Old 09-22-2001, 06:28 PM   #121
what do you think the difference is between the corally and the x ray
Where can i buy them
Gump0220 is offline   Reply With Quote
Old 09-24-2001, 01:47 PM   #122
Default Xray website
Xray is getting close to finishing up there online ordering system. To bad you can't get cars for 10 bucks like the site shows.
damo is offline   Reply With Quote
Old 09-25-2001, 12:22 AM   #123
Usagi's Avatar
Deleted
Usagi is offline   Reply With Quote
Old 09-26-2001, 10:17 AM   #124
One belt
The one belt design may never make it to production. It is still in prototype form at the moment. Maybe if there is enough demand for it, but we will have to see. The car is a great performer as is if you take the time to learn how to tune it.
Old 09-26-2001, 02:26 PM   #125
Regional Moderator
Darkseid's Avatar
Gump0220: There are plenty of differences between the Xray and Corally. It would be simpler to say whats the same. They share the same Serpent shocks. They have similar shaft mounted one-ways. They both have externally adjustable diffs. Both cars are insanely adjustable and have excellent workmanship. Other than that, their just two cars that look alot alike.
The Corally can be found at www.superiorhobbies.com or www.corallyusa.com or you can have your local shop special order it for you.
I'm sure the regular guys here can tell you where you can find the Xray T1.
TLR 22...Tamiya F104...
Old 10-01-2001, 10:46 AM   #126
ttt
Old 10-01-2001, 11:03 AM   #127
Usagi's Avatar
Smile
Deleted
Old 10-01-2001, 12:24 PM   #128
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
I have my car dialed-in for faster entries into and out of turns. I was astonished by the increased level of performance with the addition of weight in the front. I was told to add weight but tried my best with out using it. I had added 7 grams to the left side to balance the chassis and when making left turns the car pushed. But when making right turns the car was dialed.
This past weekend I added more weight, but to the right front. Long and behold I have incredible on-power bite left and right into turns. Off-power is a given, slight oversteer is the obvious characteristics.
Ultimately, I added 14 grams to each side and feel that is sufficient for tracking through the turns. In addition to the added weight, I milled my own Eccentric Front Upper Pivot Pin Holders and use the lowest setting. In doing that, it means the re-action of the front-end is spontaneous and aggressive, therefore, harder valving of the shocks is neccessary to prevent the front-end from bottoming.
My past run was on treated concrete and I can only think that it will perform better on treated asphalt. I find that out on Oct. 7th.
L8r.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 10-01-2001, 11:56 PM   #129
ottoman's Avatar
R/C Tech Charter Subscriber
Does anyone know were I can buy a oneway for my T1 in the states? My LHS has been telling me "next week" for three months.
ottoman is offline   Reply With Quote
Old 10-02-2001, 05:43 AM   #130
Try http://www.atomichobbies.com, they may have it.
V-Dezign 4.0
Old 10-03-2001, 12:00 PM   #131
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
I found this little dude in the bottom corner of a page on the Xray website. I thought one of you guys might want to use it on your signature or sumthin'....
here's the link: http://www.teamxray.com/teamxray/show.php?img_id=361
Hmmm..... it's not showing up as an image... just a link. That's weird...
Maybe this one will work:
BigDogRacing is offline   Reply With Quote
Old 10-03-2001, 12:05 PM   #132
The reason it does not show is because that function is disabled. Check your Control Panel for that info.
V-Dezign 4.0
Old 10-03-2001, 12:09 PM   #133
I checked, the show [img ] function is on. I'm showing the other small Xray icon, in my post, but not the one from the Xray site.... weird huh?
Do you see it RCCadet? Or do you just see the link????
Old 10-03-2001, 12:12 PM   #134
So initially you missed surrounding the referenced URL with the IMG tag?
It is not an absolute reference to the image therefore it can't be called. Pretty cool I think.
V-Dezign 4.0
Old 10-03-2001, 12:31 PM   #135
ottoman's Avatar
RCCadet Thanks but I am dealing with atomic hobbies. I guess that means they are still not available here. I must say I have been dissapointed in the factory support as far as parts goes. Carpet season has started and I cant get the parts I need. I guess I will have to run my TC3 or my XXXs.
