Old 01-03-2009, 08:57 PM   #12196
chris moore's Avatar
Trader Rating: 88 (99%+)
Originally Posted by flatspunout View Post
I race in a parking lot series that also includes nitro sedan and Inferno GT's, so the layouts are fairly large and open (usual layout is 180x90), so I don't think it really hurts the car's performance. It actually makes for a car that is easy to be fast with, especially in 27T/13.5T classes where momentum is so important and where smooth is fast. A faster, digital servo *will* be my next upgrade though, and then lipo once someone makes an SMC-sized saddle pack with bullet connectors
-rocky b
With all the races you've won I dont think you need to worry about a new servo.
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 01-03-2009, 09:14 PM   #12197
flatspunout's Avatar
Location: Somewhere between raising hell and Amazing Grace
Trader Rating: 38 (100%+)
I know right! You'd think the manufacturers would be piling them up at my front door!!
-rocky b
flatspunout is offline   Reply With Quote
Old 01-04-2009, 01:21 PM   #12198
minittrackmann's Avatar
I officially wanna give upon these shocks. They are the worst shocks I have ever worked on, lol. IDK what it is. Its not even like I am doing a full rebuild, just wanna try different weights. Everytime, I drain te Shaft, and put the new weight in it is fine. But then when I go to rebuild it, the collar that lets you adjsut ride height never wants to go back on. The shock is not stripped or anything. WEIRD!.
Cody
minittrackmann is offline   Reply With Quote
Old 01-04-2009, 01:49 PM   #12199
blast's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to blast
Cody
i always ran with 30 weight oil only time i changed weight of oil is foam carpet. they are great shocks u just have to know what you are doing and take the time to do it right.
Patrick Connors
FTM Grip
You're not fast if you don't have the grip
A Master key can open any lock, but a lock that can be open by any key is an sloppy lock.
blast is offline   Reply With Quote
Old 01-04-2009, 01:51 PM   #12200
Wow, So Icould have left them alone. lol.
I was going to run 30weight
Cody
Old 01-04-2009, 02:05 PM   #12201
blast's Avatar
Cody
yea that's pretty basic for Xray 30 weight oil.
Patrick Connors
FTM Grip
Old 01-04-2009, 09:30 PM   #12202
Cody I would suggest starting with 40 wt all around, with 2 or 3 hole pistons. You said your track was just repaved with tennis court asphalt, so I'm sure it is billiard table smooth, and you are running 19T so it won't hurt to keep the car a little flatter in the corners. Search for "shock bleeding" or "shock rebuild" or something along those lines on the XRay forums...there is a tutorial there that is 4 or 5 pages long and takes you step by step how to build the perfect shock (I could do the same thing for my nitro buggy shocks in about 5 sentences ). The trick is in the bleeding and "communicating effectively" with the purple o-ring. There is also a great tip for threading the caps and collars...set in on the threads and turn in counter-clockwise until you hear a click and feel the cap/collar flatten out, *then* turn clockwise to tighten it. Did you get your track measurements yet or is there a website?
-rocky b
Old 01-04-2009, 10:57 PM   #12203
jlfx I'm digging the VTA FK04...what lipo did you find that would fit between the bulkheads? Love the pics!
-rocky b
Old 01-04-2009, 11:23 PM   #12204
hi im just new to rc and just recently picked up a used t1fk04. i just found out right now that its so hard to find parts for this car. so where do you guys buy parts? i need the chassis i know i can use any chassis from any t1 series but i really like the one from fk04. any help?
boybawang is offline   Reply With Quote
Old 01-05-2009, 12:22 AM   #12205
Stormer Hobbies, The RC Shack, and Ampdraw Hobbies have a pretty good selection of T1 parts...new chassis are expensive everywhere I have found them though. For the 80 or 90 bucks a new chassis costs you can buy another roller. Which one do you have and which one do you need? I have a couple of carpet chassis I would be willing to part with if that is what you will be running on and I'll make you a smokin deal. Also, the T1 FK05 chassis will not fit; T1 Evo, Evo2, and FK04 will. Now let's see pics
-rocky b
edit: the composite (plastic) chassis is 30 bucks...not a bad deal if you are racing on asphalt or just bashing around.
Old 01-05-2009, 05:35 AM   #12206
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
-rocky b
well the pack is a reedy 5000 i did have to sand the ends 1/2" across to get it to go between the uprites but that is ok cause the case is 3/8" longer than the cells and i filled the holes in with epoxy putty to add weight and fill in the holes i just used a belt sander and did it little @ a time and actualy 1/8" on each side was alittle mutch
jlfx car audio is offline   Reply With Quote
Old 01-05-2009, 01:51 PM   #12207
I don't have measurements but here is a video of the 19 turn class.
http://www.youtube.com/watch?v=61wL2Eq3qUk
It is a pretty large track.
Since it was just repaved, there is already a ton of traction. Would this shock setup work you think?
40 weight all around
White springs in the rear, and purple up front?
cody
Old 01-05-2009, 03:13 PM   #12208
Here is a nice generic starting setup sheet for the early generation T1's. I changed a couple of things as I run on a low traction p-lot but this should get you in the ballpark.
http://www.teamxray.com/teamxray/sho...p?file_id=1013
Sponsered by:
Old 01-05-2009, 08:09 PM   #12209
Smile
-rocky b
its the fk04 version and i would like to buy another chassis cause mine has cracks in the front. sorry no pics for now since i am rebuilding the car and wont be finished till the aluminum suspension gets here (its on its way) ill post pics asap when its done.
i want the stock fk04 chassis in particular (same chassis i have now), i guess the one you have is different. do you have pics?
Old 01-05-2009, 08:19 PM   #12210
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
