Old 10-29-2009, 12:24 PM   #1
Trader Rating: 20 (100%+)
Default 48P vs 64P
I am new to the onroad RC world and have been using my pinion and spur gears from off-road which are 48P. Is 64P better for onroad?
Also, I have a stock 72 spur (I think it is 48P). If I do go 64P what should I start at with spur and pinion? Will this vary from the 48P? I don't quite have a grasp on 48P vs. 64P. Hopefully someone can help me out. Thanks in advance.
storytyme is offline   Reply With Quote
Old 10-29-2009, 01:51 PM   #2
geeunit1014's Avatar
64P has finer teeth, and therefore allows more ratio options than 48P, the downside is the window for gear mesh is a lot smaller with 64P, and the teeth are more susceptible to damage. I would just run whatever you have access to locally, that will be easiest for you to get spares and gear options. If you do switch over to 64P, you can multiply by 2, and divide by 1.5 to get the equivalent gear. So your 72 would be a 96.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 10-29-2009, 02:22 PM   #3
What pinion would be good to start with with a 72 48P spur? Or should I base it on my FDR? If so, where should the FDR be at? Running on carpet with a 13.5
Old 10-29-2009, 02:31 PM   #4
Scottmisfits's Avatar
You have to base your gearing off of a few things but FDR is based on gearing of the diff pulleys (internal ratio), and your spur/pinion combo. Use a site like www.gearchart.com to figure out what you should be running based off of what car.
For a 13.5 motor, anywhere between a 5 and 5.5 FDR, depending on track and motor.
Scottmisfits is offline   Reply With Quote
Old 10-29-2009, 03:15 PM   #5
PDX-Spike's Avatar
Provide the specific car you're running and the type of track (big, small, flowing, technical) so people can give you a better idea of where to start.
Roger Christal - Team Timezone (Hooligans), Rose City Scale Racing, ROAR Member until 9/16/2012
Support the locals: Timezone Raceway, Timezone II, R/C Plus, Portland RC Raceway
McKune Design, Slapmaster Tools, Houston's Engine Service
PDX-Spike is offline   Reply With Quote
Old 10-29-2009, 03:24 PM   #6
car is a TC4 on a carpet mid size track. Long straightaway. technical
Old 05-18-2010, 10:19 PM   #7
JKL1031's Avatar
why cant i find a 48p spur with over 100 teeth?
JKL1031 is offline   Reply With Quote
Old 05-18-2010, 10:27 PM   #8
JKL1031's Avatar
its going on an xray BTW.
Old 05-19-2010, 02:25 AM   #9
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
Because a 100t 48dp spur would be huge and have trouble fitting on most cars...
The max on a xray is about 90, and that doesn't leave many options with ratios....
Hth
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
48 pitch vs. 64 pitch for 1/12??? Taylorm Electric On-Road 24 07-14-2008 01:49 AM
48 pitch vs 64 pitch bvoltz Rookie Zone 11 04-12-2006 06:26 PM
68 Pitch vs 48 pitch jamie814340 Electric On-Road 16 01-04-2006 09:14 AM
Xray T1 Evo 2 vs HPI Pro 4 vs Corrally Assasian murfy Australian Racing 78 02-05-2004 05:15 AM
48 Pitch vs 64 Pitch CRASH Electric On-Road 11 02-22-2002 12:13 PM
