Xray T1
hrm, cool. Yea as in grinding down the shock mounts on your arms so you can use the outer holes. but i guess you dont have it done.
im gonna try this.... right now!
and heres a pic!
and heres a pic!
and heres a pic!
yea for sure. im interested to see what this will do for handling. I would dremel my mounts, but i dont have a drill bit small enough to make the remaining holes deep enough
hey. i thought i was the only one who did that.
sorry
btw jon, you reffered the shock's mounting as like the rdx's. as the pro2's would be a better example
From the setup book: Harder damping - less grip but lower
chassis roll. Stability is decreased,
but high-speed cornering, traction
permitting, is increased
Hi there, has anyone fitted tamiya's trf shocks on your xray? Are the shocks a direct fit or are there any mods needed? Thanks.
Here's my FK with TRF shocks. I forgot what parts i used to make it work. Those are Xray springs on the shocks.
these parts?
53571 | FLUORINE COATED DAMPER SET (4)
53598 | AL. 5 mm Ball Connectors (10) for suspension arm
53599 | AL. 5 mm Ball Nut (10) for shock towers
50596 | Adjuster 5 mm 81/02 plastic for lower end of shock (rear)
50797 | Short Adjuster 5 mm plastic for lower end of shock (8pcs) (front)
50875 | 5 mm ball connector set TAO4
