Avatar
Send a message via AIM to TVMRocket69 Send a message via Yahoo to TVMRocket69
If your electronics are designed to run off of 6 volts then Yes use a regulator. It will also help the rx pack last the whole 8 minutes by cutting down the amp draw.
On the Horsham Racing thread they posted a roll out of 80-82mm using a 13.5. Those guys are some of the best on the east coast. The rollout also depends on your tire size. I use this site to help me figureout what pinion to use with the spur U choose. http://www.gearchart.com/index.cfm?f...n=chart.create .
I'll be using Speed Passion ESC's so I really can't help with the SPX until my friend buys his. Sorry.
Hope the rest helps.
Bob Walker Jr.-Sponsor's-
AnswerUSA-RC Team Driver, G's R/C Raceway Team Driver, RBMods Team Driver, Kosmic R/C Fuel Team Driver, MurfDogg Motorworks Team Driver, Serpent S811B, Serpent S811t, MurfDogg Powered V-Desizn Carpet Ripper 5
TVMRocket69 is offline   Reply With Quote
Old 11-01-2009, 08:57 AM   #3
LOW ET's Avatar
Trader Rating: 97 (100%+)
spx settings: 2-8-1-1
LOW ET is offline   Reply With Quote
Old 11-01-2009, 09:10 AM   #4
gijoe64's Avatar
Thanks guys for your help
Raymon Robinson
ARC, LRP Go Blue!!
