Old 12-13-2009, 12:09 AM   #106
dsrbltoys's Avatar
Originally Posted by mark xray007 View Post
Hi I just got my X12 17.5 and was wondering would it be better to run a higher roll out and lower final drive since these motors have alot of talk
or should i run a lower roll out and change spurs to get my final drive down around 4.0
That will depend on your track and speedo choice.
dsrbltoys is offline   Reply With Quote
Old 12-13-2009, 04:15 AM   #107
Send a message via MSN to mark xray007
Im using a lrp sxx tc spec speedy the track has a 25 m straight the rest is fairly slow there is a s bend a 2 hairpins
mark xray007 is offline   Reply With Quote
Old 12-13-2009, 01:54 PM   #108
mutley001's Avatar
I'm a bit confused guys on which speedo to choose for 10.5
I've been using the X12 10.5 motor and love it but should I now buy an SXX TC Spec speedo for it or wait for the SXX Stock Spec Speedo release?
I run paimarily indoors rubber tyre on carpet with a Tamiya TRF 416
Thanks for any advice and opinions
Paul
ARC R11 2017
ARC R10 2013
EA Motorsports www.teameamotorsports.com
Team EAM
mutley001 is offline   Reply With Quote
Old 12-13-2009, 02:07 PM   #109
Wait for the SXX Stock Spec
Niklas Hansen
Team TCHobby / Team Upgrade-RC
Tamiya TRF417 / Speed Passion GT2.0 / Speed Passion V3 motors.
Nilks is offline   Reply With Quote
Old 12-13-2009, 02:12 PM   #110
Stephtruc's Avatar
not sure...
on X12 you can add timing on motor
YES for fixed timing motors
Stephtruc is offline   Reply With Quote
Old 12-13-2009, 03:14 PM   #111
Stein Tumert's Avatar
Yes, definitely wait
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 12-13-2009, 10:36 PM   #112
HI_808's Avatar
I tested the 17.5 X12 today for the first time in my 416 with a SPX. I started out on profile 6, FDR 4.86, and the stock "0" degree timing insert. It was fast, but the motor was at 180 F after two minutes. I ended up with profile 6, FDR 5.2, and the "-5" degree timing insert. It temped at 180 F after 8 minutes. This was in ~85 F ambient. I did not try the "-10" degree insert though I am thinking about using it with a higher FDR.
The manual says not to use profiles 7 or 8 on the SPX. I don't think it's necessary because this thing is so fast. As some have reported, the motor does feel very much like a brushed motor due to the magnet being so strong. The only handling issue that caused was under braking. The brakes are so powerful, it will lock up your front wheels with the slightest tap if your brakes are set to 100%. All I needed to do was turn down my brakes on my radio to fix that.
HI_808 is offline   Reply With Quote
Old 12-14-2009, 08:50 AM   #113
Trader Rating: 45 (100%+)
So will the LRP SXX StockSpec have anything for the BD speedo in 1:12 1S LiPO? I was running the SPX against the BD's in 10.5 and I was getting walked down the straight away with ease by the BD.
Apex is offline   Reply With Quote
Old 12-14-2009, 01:53 PM   #114
ShaunMac's Avatar
Let's hope so. It would be a shame for LRP to drop a new speedo for stock racing that isn't AT LEAST on par with the current competition.
Come on BLUE DIAMOND!!!
ShaunMac is offline   Reply With Quote
Old 12-14-2009, 02:09 PM   #115
mutley001's Avatar
Thanks for the advice guys - cummon LRP get this SXX Stock spec ESC out to us!
Cheers
Paul
ARC R11 2017
ARC R10 2013
Team EAM
Old 12-14-2009, 05:50 PM   #116
adamge's Avatar
Has anyone taken an X12 17.5t apart to figure out why it is different than other 17.5t motors? Rotor inner diameter, outer diameter, length, rotor material, stator dimensions...
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 12-15-2009, 10:38 PM   #117
Default X12 17.5
On a short track avg about 12 sec with 2 hairpins a set of ss and a 25m straight would a high or lower final drive be better any help would be great
Old 12-21-2009, 06:41 PM   #118
jmackani's Avatar
Trader Rating: 14 (100%+)
Does anyone have a date as to when the sxx stock spec esc is going to be available yet?
jmackani is offline   Reply With Quote
Old 12-21-2009, 06:42 PM   #119
flopunquo is offline   Reply With Quote
Old 12-21-2009, 08:46 PM   #120
adamge's Avatar
I call plagiarism.
-Nietzsche
