Old 04-09-2005, 10:59 AM   #11716
work's Avatar
Here's a shot of the custom fan mount i made for the Much More esc fan. Made out of lexan and carbon stickers
work is offline   Reply With Quote
Old 04-09-2005, 11:00 AM   #11717
work's Avatar
Originally posted by NVisible
these parts?
53571 | FLUORINE COATED DAMPER SET (4)
53598 | AL. 5 mm Ball Connectors (10) for suspension arm
53599 | AL. 5 mm Ball Nut (10) for shock towers
50596 | Adjuster 5 mm 81/02 plastic for lower end of shock (rear)
50797 | Short Adjuster 5 mm plastic for lower end of shock (8pcs) (front)
50875 | 5 mm ball connector set TAO4
Yup
Old 04-11-2005, 04:52 PM   #11718
what is the best chassie for the tr1fk and where can i get one
zinger77 is offline   Reply With Quote
Old 04-11-2005, 05:09 PM   #11719
JDXray's Avatar
Send a message via AIM to JDXray
BMI 350 Chassis and the Xray upgrade chassis. (XRC)
JDXray is offline   Reply With Quote
Old 04-11-2005, 05:25 PM   #11720
where can i get a bmi 350 ?
Old 04-11-2005, 05:39 PM   #11721
JDXray's Avatar
From Jason at BMI www.bmiracing.com i believe the site is. His name on RCTech is Protc3.
Old 04-11-2005, 05:41 PM   #11722
thanks JD
Old 04-13-2005, 05:02 PM   #11723
NVisible's Avatar
a general setup question for you guys, im trying to use josh cyruls setup (sorta) on my FK but i cant seem to get the ride height low enough. I dont have any pre-load on my shocks and when running 5mm droop i cant get low enough. Is there something im missing here? I figured its shock location, but im using the same as on the sheet. Would it be the height of my foams?
NVisible is offline   Reply With Quote
Old 04-13-2005, 05:03 PM   #11724
JDXray's Avatar
Could be the height of your foams as you said. Why are you running such a high droop? Isnt Cyrul's droop low? around 1 or 2?
Could also be shock collars (lower part) try associated ones and they lower the ride height as well i believe.
Old 04-13-2005, 05:17 PM   #11725
NVisible's Avatar
hes got 5mm in the rear, 0 up front.
Im sure this wont be an issue once i hit the asphalt. I'll look into those AE shock supports, ive also heard the team tamale supports work well too.
Old 04-13-2005, 05:31 PM   #11726
I can vouch for the Tamale collars - the do work well with foams!
Cottontop is offline   Reply With Quote
Old 04-13-2005, 05:42 PM   #11727
Default T1R short arms conversion
hi,
I was just wondering if any of you guys actually tried to convert the long arms on the T1R to short ones.
I am using the stock composite chasis.
Does it make a lot of difference?
what are the parts i require?
thks in advance
hope someone can help me out
BlueT is offline   Reply With Quote
Old 04-13-2005, 06:54 PM   #11728
NVisible's Avatar
heres another really bonehead question. Im actually pretty embarassed to ask it.
How do you tighten the belts? I know the part i have to turn.. but how? do i wrench on it with a pair of pliers? do i have to slide it out, turn then back in?
Old 04-13-2005, 08:14 PM   #11729
JDXray's Avatar
Originally posted by BlueT
hi,
thks in advance
I would keep it the same, no reason to keep upgrading the T1R, its a great kit out of the box i have had 2 and i kinda liked the long arms on them.
But if you wanted to buy the short arms you can, but you need to then buy the hinge pin holder set i think.
Take the black insert where the bearing meets the diff/oneway/spool whatveer you have and turn it counter-clockwise if i am correct, ill have to double check. Its in your manual if you have it still.
Jon
Old 04-13-2005, 08:23 PM   #11730
NVisible's Avatar
yea i had read that in there, seems pretty damned tight though. should i be doing this with my hands or a tool?
