Old 03-26-2005, 09:22 AM   #11686
Superkidracer82's Avatar
Send a message via AIM to Superkidracer82
here is a t1 for pretty cheap. http://www.speedtechrc.com/store/ebp...id=120&id=1088
Superkidracer82 is offline   Reply With Quote
Old 03-26-2005, 04:26 PM   #11687
Send a message via AIM to greencactus3
uhhh thats a t1r and its outta stock.
greencactus3 is offline   Reply With Quote
Old 04-01-2005, 08:00 PM   #11688
Assasin's Avatar
finally got a very good condition used xray FK04 really cheeeeeap!
Anyone got a good set up for So Cal on 27T stock? Tnx
Assasin
Assasin is offline   Reply With Quote
Old 04-02-2005, 04:49 AM   #11689
Default CASTER BLOCKS
WHAT IS DIFF BETWEEN 0 AND 3 DEGREE CASTER BLOCKS WHAT WILL IT DO TO THE CAR?
zinger77 is offline   Reply With Quote
Old 04-02-2005, 11:11 AM   #11690
wazee's Avatar
Where i can get o good basic setup or a starting point for racing a FK`04 with foams on a aspahlt track?
What shore should i take and what diameter?
Never raced foams before.
wazee is offline   Reply With Quote
Old 04-02-2005, 11:39 AM   #11691
NVisible's Avatar
Default Re: CASTER BLOCKS
if you promise to turn your caplock of ill tell you....
ok ill tell you anyway
Less Caster:
Decreased straight-line stability.
Increased off-power steering at corner entry.
Increased suspension efficiency.
Decreased on-power steering at mid-corner and corner exit.
More Caster
Increases straight-line stability.
Decreased off-power steering at corner entry.
Increased on-power steering at mid-corner and corner exit.
Makes the car more stable through bumpy track conditions.
All of this is found in the HUDY Setup Book
NVisible is offline   Reply With Quote
Old 04-02-2005, 04:38 PM   #11692
JDXray's Avatar
Send a message via AIM to JDXray
Hey Guys,
Its been awhile since i have run my FK (04) and i need to refresh my memory. I saw the guys at my track running again and i just wanted to join in.
-How do i calculate rollout for a small track?
-Is running a one-way fine for indoor carpet? (i have before and it was okay)
-What shock oil in front and rear (just the regular Xray 30wt?) how many holes open front and rear? (1,3?)
Jon
JDXray is offline   Reply With Quote
Old 04-02-2005, 05:08 PM   #11693
NVisible's Avatar
-rollout... try www.gearchart.com (i guess)
-one-way... id rather use a diff, better for high grip
-oil... well you could just use 30 and close all holes up front and leave some open in the back.. thats just my personal pref though
Old 04-02-2005, 05:12 PM   #11694
JDXray's Avatar
But does anyone have the actual calculations, i like doing the rollout myself.
Old 04-02-2005, 05:33 PM   #11695
NVisible's Avatar
here ya go. check this out
http://www.rctech.net/forum/showthre...hlight=rollout
Old 04-02-2005, 07:06 PM   #11696
JDXray's Avatar
Thanks again Nvisible.
Old 04-06-2005, 01:11 PM   #11697
JDXray's Avatar
I posted this on the Xray 05 thread, but i would like the 04 guys opinions.
I moved the shocks on the other side of the shock tower.
Ill post pics.
Old 04-06-2005, 01:14 PM   #11698
JDXray's Avatar
rear pics of shocks
Old 04-06-2005, 01:55 PM   #11699
NVisible's Avatar
Interesting. Does that not create a big forward angle on the shock? Also, what do you expect to accomplish by doing this?
I have the exact same car as you and am curious
Also, im guessing you have your shock mounts on your arms ground down?
Old 04-06-2005, 01:57 PM   #11700
JDXray's Avatar
If you look at the 2nd pic, there really isnt that big of an angle. Almost vertical. I have never run the car like this yet, but a couple of guys at my LHS have and there the FAST A main drivers here.
Ground down?
