Old 07-22-2007, 03:36 AM   #12076
PINKIE's Avatar
no1 runs these anymore?
looks to be mega dead
- RATED X RACING - worlds ahead
XRAY - LRP - NOVAK - FERRAL BATTERIES
PINKIE is offline   Reply With Quote
Old 07-22-2007, 09:01 AM   #12077
Default crashed my t1
I run one, but i can't get the setup right. I use the pivot ball suspension, and I'm not happy with the geometry. besides that, I demolished my front drive axle because of radio interference. always nice...
does anybody have a spare one for sale? since there is no factory supply anymore..
Govert is offline   Reply With Quote
Old 07-22-2007, 09:51 AM   #12078
pole_position's Avatar
Originally Posted by PINKIE View Post
how are you guys traying your cells? the only way i can do it is to do 3 at a time as my cable is to short..now the obvious answer is to make it longer but i dont wanto do that.
secondly i am thinking of running the batties down the side for ease of traying and storage does anybody know of what diong this might do to my handeling? im warried about it as my main problem with the car is getting it to handel as it changes all the time for some reason
any info would be greatly appreaciated as ill be going brushless soon and i think ill be needing to tray my cells every time instead of once ina while when i have time lol
Hi,
If you are keen, refer to this post:
http://www.rctech.net/forum/showpost...5&postcount=40
Hope it helps.
Btw, I had retired my T1 and replaced with a TA05R now in view of the scarcity of parts & support now as the product had been EOL, End Of Life... and Xrays parts are damn Xpensive!!!
Too bad... life goes on...
pole_position is offline   Reply With Quote
Old 07-22-2007, 09:57 AM   #12079
Likewise I shared that same thoughts as you on the pivot ball suspension. Mine could not hold on to the camber angle well and had to readjusted after every run due to wear & tear... what a waste to a great car!
Old 07-22-2007, 09:19 PM   #12080
Default Pivot Ball hardware
Hey guys. I've got some T1 Pivot Ball hardware, pivot balls, the plastic hold down, hinge pin holders, etc. basically everything BUT the plastic arms (upper and lower)front, and steering blocks. Let me know if you're interested.
Electro-MAX RC is offline   Reply With Quote
Old 07-23-2007, 02:50 AM   #12081
PINKIE's Avatar
pivot ball suspension was only used on the evo series t1's and was never used again for on good reason. it sux
it you can get your hands on some then buy a full c hub set. youll be much happier
parts are no problem for me as ive aquired over the years about 5 full cars worth of parts and all i ever break are the bumper tops
Old 07-23-2007, 09:37 AM   #12082
Thanks!
The C hub conversion kit cost a bomb! That is why I retired my T1...
Old 09-04-2007, 05:49 AM   #12083
Default T1R ratios and diff pullys
Hi does anyone know off-hand if the T1 diffs at 2.125 ratio have 34 or 32 teeth pulleys in the diff. It would just save me pulling them out to check.
yellowshark is offline   Reply With Quote
Old 09-04-2007, 07:31 AM   #12084
Wolf's Avatar
Send a message via ICQ to Wolf
should be 34 teeth for 2.125 internal ratio (34/16)
Wolf is offline   Reply With Quote
Old 01-19-2008, 09:45 PM   #12085
Moderator
roadrashracing's Avatar
Trader Rating: 76 (100%+)
I am looking for a rubber tire carpet setup for a t1r.
roadrashracing is offline   Reply With Quote
Old 01-20-2008, 08:33 PM   #12086
Moderator
can anyone help????
Old 01-20-2008, 09:00 PM   #12087
RedRocketRacing's Avatar
http://www.teamxray.com/teamxray/pro...AY%20T1%20EVO2
There are a few here.
RedRocket
Still have alot ot parts for the FK cars, both the 04 and the 05 If anybody needs them.
RedRocketRacing is offline   Reply With Quote
Old 01-22-2008, 05:54 AM   #12088
Trader Rating: 3 (80%+)
anyone have any t1 parts that want to give them away for free or cheap? Im building a battlebot type oval racer monster.
242speedster is offline   Reply With Quote
Old 01-22-2008, 11:57 AM   #12089
Branden Moody's Avatar
PM redrocketracing he had a lot of parts from the local track closed.
Branden Moody is offline   Reply With Quote
Old 01-22-2008, 12:02 PM   #12090
PM me an email address and I will send you my list of parts.
Red Rocket
