Old 09-01-2009, 04:58 AM   #12361
asw7576's Avatar
I have bunch of Xray T1 Factory Kit spare parts, and most of them are still brand new in plastic.
lower bumpers, suspension arms, alumunium bulkheads, 3.3mm main chassis, universals cvd, wheel hex adapter, front one way, rear diff unit, front &uprights, steering knuckles.
PM me. I want to sell them.
Old 09-01-2009, 06:18 PM   #12362
Send a message via Yahoo to nomaak
Default parts
@t GEEZ: hey thanks for the tip. ya i found all the parts there but the steering knuckles. what i did find were the ones for the nitro car. i wonder if they're the same thing just different part #'s.
nomaak is offline   Reply With Quote
Old 09-01-2009, 10:52 PM   #12363
I'm pretty sure they are not. In fact be very careful when buying the T1 pivot ball front suspension parts as there was a design change between the original issue and the later EVO2. Some of the parts are not interchangeable without changing other things including the drive shafts and hubs. It can get very expensive, even if you could find the parts. Use the part numbers supplied with your kit. I'd be willing to bet that most of the available parts are for the later model and I'm pretty sure the car pictured on the last few pages is the original issue T1 that came out around December 2001. That doesn't mean that it hasn't been upgraded, but I doubt it as it really looks bone stock. The C-Hub upgrade kit Part # 300921 brings everything up to the newer suspension design in one package and will also allow you to use the later pivot ball parts. Pivot ball parts are getting much harder to find. In fact the last time I looked, Stormer's inventory did not have everything to completely replace a T1 pivot ball front suspension.
calvin is offline   Reply With Quote
Old 09-02-2009, 01:40 AM   #12364
some87's Avatar
Trader Rating: 16 (100%+)
anybody know if somebody still sells the hudy starburst wheels?
some87 is offline   Reply With Quote
Old 09-02-2009, 06:37 PM   #12365
evanwest94's Avatar
Send a message via AIM to evanwest94
what is a good ride height for this car, right now i have it a 5mm
http://unclefrankensteinsrctools.yolasite.com/
--------LOOK AT MY TING-TING!!!----------
evanwest94 is offline   Reply With Quote
Old 09-04-2009, 08:46 PM   #12366
evanwest94's Avatar
Nice Right
Old 09-04-2009, 09:04 PM   #12367
Geezatec's Avatar
5mm the minimum with rubber tires.
Nice Right
Excessive toe-in on Rear!!
Geezatec is offline   Reply With Quote
Old 09-04-2009, 09:06 PM   #12368
evanwest94's Avatar
its just my camera angles
Old 09-04-2009, 10:48 PM   #12369
Geezatec's Avatar
Hmmmmm!!Funny!!! all four photos show the same rhing. Excessive toe-in!!! Take another photo, of top view, than I'll blame the cheap camera!! lol!!JK!
What size tire you useing? 24mm or 26mm?
Old 09-04-2009, 11:39 PM   #12370
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
Why is it excessive? I run 3-4* (which looks to be about what he has) rear toe at my local carpet track, along with everyone else running 13.5 rubber. His tires look like super-hard compound drift tires, and a lot of rear toe may be the hot ticket for a drift setup. Just because it is more than you are used to running doesn't make it "excessive"
-rocky b
flatspunout is offline   Reply With Quote
Old 09-05-2009, 12:24 AM   #12371
Geezatec's Avatar
-rocky b
Don't have much time to say right now, cuz I'm at the Indoor Championship in Las Vegas. No one here is running more then 1 degree of toe-in. Toe-in is generally used for direction of steering(Straight) the car. Also less friction for car to run, less wear on tires. Whick ever you run, adjust to where the car run to accomodate your type of driving. Drifting, I'd rather set toe-in at 0 degrees. Lots of kit come with exccessive toe-in and may not be adjustable. But try this, Change the lower A-arms position, by reinstall lower arm left to right. Lengthening the ball joints may look uneven. Changing the lower arm will bring to 0 degrees of toe-in. Then it will be adjusted by ball joints.
Won't be back till after Labor Day weekend. After International Indoor Championship in Las Vegas.
Have A Safe Weekend!!!
Old 09-05-2009, 02:05 PM   #12372
bucknuts's Avatar
One of the things I've found with this car to make it go longer is that the drive shafts are easily salvaged by bending them straight again. I also added steering stops using the three hole hubs by attaching a 3mm spacer and screw into the third hole on the bottom, because when you hit something the hub turns and bend the shaft by the hub. I'll take a pic of my straightening device later. You can't do this with Aluminum shafts!!
bucknuts is offline   Reply With Quote
Old 09-06-2009, 06:06 PM   #12373
evanwest94's Avatar
http://www.rctech.net/forum/r-c-item...taba-more.html
you might find something you like
Old 09-11-2009, 09:33 PM   #12374
evanwest94's Avatar
http://www.rctech.net/forum/r-c-item...ml#post6332724
Old 09-12-2009, 02:14 PM   #12375
evanwest94's Avatar
$150 takes it
