Old 02-21-2004, 12:01 PM   #1
KevanB's Avatar
Default Bearing Cleaning Process
Ive searched a bit on the forums about cleaning metal shielded bearings and found out that I should use Goof Off, and/or lighter fluid to clean them in a glass container (shaking) then spray with motor spray(once you remove the shields of course).
Are these the best fluids you can use to remove ALL that crap in my bearings? Is that process right?
KevanB is offline   Reply With Quote
Old 02-21-2004, 12:22 PM   #2
Send a message via AIM to True R/C Racing
ive heard the Nitro CLeaning Stuff works Well???
True R/C Racing is offline   Reply With Quote
Old 02-21-2004, 01:51 PM   #3
JusBox's Avatar
Right now i use the integy sparkle cleaning device and motor spray. I need to find something more cost effective as far as cleaning solution though. I think mineral spirits works just as well.
JusBox is offline   Reply With Quote
Old 02-21-2004, 01:54 PM   #4
what do you guys soak bearing into? I Baught brand new Matal shielded and should i soak in some liquid?
Old 02-21-2004, 01:58 PM   #5
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I remove the sheilds, and blast it with motor spray first just to remove as much as possible.
I then fill my Integy Sparkle with motor spray, and let it run for 20minutes or so.
Relube, re-instal.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 02-21-2004, 02:05 PM   #6
I got Just reg reedy motor cleaner(elect) that same? the bearing should be here Monday
Old 02-21-2004, 02:06 PM   #7
Originally posted by TSR6
Relube, re-instal.
What Lube? Trinity Royal oil?
Old 02-21-2004, 02:13 PM   #8
KevanB's Avatar
Yeah Im using the purple trinity stuff. I heard it works wonders. I neeeed to get me one of those sparkles!! Shaking by hand just doesnt cut it!
How else can I remove all the carpet fuzz hair and crud? I tried pulling it out or brushing it...
Old 02-21-2004, 02:18 PM   #9
RCTech Member #2
TSR6's Avatar
Team1rc.com
Team1 Thin ( mobil 1? )
Team1 Superthin - Blue stuff
I only use the blue stuff for bigger races.
Troy
RCTech Member #2
Old 02-21-2004, 02:24 PM   #10
hmmm So If i buy super thin i have to relube quite Often correct? But i think super thin might be the best in my opinion
Old 02-21-2004, 02:30 PM   #11
also heard people take the shield off the bearings? does this work..
Old 02-21-2004, 02:37 PM   #12
KevanB's Avatar
yeah mine are already taken off on one side. You take it off on the side that isnt exposed. Ill try to find a link to it
http://www.schumacher.clara.net/bearings.htm
Old 02-21-2004, 02:44 PM   #13
RCTech Member #2
TSR6's Avatar
Yeah, I take the inner shields off, because the hubs and losi chassis seals it up pretty well.
The super thin, I would probably relube at least every other race day. It's almost thin as water.
The thicker ( mobil 1? ) I usually relube about once a month.
Troy
RCTech Member #2
Old 02-21-2004, 02:47 PM   #14
which would you preffer? the hassle Of taken car apart is no prob i just want The better results...
Old 02-21-2004, 06:11 PM   #15
RCTech Member #2
TSR6's Avatar
I prefer the thin lube, only because it's less maintenance. I cant tell the difference between the thin and super thin on the track, only when free-spinning the diff inside the bearing in my hand
Troy
RCTech Member #2
Bearing Cleaning/Re-Lube almtx3 Nitro On-Road 25 09-02-2008 12:07 PM
Marshalling - Selection process TeamB&B Electric On-Road 30 12-16-2007 05:41 PM
R/C Ball Bearing Cleaning Service Johnathan R/C Items: For Sale/Trade 22 07-17-2006 05:20 PM
ball bearing cleaning andy_b22 Rookie Zone 5 04-09-2006 10:08 PM
Help Need Bearing Cleaning Methods! rc-jockey Electric On-Road 9 12-21-2002 06:41 AM
