Old 04-28-2011, 12:03 AM   #12616
angry-alien's Avatar
Good to see you got together again... what sort of advice do you need? will you be running on carpet or asphalt? Tell me how that r9r body works...
been reading that it's a little aggressive...
Alien
angry-alien is offline   Reply With Quote
Old 04-28-2011, 12:36 AM   #12617
jordanjester's Avatar
Alien
thank you! i'm running on asphalt and mainly advice about the motor and set up for road. i only use to run carpet so it's hard for me to adapt you know?
the r9 is amazing, and i guess you could say it's a little aggressive lol
i'm still having a little bit of traction loss out of turns though.
I ask questions because i enjoy talking to people, why bother living if you can't be friendly.
DRIVE T1'S!
jordanjester is offline   Reply With Quote
Old 04-28-2011, 11:14 AM   #12618
If you are losing rear end traction 'on power' out of the corners, you may have to loosen the rear diff a little... you can also look at the rear toe...
how is the surface you're running on... is it treated? are the tyres 'sauced' before you run?... the r9r also puts a lot of down force on the
front end and not that much on the rear i believe...
Tell me more about the electrics... from what i can see so far, is that it's a non-sensor motor... if that's the case, you will have to be very
smooth on the throttle out of corners...
Alien
Old 04-28-2011, 01:49 PM   #12619
Alien
well, it is a non sensor motor, it's a reedy 540r? i'm using the speedo it came with an xp digital or something like that, receiver is a novak xxl(really really old) and a hitech servo. can't afford a lipo right now, wouldn't know how to set it up with a t1 anyway
the car is super hard to drive, the street is in front of my house so it's not ideal for driving but, it's not that bad. theres a one way is this(it was my backup for carpet) so i think i'm going to take it out? also, would standing the shocks up more help?
on another note, i really appreciate your help. this day and age i wouldn't expect it you know?
DRIVE T1'S!
Old 04-28-2011, 02:24 PM   #12620
No Problem man... A oneway won't help you very much on asphalt... Try a solid spool or a diff up front... keep the tops of shocks closer to center of the tower...
standing them up would be more suited for carpet... are you using stock shocks? if so, adjust the rears to soften them a little... a little roll can help... make some
notes on what the car does exactly...
Have a look at the hudy setup guide on the xray site... http://www.teamxray.com/teamxray/pro...a=253&catName=
Alien
Old 04-28-2011, 04:12 PM   #12621
UrabusDenis's Avatar
I don't reccomend the one way . I run a diff in mine and I'm super satisfied with it . It's very tight but not fully ( I like it that way ) , no complaints
Angry alien , I run all 4 white springs , do you think I should have a go with yellow ones ( super soft ) at the back ?
UrabusDenis is offline   Reply With Quote
Old 04-28-2011, 08:08 PM   #12622
BCbud's Avatar
Trader Rating: 37 (100%+)
Good day!
Are you planning on running on a prepaired track or just on the street? On a prepaired track the rear end will not wash out as mutch. there is a couple of ways to help fix this. You can try to make the rear stick better or you can try to mak the front a bit looser to make it equal or a bit of both. I run my rear shocks in a new hole I made in my tower that is further in to lay them down more. I use a yellow spring with 30w oil and the adjustable shock in the softest posision. In the front I run 30w oil with purple springs with the shock set at the hardest position and mounted on the 2nd outmost hole. I am using X-ray springs, are you? The colors may be the same from different manufactures but do not have the same rating.
On a prepaired track the car worked well but when we just had a practis day with no track prep my car and most others had rear grip problems and we had to be very soft with the throttle.
The weather has not been good here but it looks like we may get lucky this weekend and hopfully we will get a full day of racing in. That will give me a better idea how my car is working. I am also going to try and run only 32's tires no matter what the weather is like unless it gets realy hot then I might put on 36's
More to follow.
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 04-28-2011, 08:27 PM   #12623
Well, it depends on the results you're getting with the whites... do you need more roll in the rear? are you losing the rear on power?
Alien
Old 04-28-2011, 08:31 PM   #12624
More to follow.
VIDS!!!
Old 04-29-2011, 05:14 AM   #12625
Well , it really depends on the conditions , sometimes yes sometimes not . I'll try it , at least springs aren't hard to change
Old 04-29-2011, 06:46 AM   #12626
Yeah... the blues are pretty hard springs and i am still able to get good traction with two holes closed on the shocks... so It's really the conditions
of the track that will dictate the behavior of the car...
Old 05-05-2011, 01:27 PM   #12627
Hi guys, just a small vid tour of the car on its stand... if i get to the track this weekend, i'll make some more...
+ YouTube Video
Alien
Old 07-17-2011, 10:37 AM   #12628
Hey guys... just checking in... how are your T1s?
Old 07-17-2011, 12:47 PM   #12629
Deves's Avatar
Default Aluminum hubs
Anybody need some aluminum hubs for a T1? I have no use for them... Post here or pm if
interested. Not looking to get rich just want them to go to a good home.
All parts are sold.
Deves is offline   Reply With Quote
Old 08-08-2011, 01:41 PM   #12630
Hey guys, you all know where i can find the the outdrives bellow? i broke mine last night during a test... i will need a store or person who will accept paypal...
xra305131 Outdrives:
They fit this:
thanks
Alien
