Old 05-06-2005, 12:16 AM   #11806
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
seems to me you have a problem with turn-in.
try:
-using 2 deg rear toe-in
-do you use swaybars? if yes use a thicker rear bar; if no then use it
-adding more dual rate (on your radio)
-add more rear droop (numerically lower on a droop guage)
-use a mazda 6 body
-rebuld your shocks
S-T-R-l-K-E-R is offline   Reply With Quote
Old 05-06-2005, 03:23 AM   #11807
Stealthy Ninja's Avatar
I went shopping today and there was a Xray T1FK04 that some guy build and was selling second hand, apparently this guy has 4 FK04s at home. He built this one and never used it. It has a XRC chassis and wide upper deck as well as Hudy spring steel outdrives and a one way fitted. It is so new the battery foam wasn't even dented...
So I bought it. It cost $1500 HKD, which is 148.65 Euros or $192.497 USD. It is half what a FK04 kit would cost here new, but mine has the XRC and Wide upper deck etc.
I think this was the best way for me to go, because I already have spare parts etc.
I've attached a picture here. Sorry about the quality...it is from my mobile phone.
http://www.rctech.net/forum/attachme...postid=1567890
Stealthy Ninja is offline   Reply With Quote
Old 05-06-2005, 03:47 AM   #11808
VenomWorldOrder's Avatar
Originally posted by asw7576
Guys.... I need your advice :
My T1FK is very slow during mid corner entry. Even tamiya TT-01 with silver can is able to match the entry cornering speed
If I enter corner too fast, the car have tendency to go wide losing my racing line.
If I immediately push the gas ( don't let the car behind me to pass ) the car could easily spin.
I need more speed at every corner entrance.
What necessary tips should I consider ? Just give me the tips and I'll check the possibilities of each tips. Thanks guys.
ok, go back to base EVERYTHING SETUP and try doing this following change to the setup. i am running mod and this has allowed me to enter corners very fast: with the rear arms put the rwo arm screws closest to the bumper at the highest position and the ones right at the back holding the arms right at the bottom.
VenomWorldOrder is offline   Reply With Quote
Old 05-06-2005, 04:40 AM   #11809
NVisible's Avatar
try:
-use a mazda 6 body
-rebuld your shocks
Indeed! try some more uptravel in the rear to allow your car to roll more. you could move to a stiffer spring back there, and possibly lay your shocks down a hole or two. I had a similar problem on carpet and that helped me
NVisible is offline   Reply With Quote
Old 05-06-2005, 03:34 PM   #11810
Send a message via AIM to greencactus3
and are you using decent tires?
greencactus3 is offline   Reply With Quote
Old 05-06-2005, 04:34 PM   #11811
They say if you get the tyres right you are most of the way there...etc.
Old 05-06-2005, 11:40 PM   #11812
new92's Avatar
I just picked up an FK04 chassis, battery straps, and topdeck for my T1R.
I know I need the bearing holders for the servo saver. Anything else?
I was going to download the FK manual tomorrow and go through it but if anyone knows offhand any other items it could really help me out.
new92 is offline   Reply With Quote
Old 05-06-2005, 11:50 PM   #11813
T1Raycer's Avatar
not really i did the same thing whit my T1R but i bougth the aluminium Servo Mount because there are more durable and look better than the plastic one!!!
Later
T1Raycer is offline   Reply With Quote
Old 05-07-2005, 01:44 AM   #11814
Default Spin out in corner on gas
If you have a "normal" set up on the car already, and If you are spinning out, you have a tweak or broken/bent parts.
Post your full set up after you check for the above.
Also tires are very important, are you using tires that are good and the right type for the temperature? Are you on asphault/ Carpet? Foam or rubber tires?
Charles is offline   Reply With Quote
Old 05-07-2005, 02:22 AM   #11815
asw7576's Avatar
Ok, I'll test each one of your tips.
I have big race ( modified ) on 24th of May at circuit designated for engine cars ( very long straight, sweeper corners, wide radius corners, medium to high bite tarmacs ).
Some Xrays T1 drivers have slow corner entry problems against TRF 415MS and MR4TC SDW, so your advice means a lot to us. Thanks.
Old 05-07-2005, 11:05 AM   #11816
new92's Avatar
I dont trust my fabrication skills for long term durabilities lol.
Anyone have an extra antennae holder #306300 they could part with?
rcshack doesnt have it listed and I dont have one since I am converting from a T1R.
Old 05-11-2005, 03:58 PM   #11817
jw92656's Avatar
Smile
I am running a 19T Quad, and have the same problem with the rear coming around if I punch it mid corner. I actually went through my owners manual for my Losi BK2; as there are some great tips at the back concerning setups. I am going to use the outside hole on my rear hub vs the inner. This should stiffen the rear end up. Might be worth a try ?
jw92656 is offline   Reply With Quote
Old 05-11-2005, 04:40 PM   #11818
JDXray's Avatar
Send a message via AIM to JDXray
If the rear of the car is pushing out and around. Try:
Less Dampening in rear
Increase Front Dampening (Or keep it the same)
Change Pistons if needed
Softer Spring in the rear
Harder in the front
JDXray is offline   Reply With Quote
Old 05-11-2005, 06:29 PM   #11819
to get more on-power steering:
decrease rear toe-in
lower front roll center
i foundout that xray cars respond well to swaybars- use a thicker rear swaybar
Old 05-12-2005, 03:49 PM   #11820
NVisible's Avatar
Default WD 40
I have some really tight screws on my BMI Chassis, and am wondering if i should lay down some wd40 to try and loosen them up a bit. As you may know, the BMI 350 chassis has some knock-outs that leaves the CF unprotected. Im wondering if WD40 will do anything to negative to the chassis. Also, are there any other methods to get the screws out of the bulkheads? i dont really want to dremel the suckers out, as hacking this chassis isnt an option, and the screws arent stripped... yet :\
