Old 10-29-2009, 07:39 PM   #1
drive2survive's Avatar
Trader Rating: 23 (100%+)
Default C-HUB RATING?
I notice some C-hubs have degree numbers imbeded in the material,is that how ya change the toe using diffrent hubs? I could be mistaken but dont see anything esle that would adjust it
"OLD MUSICIANS NEVER DIE, THEY JUST DE-COMPOSE"
drive2survive is offline   Reply With Quote
Old 10-29-2009, 07:42 PM   #2
Scottmisfits's Avatar
The C Hubs change the caster angle. Toe change the front toe, use the steering links.
Scottmisfits is offline   Reply With Quote
Old 10-29-2009, 07:46 PM   #3
Ah Daaa just seen it, thanx
Old 10-29-2009, 07:46 PM   #4
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
the #'s on the hubs change the caster of the front end. meaning that if you put a line from the upper pivot ball and the bottom hinge pin it is how much the upper pin is mover back from a center line. so 2* would be 2* of caster. 4* would be 4* of caster. you always us neg. caster. there will be 2* left and a 2* right. same for the others. 2* will give the most turn in and least turn out of a corner. where 6* will be the least turn in and the most turn out of a corner. hope this helps. jeremy
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 10-29-2009, 08:00 PM   #5
I was reading thats what the toe does, like>>>>>>>>the more toe out and better for turn in but not as good for mid-corner or exit and toe in is better for mid corner/exit but not turn-in...how does toe and caster differ?
kinda like whos on 1st and whats on 2nd...
Old 10-29-2009, 08:06 PM   #6
Typically front toe will be a last resort type setting. Adjust everything else first, roll centers, ride heights, camber, caster, kick up, then use toe as a fine setting. Typically you want zero front toe. At least to start with.
Old 10-29-2009, 08:09 PM   #7
Moderator
J.Whiting's Avatar
toe is for smaller changes. caster is a bigger change for turn in and out. to much toe in or out make the car handle very twitchy. +1 to -1 is all you want for toe. caster is 0* to 8* on some cars. jeremy
Old 10-29-2009, 08:34 PM   #8
so besides the caster thing Im assuming they have setup tools/gauges for this right? if so whats a good one to have?
The elusive "C" Rating on Lipos Neu_Racer Electric Off-Road 20 09-29-2009 06:41 AM
LiPo C-Rating & 13.5 CanyonCarverR1 Electric On-Road 22 05-05-2009 09:51 PM
Which C rating to choose? ErikO Radio and Electronics 8 04-24-2009 03:33 PM
C Rating battery craze! True or untrue!! Bulldawg RC Electric Off-Road 236 03-11-2009 01:44 PM
What is the lowest C rating I should look at for a LiPo? y2kgtp Electric Off-Road 45 10-31-2008 12:03 PM
ROAR Lipo "C" Rating Standarized Method Xtreme2008 Electric On-Road 23 04-03-2008 08:15 PM
