Old 07-20-2005, 04:50 PM   #11911
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
Thumbs down
is there a trick for threading ballcups onto turnbucles? or are they going to be a " " regardless?
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 07-20-2005, 04:53 PM   #11912
Kennedy's Avatar
Location: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
I put a self tappign screw in the turnbuckle first(with a screwdriver) and then took it out. It makes it much easier
Kennedy is offline   Reply With Quote
Old 07-20-2005, 04:56 PM   #11913
rdub202's Avatar
so like pre-threading it basically?
Old 07-20-2005, 04:59 PM   #11914
Kennedy's Avatar
Yes and no. The x-ray screw can't use the same thread coz one is a self tapper and one is a machone thread but it does open the hole to make it easier. Just don't use a self tapper thats too thick.
Old 07-20-2005, 05:00 PM   #11915
rdub202's Avatar
okay ill try that
thanks
Old 07-20-2005, 05:14 PM   #11916
jw92656's Avatar
Smile
Use a bolt from your X-Ray kit, and thread it in two to three times. Use some bar soap as a lubricant on the threads, as this will help make it a little easier.
jw92656 is offline   Reply With Quote
Old 07-20-2005, 05:18 PM   #11917
jw92656's Avatar
Smile
Ooops. Forgot to mention, make sure it's the same size as the shaft threads.
Old 07-20-2005, 05:50 PM   #11918
rdub202's Avatar
yea seems like it will need it like 2 or 3 cuz i was having no luck just now,
Old 07-20-2005, 06:30 PM   #11919
jw92656's Avatar
Yeah I hated those shock ends until a friend of mine mentioned the bolt/soap trick. It was still a little tough, but I was going nowhere in the beginning. Hope it helps :-)
Old 07-20-2005, 07:03 PM   #11920
rdub202's Avatar
Angry
so now i need to find the pices cuz i quit and i just chucked them across the room
they arent working and i give up!
Old 07-21-2005, 07:57 AM   #11921
teamgp's Avatar
I hold the turnbuckle in one hand with the little wrench attached and braced against my finger. Then I screw the end on until it gets too hard to force it with my hands. And finally I grab the end with a set of pliers and finish tightening it down.
I only pre-thread the shock ball ends.
teamgp is offline   Reply With Quote
Old 07-21-2005, 10:11 AM   #11922
rdub202's Avatar
yea the lack of turnbuckle wrench is kinda hurtin me but i just clamp on them with pliers and if i could get the end started a little i used a wrench to tighten it on but i cant even get them started and im quite upset
Old 07-21-2005, 10:19 AM   #11923
Thraex's Avatar
I always put the turnbuckle in a vice, then put a screwdriver through the ball cup hole and turn it.
For me that's the easiest way to make them, it's fast and you don't scratch anything.
Thijs van M[HPI/HB]
Thraex is offline   Reply With Quote
Old 07-21-2005, 12:07 PM   #11924
NVisible's Avatar
a little tip i read was to use your reamer on them, just a little. Then go ahead and put them together. makes adjustment a little easier
NVisible is offline   Reply With Quote
Old 07-21-2005, 09:07 PM   #11925
cheehtae's Avatar
Trader Rating: 15 (100%+)
Default FK04 front shock tower
Hey guys I need some help, will the FKo4 front shock tower fit the T1 Raycers bulkhead?
LMK and all the help I can get will be greatly appreciated/
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
