Old 10-31-2009, 02:46 AM   #1
Default is my power supply adapter enought?
have accuel 6 charger 5000 2s lipo. The power supply says output of 2A at 12V is that enough?
wantboost is offline   Reply With Quote
Old 10-31-2009, 02:58 AM   #2
Not unless you plan to charge at less then 2 amps...I'd suggest a minimum of 10 amps for a power supply, more would be better.
Old 10-31-2009, 03:23 AM   #3
what size is the connector for that charger? how long would it take at 2amp?
the charger is only rated a 5a why get 10a?
Old 10-31-2009, 09:46 AM   #4
Send a message via ICQ to rcnewb2004
If you use 2A vs 10A, it would take 5 times as long (in theory) to charge your batteries.
But since your charger is rated at 5A then you are only charging your batteries at 40% of the speed your charger is capable of charging at.
You want to have 10A because you may want to run something else off your power supply, for example, another charger... also for "safety"... some cheaper PS's that are rated at 10A... may only go to 9.7A before crapping out... or maybe your 5A rated power supply may need 5.3A to actually run... so if you only bought a 5A rated PS for your 5A rated charger... it "could" (correct me if i am wrong)... fry your power supply...
Always better to have a power supply that can give a bit more juice than what you are plugging into it.
Kinda like... if you are going on a 100km trip... you don't want to only exactly put 100km worth of gas into your car's gas tank...
long story short, you want more amps because sh*t happens.
Ta04-TRF, EVO 5
Futaba
KO Propo
Spintec
rcnewb2004 is offline   Reply With Quote
Old 10-31-2009, 12:39 PM   #5
ok . im not looking for an actual power supply just AC adapter. also not sure if i will run the full 5A on the lipo may get too hot.,
Old 10-31-2009, 03:43 PM   #6
PDX-Spike's Avatar
Five amps is appropriate to charge a 5000mAh LiPo.
Roger Christal - Team Timezone (Hooligans), Rose City Scale Racing, ROAR Member until 9/16/2012
Support the locals: Timezone Raceway, Timezone II, R/C Plus, Portland RC Raceway
McKune Design, Slapmaster Tools, Houston's Engine Service
PDX-Spike is offline   Reply With Quote
Old 10-31-2009, 04:28 PM   #7
If you are using a DC powered charger you will want a power supply not just an AC adapter. Typically those can not take the stresses of RC.
As for why 10a? As stated earlier...you may want to use it for something else later on like a 2nd charger or tire truer.
Old 10-31-2009, 05:13 PM   #8
5A is right for RC.... If you are charging a 5000mAh battery, this means it will take an hour to charge it, which is pretty standard. It is probably not going to get too hot (I haven't ran lipos yet, but I am pretty sure about it from what I have read.)
A power supply used for RC usually takes 110-220VAC and converts it to 12VDC. The difference between a PS and an AC adapter as stated before is that they typically are not able to output 10A or even 5A at 12V.
Ta04-TRF, EVO 5
Futaba
KO Propo
Spintec
novak smart tray se issues turboxrayt1fk05 Electric On-Road 33 10-23-2007 12:12 PM
