Old 06-21-2005, 12:00 AM   #11866
war11x's Avatar
Trader Rating: 17 (100%+)
Originally Posted by NVisible
so you guys are telling me you have no movement in your front steering knuckles?
also, my balls, they are ze tight! so i dont know that its them
yep
mine where tight then 4 kids later
They are pretty loose now
Really
i have had no slop at all in any of my 3 Xrays , i would think you may have a worn out component in the steering
as for your balls being tight take them out of the car and pull the seal of , then spray a heap of cleaner or the likes in them and spin them until they lossen up , re oil them with full synthetic oil or sim and reinstall
this should help
war11x is offline   Reply With Quote
Old 06-21-2005, 10:00 AM   #11867
teamgp's Avatar
Originally Posted by Jayjp
Thanks for the help, but I need a asphalt setup. The first setup looks pretty close to what I am running now.
Jayjp, I ran rubber on asphalt for the first time last weekend and took 3rd in the A main. My car was faster than the results suggest, but my driving was off. The car was very balanced and I had more grip than all but the leader. Here's the setup:
http://www.teamxray.com/xforum/xform...7&setup=t1fk05
If using my setup on an FK04 or EVO I'd suggest taking out the anti-dive and running both front pin holders in the middle holes, as well as running both rear pin holders in the middle or upper holes. This is due to the fact that the FK05 is front heavy and the FK04/EVO are slightly rear heavy if both saddle packs are in the rear slots.
teamgp is offline   Reply With Quote
Old 06-21-2005, 10:08 AM   #11868
Jayjp's Avatar
Send a message via AIM to Jayjp
Thank you! I will give that a try
Jayjp is offline   Reply With Quote
Old 06-21-2005, 10:50 AM   #11869
teamgp's Avatar
BTW, If you're using Xray oil, put 30wt in all shocks with 3 holes open in front & 4 holes open in rear.
Old 06-27-2005, 01:24 PM   #11870
cheehtae's Avatar
Trader Rating: 15 (100%+)
Default chassis question
I just bought a Tc4 TC and battery config. is side by side and I also have a T1 raycer , My question is is there a chassis that I can buy for my T1 that uses a side by side config?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 07-11-2005, 05:42 PM   #11871
I recently bought an Xray Evo2 FOC car, and I was taking it apart and reassembling when I noticed something. Right now I've got the C-Hub suspension on it and that is what I plan on running. I noticed that the guy I bought it off of was running his a-arms on the outside of the bulkheads (see pic).When I look in the manual, it shows them on the inside. The shafts seem like they'd be to long if the a-arm was on the inside. Any ideas?
Altrodesigns is offline   Reply With Quote
Old 07-11-2005, 05:55 PM   #11872
Tom
Tom's Avatar
The FOC came with long suspension, and yours has been upgraded to short suspension found on the FK04 and FK05. So you might want to download to FK04 manual if unsure.
Tom is offline   Reply With Quote
Old 07-11-2005, 06:01 PM   #11873
Thanks!
Old 07-11-2005, 07:06 PM   #11874
edseb's Avatar
It depends on what kind of 19t. Reedy quads are rpm based, C2s are torque based. I've found 5.8-6.2 depending on motor and size of track. These motors have a sweet spot, so you need to be in that range. I use 767 brushes and go purple +, green or red -. Cut it every run. Others have ideas too. "Lickrim" uses Reedy quad mags and gears around 6.0. He uses black springs on pos side, 766s with 10-15 min break-in, cut every run and use same brushes all day for club racing and 767s for big races. For mod, on V2, go about 12 degrees of timing, hard springs, sprint brushes, and gear about 8.8-9.0, same gearing and timing for Reedy PT although if you use single wire you can go up on timing, but that's by feel. For mod I'm assuming you mean motors 10t and below.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 07-11-2005, 07:07 PM   #11875
edseb's Avatar
Originally Posted by tom235
i just got a t1 a little bit a go its used and im trying to find a go gearing 48 pitch or 64 . what is a go starting point for a 120ft straight, pretty tight
motor is 19t
Oops. That response was for those questions.
Carl Hyndman
Old 07-11-2005, 08:25 PM   #11876
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
okay so im putting my T1 together and i got the c hub conversion kit, right away i see a problem before i even start,
step 1-thread a downstop adjustment screw into the front lower arm.....
and where am i supposed to get these from
do i have to buy ANOTHER part
i already threaded them into the original arm from the KIT kit and i cant get those out so do i have to buy a set of these (309358, 309354, 309351) downstip adjusters??? cuz i REALLY dont want to
they arent anywhere in the conversion kit and like i said i used the ones that came with the car kit
thanks
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 07-11-2005, 08:45 PM   #11877
edseb's Avatar
Why can't you use the old ones? I guess if they are unable to reuse, you might have to replace them with another part just like anything else. If you replace the hub and the bearing is blown, you have to replace that too.
Carl Hyndman
Old 07-11-2005, 09:04 PM   #11878
rdub202's Avatar
well the part itself makes its own thread, you are threading it into the part and i guess its just in there good and i cant get it out, maybe ill keep trying that and might just have to buy the pieces. what do they do anyways, are they stoppers to the suspension doesnt like over "suspend" lol?
Old 07-11-2005, 09:51 PM   #11879
edseb's Avatar
If I'm following you right, you're talking about the droop screw in the a-arm. It is used for adjusting droop on your suspension. It is a big tuning feature.
Carl Hyndman
Old 07-11-2005, 10:01 PM   #11880
rdub202's Avatar
grrr
hm alright ill guess ill have to see if i can get them out or just buy the suckers!
