Old 06-14-2005, 11:15 PM   #11851
Deves's Avatar
Tom try a 6.5-6.8 somewhere in there
Deves is offline   Reply With Quote
Old 06-15-2005, 11:56 AM   #11852
tom235's Avatar
thanks Deves whould you run a mod around 7.60-7.90 or 7.3-7.06
tom235 is offline   Reply With Quote
Old 06-15-2005, 12:49 PM   #11853
Deves's Avatar
I just started running 19T so am not familar yet with mod gear ratios
Old 06-16-2005, 12:30 AM   #11854
MarkBrown's Avatar
Originally Posted by Pezz
Ok just got my FK05 kit, took a little while to get here. I was wondering about the multi diff. I was looking around and it looks like I can buy a one way diff for about half the price as the multi diff, and since all I use is a one way or ball diff should I skip the multi diff all together?
-B
If you are desperate to save money you could buy the spool and run that. The basic handling of the 05 is aggressive and the one-way will be too much except when traction is super high. Even then you might rather run the spool. The car feels so planted with the spool.
But the multi-diff, configured as a spool, is a stronger spool than the old alu one, so in the long run you are better off with the multi-diff.
MarkBrown is offline   Reply With Quote
Old 06-16-2005, 10:13 AM   #11855
Jayjp's Avatar
Send a message via AIM to Jayjp
I'm sure this has been asked a thousand times, but.....
Does anyone have a good setup for asphalt with foams?
I have looked at both Mytsn.com and Myrcworld.com, but I can only find setups with rubbers.
If you can please let me know what chassis you are running, I have them all
(XRC, BMI 350, stock). Thanks!
Jayjp is offline   Reply With Quote
Old 06-16-2005, 10:48 AM   #11856
tom235's Avatar
check teamxray.com
Old 06-16-2005, 11:01 AM   #11857
Jayjp's Avatar
Same problem there, only rubber tire setups (that I could find). Almost everything on that site now is for the '05.
Old 06-16-2005, 11:31 AM   #11858
teamgp's Avatar
Go to:
http://www.teamxray.com/xforum/xsheets-search.php
Select "foam tires" and do the search. you'll find 10+ setups. All except the one I labelled "FK04..." are for the FK05. Not sure which model your running though.
teamgp is offline   Reply With Quote
Old 06-16-2005, 12:07 PM   #11859
Jayjp's Avatar
Sorry, I am running the FK '04.
The problem there is I only get the option for the '05.
Old 06-16-2005, 12:45 PM   #11860
teamgp's Avatar
Yep. But I'm the only one who bucked the system and put my 04 setup in as an "05" setup and specified it as an 04 setup in the title. I used the notes section to explain a few things that are specific to an 04 setup, such as saddlepack placement. Take a look.
Old 06-16-2005, 01:25 PM   #11861
Jayjp's Avatar
Thanks for the help, but I need a asphalt setup. The first setup looks pretty close to what I am running now.
Old 06-16-2005, 02:06 PM   #11862
NOTFASTENOUGH's Avatar
Trader Rating: 24 (100%+)
What is the evo2 like compared to the 05'?
NOTFASTENOUGH is offline   Reply With Quote
Old 06-16-2005, 02:20 PM   #11863
jtveten's Avatar
Default foams on asphalt?
You don't see any setups for foams on asphalt cause you don't run foams on asphalt for 1/10 tc. It's bad enough they run it, (only in North America), on carpet.
jtveten is offline   Reply With Quote
Old 06-16-2005, 02:48 PM   #11864
Jayjp's Avatar
Well the 2 clubs around here BOTH race 1/10th tc on foams, if there are enough we will run rubber, but it is both expensive and slow to do that.
Anywhooo....if someone actually has a setup that they want to share please PM me
Old 06-16-2005, 02:55 PM   #11865
jtveten's Avatar
Default Foams cost less?
Most everyones experience is, foams are more expensive to run competively than rubber, unless you have a foam sponsorship.
Pops
