Old 03-21-2005, 07:06 AM   #11671
kidDynomite's Avatar
Green, this is what Speedo and I were talking about. It helps if you do this while the alum. axles are still new. But if yours are not in bad shape, you may still be able to do this.
Good luck!
kidDynomite is offline   Reply With Quote
Old 03-21-2005, 07:16 AM   #11672
Originally posted by steve eaves
Hey guys sorry for any repeat but i have been running associated for 5 years recently bought a fk04 any idea for asphalt and concrete setup any help would be appreciated.
Steve eaves
Steve, hope this helps!
Xray Asphalt Thead
Or sign up on www.mytsn.com for a bunch of set-ups.
Old 03-21-2005, 04:39 PM   #11673
Send a message via AIM to greencactus3
Good luck!
thanks guys! really helps! will look into the damage i already have to my axles.
greencactus3 is offline   Reply With Quote
Old 03-22-2005, 11:57 AM   #11674
Shumacher 99's Avatar
I hate those axles when they mushroom like that. And the bulkhead screws that refuse to come out. Other than that I love X-Rays...lol
Shumacher 99 is offline   Reply With Quote
Old 03-22-2005, 07:22 PM   #11675
Is there another source for T1FK zero degree castor blocks other that the aluminum ones from X-Ray?
Cottontop is offline   Reply With Quote
Old 03-22-2005, 08:51 PM   #11676
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
Xray is releasing 1.5 degree composite caster blocks, you might want to try those.
Other than that, the Xray aluminum ones are your only option for 0 degree. Many people have reported problems with the Xray aluminum blocks bending however, so you may want to take that into consideration.
Josh
Speedo is offline   Reply With Quote
Old 03-22-2005, 09:46 PM   #11677
if yuo ask real nice we at Team tamale Racing products mihgt be prsuded to build some of our virtually indestructabl C-Hubs in o degrees.
teamtamale is offline   Reply With Quote
Old 03-23-2005, 06:37 AM   #11678
theisgroup's Avatar
so larry are you going to do the 1.5 and 4.5 as well?
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 03-23-2005, 06:41 AM   #11679
Jon Williams's Avatar
teamtamale - you've got PM.
Jon Williams is offline   Reply With Quote
Old 03-23-2005, 06:55 PM   #11680
Trader Rating: 70 (100%+)
Xray Asphalt Thead
Great thanks for the help.
Steve eaves
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 03-25-2005, 03:39 PM   #11681
Qwiglee's Avatar
Does anyone know if there is a optional chassis for the T1FK04 that has the same layout as the 3.5mm chassis but is still only 2.5mm thick? I like the improved battery and servo placement on the newer chassis but don't want 3.5mm thick.
Brian Aldridge
Qwiglee is offline   Reply With Quote
Old 03-25-2005, 07:57 PM   #11682
todd8603's Avatar
I am trying to install the Low ratio pulley set. I have the hollow spring steel layshaft.
I have noticed that the pulleys are in a straight line down the chassis. Are there any diagrams for assembly to ensure I have done this correctly?
Currently, I have from spur across, plastic washer, pulley open end right over pin, pulley open end over pin, the threaded plastic bit from the origianl setup holding it all together. Help!!??
todd8603 is offline   Reply With Quote
Old 03-25-2005, 08:05 PM   #11683
I think you have to have the aluminum layshaft for the low ratio pullies to fit. I don't think you will be able to use the spring steel one.
dway100 is offline   Reply With Quote
Old 03-26-2005, 04:21 AM   #11684
todd8603's Avatar
Thank you. Will look further into this with Xray distributor.
Old 03-26-2005, 07:07 AM   #11685
theisgroup's Avatar
you do not need the nut. the way it is installed is as follows from spur in:
bulkhead, spacer, plastic washer, pin, pulley over pin, pin, pulley over pin, c-clip, bulkhead.
the clip will sit in a groove on the layshaft. I don't have the spring steel solid layshaft, so not sure.
yang lai
