LRP Vector X12 StockSpec and SXX stockspec
#151
#152
Paul
#153
For those trying to decide on what speedo, this is what I have found. I have the SPX and am looking to buy another speedo but I think I have to buy another SPX because I run 10.5 and up.
The SPX- specially developed for stock racing and Fully dual purpose and excellently suited for both stock and modified racing.
The SXX TC-Spec- Perfect speed control for 1/10 Onroad (Touring car MODIFIED) and 4wd Offroad MODIFIED.
SXX Competition - Specially developed for 1/12 Onroad and 2wd Offroad.
SPX Brushless Competition Stock-Spec ESC-
Get the edge over the competition with this speed control specially developed for stock racing. Features improved hardware and our special “Stock Spec” software which increases stock motor performance significantly. Fully dual purpose and excellently suited for both stock and modified racing, the power profile 5-8 is specially for “Stock Spec” and 1-4 profile is ideally suited to modified racing.
Features:
- Automatic brushless/brushed adaptation
- Advanced digital with 4 adjustable modes
- ADPC-Advanced Digital Phase Control
- Stock and modified power profiles
- Ice Drive Design
- Automatic NiMH/LiPo adaptation
- Optimised for the use with 4, 5 and 6 Sub-C cells
- Launch control
- Internal-Temp-Check System
- 3.0A BEC
- Blue LEDs
- Weight only 24.5g
- Multi-Protection-System
- External soldering tabs
- 2,6mm power-wire
- Sensored design
SXX TC-Spec Brushless ESC-
LRP sets new standards and is conquering R/C-racing worldwide!SXX series is a complete redesign of the super-successful SPHERE series and boosts brushless performance into a new dimension. LRP once again confirms and proves its leading position in brushless technology.
The all new SXX TC spec represent the best of today’s brushless speed control! With its new ADPC 2 software, low profile heatsink and plugged fan, optimised Internal Temp Check System 2 and many more great features results in a perfect speed control for 1/10 Onroad (Touringcar modified) and 4wd Offroad modified.
- C3 Technology: Revolutionary Copper Core Cooling technology for lowest running temperatures
- New X.Brake: Stronger brake and 10 autobrake setting for perfect adjustments.
- New ADPC 2 software: 10 power profiles, includes all profiles used by the team.
- Extra small size: 30.5x34x21mm
- Optimised Internal Temp Check System 2: Allows you to read out the maximum internal temperature that the speedo has reached.
- Sensored design
- AutoCell System: Automatic NiMH-LiPo adaptation
- Externally removable power capacitor and 3.3mm2 power cable
Motorlimit: over 3.0T (7.4V)
Rec. Motorlimit Brushless: over 2.5T (6.0V)
Voltage Input: 4.8-7.4V
Type: Forward / Brake
SXX Competition Brushless ESC-
LRP sets new standards and is conquering R/C-racing worldwide! SXX series is a complete redesign of the super-successful SPHERE series and boosts brushless performance into a new dimension. LRP once again confirms and proves its leading position in brushless technology.
High-tech features and matched components is what makes the all new SXX Competition the highest performing speed control today. This completely new revolutionary speed control set new benchmarks is brushless speed-control technology. The SXX Competition is specially developed for 1/12 Onroad and 2wd Offroad.
- Extra small size: 30.5x34x16mm
- Sensored design
- Externally removable power capacitor and 2.6mm2 power cable
- only 16mm high
Motorlimit: over 4.5T (7.4V)
Rec. Motorlimit Brushless: over 4.0T (6.0V)
Voltage Input: 4.8-7.4V Type Forward / Brake
Features:
- Ice Drive Design
- Launch control
- 3.0A BEC
- Blue LEDs
- Weight only 24.5g
- 2,6mm power-wire
- Sensored design
- Sensored design
- Sensored design
- only 16mm high
#154
We'll have to wait until Mid January to know the specs.
Erik
#155
I'm thinking that the way to go is with either 1) profile 6, around 7+ FDR, and the 1-dot (+5deg) or 2) profile 6, 2-dot timing, and really aggressive FDR of 6 or less.
#156
With Profile 7 and 7.2, 4 dot after about a minute is was already at 185 degrees but the motor had zero punch and was only fast at the end of the straight. So thats why I think we need a final of 8 or maybe more.
I think you are right! So far my best setup on a carpet track is profile 6, 2 dot, 6.2 final.
#157
Great copying of the LRP sales material though....
#158
I also wanted to buy the SPX Stock Spec to start in Stock class but did hold my horses luckily a week before they announced the SXX Stock Spec.
Since as a newcomer I'm more interested in 1s 3.7V Lipo I feel the SXX Stock Spec will suit me better.
Indeed as you stated I'm sold already but no sales percentage coming my way
#159
I reacted because he was talking about the SPX Stock Spec compared to the current SXX models out there hence I made the comment that the SXX Stock Spec might be a good one to compare with since they're both Stock Spec.
#160
but I don't know the further details.
Person to ask is "burito" (Reto Koenig LRP ) but he is on holidays now from what I've read in a previous post.
My guess once it comes out or the prototypes are considered ok , the final specs will be given.
Erik
#161
If you go to www.lrp.cc you can download the 2010 catalog.
Check out page 53...
Now it is my turn to copy from the LRP sales stuff...
SXX STOCKSPEC
Dual ADPCmax Software: Individuelle Einstellung von „Feel“ und „Boost“
für maximale Flexibilität und höchste Power in allen Klassen, bei allen
Zellentypen und allen Motoren.
TwinBEC: Eine wahre Revolution! Konstanter 6V/3A Output mit 3.0V bis 7.4V
Akkuspannung. Kein Empfängerakku mit 1S oder 4 Zellen notwendig.
Revolutionäres Internal-Temp-Check System 3: Ermöglicht das Auslesen der
SXX STOCKSPEC
Best.Nr. 80910
Spannungsbereich nominal 3.7-7.4V
B.E.C. 6.0V/3.0A
#162
When Tekin drops their new software in a few days, and makes their 2 year old hardware just as capable as anything available today, how do we justify buying a whole new ESC for the software profiles?
LRP won me over with the fact that their software is so reliable, and ahead of its time, but I've gotta tell yah, after buying two SPX's and watching Tekin slowly catch up and overtake them with the same hardware they used to overtake the TC Spec, and free software updates, it's hard to justify buying MORE hardware to get back to status quo with the SXX Stock Spec. Reto, I'd pay double what Tekin asks for an LRP ESC that got regular software updates. You guys do such great work, but I feel like the SPX might be my last fixed firmware ESC.
#164
#165
Tonight I tried profile 7, 4-dot timing, and 6 FDR and the X-12 was very fast. Also, no real problem with temp, which was around 170 deg F. However, from what I'm hearing, these motors run hotter than you would expect. Might want to give it a try. I think it was better than profile 6 and 2-dot.
I feel the flowing layout contributed to the manageable temps and low FDRs compared to the carpet tracks that myself and Paul are used to.
Mike Slaughter
