Old 01-03-2011, 08:48 AM   #12466
angry-alien's Avatar
Can't you get a little more steering by moving some ballast to the front of the car?
Alien
angry-alien is offline   Reply With Quote
Old 01-03-2011, 01:05 PM   #12467
UrabusDenis's Avatar
This car can be very competitive on smaller speeds if maintained properly of course . I'm running 13T brushless and I'm in the front runners with my T1 FK 04 , faster than T2 008s , T3R and TC5s . These cars are also stronger and more simple than modern ones . I recomend the modern layout because the battery on the side , simply because LiPOs are mostly in that layout .
Received my order ( set of bearings and 3x180 rear belt ) directly from Xray today , unfortunately I received a set of T2/T3 bearings !!!
UrabusDenis is offline   Reply With Quote
Old 01-03-2011, 01:19 PM   #12468
Do you have any photos of your setup and specs regarding the ballast? are you running on carpet or asphalt?
Alien
Old 01-03-2011, 07:16 PM   #12469
Alien
Unfortunately not , since the car is now in parts for the rounding carbin edges process . Will post pics soon , when it's rebuilt
Old 01-03-2011, 07:40 PM   #12470
nice... I'll be doing a rebuild soon as well... the car has taken a serious thrashing for the last month or so...
where are you guys currently ordering parts for the T1?
Alien
Old 01-03-2011, 09:53 PM   #12471
alcyon's Avatar
Alien
yes, but it will also add additional total weight to the car. now i am at 1440 with 15g extra in the front and 30g on the servo side to balance out the ESC. if i add more weight to get close to 50% front, the car would weigh close to 1480, and the track minimum is 1400. i prefer to have the car lighter, eventhough the back may be heavier, maybe i will try a little harder spring at the back next time.
alcyon is offline   Reply With Quote
Old 01-03-2011, 10:16 PM   #12472
I see your point...
Old 01-03-2011, 10:43 PM   #12473
BCbud's Avatar
Trader Rating: 37 (100%+)
Good day!
Here are some pictures of my car with the latest configuration. I have moved the servo to the left hand side, to do this I had to rotate the bearing holders for the steering servo saver 180* so that the steering arm would clear the bulkhead on the left side. Because of this both diffs had to be fliped over so the belt would clear the servo saver.
The care is ballenced from left to right. The front end weights in at 702g and the rear end is 695g. I have one 7g weight on the rx to ballance the car. All weights are with the body on.
Xray T1-dscf0093.jpg   Xray T1-dscf0094.jpg   Xray T1-dscf0095.jpg   Xray T1-dscf0096.jpg
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 01-03-2011, 11:03 PM   #12474
very cool setup there... how does the rear end handle with that shock geometry? also kind of surface are you racing on? thanks for sharing the photos...
Old 01-03-2011, 11:15 PM   #12475
BCbud's Avatar
I have not run it like this yet. I normaly run this car outdoors on pavment but the club I run with is having there first indoor trophy race so I will be running it on carpet for the first time.
Recycled teenager.
Old 01-03-2011, 11:27 PM   #12476
interesting... let us know the results when you run it...
Old 01-04-2011, 03:12 AM   #12477
alcyon's Avatar
Originally Posted by BCbud View Post
Good day!
wow, that is about 50 -50 front rear !
Old 01-04-2011, 04:01 AM   #12478
Trader Rating: 25 (100%+)
That fan position is pretty sweet. I may have to give that a try!
jonnymorrow is offline   Reply With Quote
Old 01-04-2011, 02:34 PM   #12479
Hey does anyone know of a cool, cheapo solution for braces that keep a lipo from sliding side to side when positioned across the back?
Old 01-04-2011, 04:42 PM   #12480
BCbud's Avatar
When I had mine across the back I put velcrow on the battery and under the battery straps.
Recycled teenager.
