Old 04-13-2005, 08:25 PM   #11731
JDXray's Avatar
Send a message via AIM to JDXray
Originally posted by NVisible
yea i had read that in there, seems pretty damned tight though. should i be doing this with my hands or a tool?
in the stock box they give you a little tool that pops the inserts out.
JDXray is offline   Reply With Quote
Old 04-13-2005, 08:27 PM   #11732
NVisible's Avatar
hehe, well i dont have that, i figured i had to be missing something.
Thanks man, ill see if i can find one somewhere
NVisible is offline   Reply With Quote
Old 04-13-2005, 08:28 PM   #11733
JDXray's Avatar
If not i am sure you can just take pliers and pull off the insert.
Old 04-13-2005, 08:36 PM   #11734
NVisible's Avatar
cool, thanks again man.
Old 04-13-2005, 08:48 PM   #11735
Oasis's Avatar
Trader Rating: 36 (100%+)
I have Run the short arms on the T1R,For a tight track i thought they worked great,All you need is the A arms,Rear # 303159,Front # 302159,You also need to change the mounts,they move from the inside to the outside on the bulkheads,and the alum. holders(cant think of the right name)It's not alot of money and it's very easy to do..I thought it made the car alot better.
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 04-14-2005, 06:30 AM   #11736
kt racing's Avatar
Send a message via AIM to kt racing
Does anyone know Team TAMOLLY's website address?
kt racing is offline   Reply With Quote
Old 04-14-2005, 06:32 AM   #11737
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
team tamale?
if so its www.teamtamale.com but its not working for me at school so im not sure
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 04-14-2005, 07:31 AM   #11738
JDXray's Avatar
Default Rear Shocks
Anyone try running those rear shocks on the otherside of the shock tower? I tried it last saturday but i really didnt have time to sit there and fiddle with it.
I got 2 runs with it and it seemed okay, i think my shock setup is alittle too stiff and my dampening as well. So i changed that. I was originally running 50wt all around with 1 hole front and 3 rear with purple and violet i think.
I went to 40wt front 1 hole (might try 2) and 30wt rear with 3 holes open still. Going to try one step softer around or just run violets all around maybe.
Anyone notice a tweak int the chassis when the shocks are mounted like that?
Jon
Old 04-14-2005, 07:46 AM   #11739
Default T1R short arms
thanks, i will go get the mod this weekend.
BlueT is offline   Reply With Quote
Old 04-14-2005, 08:48 AM   #11740
My web site is http://www.teamtamale.com . You can also email me directly at [email protected]. You can also pm me through this forum.
teamtamale is offline   Reply With Quote
Old 04-14-2005, 08:55 AM   #11741
new92's Avatar
Default Re: T1R short arms
I was going to do this on my T1R awhile back but I thought I read that the droop screws didnt sit on the chassis quite right on the T1R with the short arms? Any problems? If not then I will definitely be swapping over.
new92 is offline   Reply With Quote
Old 04-14-2005, 12:03 PM   #11742
NVisible's Avatar
Originally posted by Speedo
What happens with the aluminum hexes is that upon impact the driveshaft is pushed into the axel, bending the axel outwards. I think this causes the axel not to spin true.
I have ordered the spring steel axels, and am hoping they will fix the problem. If you can't buy the steel ones, and your aluminum ones are already bent, you are probably out of luck. You could possibly save some money by buying another pair of aluminum axels, and use a dremel to take some material out of the inside of the axel so that the driveshaft can't make contact.
I have this exact problem. So much so that the axle has mushroomed out over the bearing, making it impossible to remove the axle assembly from the steering knuckle. Is the only way to get this out to cut the knuckle in half? perhaps try to cut away the axle from the bearing? I can race this weekend with it, i just had to turn my radio end points down. Its just frustrating to get a car and find this wrong with it
Old 04-14-2005, 12:09 PM   #11743
theisgroup's Avatar
take a smal file and file the outside edge of the axel down. you should be able to file it down enough to slip it through the bearings.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 04-14-2005, 12:16 PM   #11744
NVisible's Avatar
damn thats using your noodle. thanks!
Old 04-14-2005, 12:23 PM   #11745
theisgroup's Avatar
nah, not that. I had it happen to me
yang lai
