Old 10-12-2010, 08:10 AM   #12421
jeff jenkins's Avatar
Trader Rating: 77 (100%+)
I have boat loads of fko4/fko5 parts if anyone is interested pm me ! i would like to get rid of them.
Maclan Racing Products-Bellgate Distributions-PR Racing- Prospeed
jeff jenkins is offline   Reply With Quote
Old 10-12-2010, 08:30 AM   #12422
angry-alien's Avatar
Nice... I will contact you soon enough... now.. do you guys have setup sheets for these cars? meaning, recorded setups that you are currently running with packs mounted
across the chassis and with a similar suspension setup as mine...
Alien
Gorillakev, see the below pic for shimmed battery hold down post:
angry-alien is offline   Reply With Quote
Old 10-12-2010, 07:25 PM   #12423
Alien
nice was the lipo rubbing on the belt..i got the t1fk that im currently rebuilding and upgrading all the electrics wasnt sure if you had to do a major mod to get lipos to fit...
gorillakev is offline   Reply With Quote
Old 10-12-2010, 07:26 PM   #12424
pm me a parts list...
Old 10-12-2010, 08:53 PM   #12425
Oh... I forgot to answer that part of the question... for the first test the battery was located closer to the back posts... the clearance was fine... no rubbing... then I move it closer to the front posts to get the batt closer to the car's CG... there was quite a bit of rubbing in this position when the belt was spun up to full speed.... the tensioner is located on the lower chassis plate pushing the belt up and over the batt... it seems though that the belt tension from the front diff hub was a little low... so when the belt got to full speed, it would bounce around and make contact with the battery... to fix this, I increased the belt tension from the diff hub, then I raised the upper deck by adding shims (1mm) between it and the rear bulk heads... this is to reduce the chance of the lower belt loop from striking the upper deck... seems to work well so far...
Alien
Old 10-12-2010, 08:54 PM   #12426
Send me this list also...
Old 10-14-2010, 08:06 AM   #12427
So no one with suspension tips or advise?
Alien
Old 10-14-2010, 12:02 PM   #12428
parts have already sold!
Old 10-14-2010, 08:09 PM   #12429
damn that was quick
Old 10-14-2010, 08:16 PM   #12430
hmmmm.... that was quick... i guess this car and its parts are still demand
Old 10-14-2010, 08:21 PM   #12431
BCbud's Avatar
Trader Rating: 37 (100%+)
Good day!
I bought them, I sent a PM as soon as I saw the add. I ran my FK04 all last season and there is 4 other drivers in my club that have them so the parts will be put to good use. I hope to keep it going for a long time.
Xray NT1 - Xray T4 2013 TC - Xray T4 2013 VTA - CRCgenX10 - CRCgenX - CRCgenXi - Slash 4X4 with LCG conversion -Associated RC8Be - Xray XB4 - DX3R PRO
Recycled teenager.
www.irocc.ca ; www.corvictoria.com ; http://www.wcics.ca/
I will not send Pay Pal as a gift or add fees to the price so DO NOT ASK!
BCbud is offline   Reply With Quote
Old 10-14-2010, 08:29 PM   #12432
BCbud's Avatar
Alien
I worked on mine all season and with the battery position chainge and going from a GTB to a Tekin RS, I never got it to where I wanted it. I was getting close at the end of the season but the last 3 races were rained out. There are so many vareables that all I can recomend is to read the setup guide and try one thing at a time. That is what I have been doing and why it is taking so long but the final result will be a car tuned to your driving and track.
Recycled teenager.
Old 10-14-2010, 08:38 PM   #12433
BCbud's Avatar
Alien
I had a setup just like that but after several recomidations from other drivers, I compleatly removed the tensioner. Having the tensioner where you have it now is about the worst place it could be. The bottom side of the belt is where it gets tight under acceleration and will cause the most wear and friction. Now that I have removed mine I run my belts as loss as posible without it scipping and yes, you may eat a belt trying to get that right. I did in a rear belt on my car but now it is perfect.
Recycled teenager.
Old 10-14-2010, 08:45 PM   #12434
Wow... thanks for the heads up on the belt man... I'll be making some changes tonight...
Old 10-22-2010, 12:23 AM   #12435
Any one have any extra pulleys for sale???
