Xray T1
Yes I very often run WD , it's great Also from my experiences it has better grip at colder weather than LRP additives . On warmer conditions pro aditives are surely better but not by much , still makes the WD an economic option
BCbud , really great to see you running this car at big meetings I have only white and yellow shocks , always used all 4 white ones . Do you reccomend using yellow ones at the back ? Also , how many holes in shocks ? I'm running 13T brushless class and tracks we run on are technical with medium grip ...
Yep, it does sound like a good budget option... can you talk about the application period and methods? like how long before use and what are the long term effects? I am always looking for alternatives to importing stuff to the island...
This is my beloved car
The best way in my opinion is to give the tyres WD , then wrap them in plastic foil ( I don't know the right word , the one you use in the kitchen for food preservation ) and leave them overnight . Next day at the track , the tyres are extremely sticky and ready to use . If WD is applied before racing , same rules as for pro aditives : after applying it , leave it for a few minutes to dry and its ready
Are there any negative effects using this technique on the tyres?
Alien
Thanks for the compliment man... I'm going to be breaking those 36Rs (SOREX) this weekend... still have a lot tuning to do on the car...
Alien
Alien
looks that way... will try it and report my finding in the weekend...
Hi Guys... i tried some WD-40 on the 36s and it worked great... the car was well planted on entry of the corner and had no issues powering out of them...
Alien
Alien
A stupid question ...
T2/T3 shocks should fit T1 without any problems ?
yes they do, but i'm not sure if the internal parts can be swapped...
Ok guys... i got the car hooked up nicely... just need to work on my driving skills... one big mechanical problem i am currently facing is the constant failure of the 3mm
plastic drive shaft caps... I am running a spool up front... every time i make a run, the plastic caps go a away... anyone else having this experience? suggestions? fixes...
any help will be appreciated...
Alien
Alien
