Old 08-07-2002, 03:45 AM   #1426
ok thanks arnoud i guess ill just wait a few weeks then.but i guess its not like i really have a choice!
Jarrod Langlois is offline   Reply With Quote
Old 08-07-2002, 05:33 AM   #1427
RC Nitro's Avatar
spaz456: I run the T1 on carpet. Bought the C-Hub conversion from Buster. On the setup board using a Futaba S9402 I get 22 dergees of turning. With the C-Hub I get 33 degrees of turning. I run the C-Hub front, rear is to low on T1, 1.5mm clearance. To date I have broke nothing in the last month or 2 months on asphalt. I bought the impact bumper, and transponder mount initally along with hardware kit and bumper. I want the spring steel hubs and a EV2 Just need $$$$ Double on the weights. I have every hudy weight on car to make T1 legal.
RC Nitro is offline   Reply With Quote
Old 08-07-2002, 06:05 AM   #1428
stormperson's Avatar
Send a message via AIM to stormperson
How do I contact Buster Bennett? does he have an email? or website?
stormperson is offline   Reply With Quote
Old 08-07-2002, 06:34 AM   #1429
RC Nitro's Avatar
Call Riders Hobby where he works. 703-430-2202
Old 08-07-2002, 06:39 AM   #1430
university_dave's Avatar
If you want more lock with the standard pivot ball setup then you could always simply dremel out the sides of the seatings for the pivot balls in the hub carriers.
This works with the pivot ball front suspension on the Mugen XR Works.
university_dave is offline   Reply With Quote
Old 08-07-2002, 06:54 AM   #1431
thanks rcnitro, ill probably run the car first with front pillow ball setup, but i may just buy the c-hubs when i order the car, if i get it from buster.
Old 08-07-2002, 08:33 AM   #1432
Thumbs up Great!
I think it's great to read so many enthausiastic reactions in this forum on theXRay. It still is a very Europea car and I found that the US car preferred the Losis en the Associates for this reason and because it is so easy to get the parts!
Do not forget that in case you are an XRay driver you will get access to the MyTSN XRay VIP room which really gives a lot of iformation, a lot of times direct from either Mario Hudy, Tony Vredenberg (a Dutch XRay top driver) or guys like Buster!
Arnoud is offline   Reply With Quote
Old 08-07-2002, 09:49 AM   #1433
ok cool, that should be helpful once i get the car, at least if i break something on the car that i have to wait a little while for ill still have my tc3 and pro3.
Old 08-08-2002, 05:33 PM   #1434
Does anyone in the USA know of a hobby shop that has a Xray evo 2 in stock and that would be prepaired to ship it to the UK? I would also like to get the c hub suspension setup as well.
Rick
Rick Draper is offline   Reply With Quote
Old 08-09-2002, 05:24 AM   #1435
Caddzilla's Avatar
Send a message via ICQ to Caddzilla Send a message via AIM to Caddzilla Send a message via Yahoo to Caddzilla
Send Les at MDIRacing an email at [email protected] , he had one in stock.
Caddzilla is offline   Reply With Quote
Old 08-09-2002, 06:51 AM   #1436
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by stormperson
........... and he said he doesnt run any hop ups, except that the front drive shaft would bend? or something like that, can anyone elaborate on this?
The driveshaft can bend with a hard hit......but if you tap them back to approx. straight and continue running...they will striaghten themselves out- completely!! I still run the original driveshafts on mine....thats the beauty of "spring steel"!!
dtm is offline   Reply With Quote
Old 08-09-2002, 06:57 AM   #1437
dtm
dtm's Avatar
and finally, what spare parts should i invest in?
1. Front hubs (although I have never broken one)
2. Rear damper plate
3. Rear body mount
4. Upper foam bumper plate (graphite)
5. Wheel bearings
6. Rear A-arms
7. Shock bodies
Thats really about it!
6 and 7 will only break if someone smacks you from the rear. 2 and 3 will let go when you go for a heavy 'roll'- you can prevent this by running 2 pieces of rear damper plate bonded together- incredability strong!!
Old 08-09-2002, 07:56 AM   #1438
by rear damper plate do you mean shock tower? and have you broken them with the EVO 2 or the orginal?
Old 08-09-2002, 09:43 AM   #1439
dtm
dtm's Avatar
Yes, I mean rear shock tower! It's the original I have broken (2 in fact!) that because it is very high up!
Old 08-09-2002, 09:47 AM   #1440
dtm
dtm's Avatar
Heres a piece of useless info!!!.....just installed my C hub kit...with all that Alloy was expecting it to be heavier...to my surprise the C hubs came in 6g lighter than the original plastic!!
However, that may be because I was running steel axles on all 4 original hubs, but with C hubs I am running 2 alloy and 2 steel!!
