Old 03-14-2005, 02:43 AM   #11641
Team-RTR's Avatar
does anyone hace a good foam tyre setup they can post for mod racing on a medium size track, with a medium amount of traction?
thanks
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 03-15-2005, 06:52 PM   #11642
pucho's Avatar
Send a message via AIM to pucho
Default Testing waters
Hello:
I haven't been racing for a while and I won't have the time to do it for a while longer. I have a full set of black anodized aluminum parts for a FK. I will sell them for the right price. This is a full set basicly I took a kit and had all the parts anodized. If anyone is interested plese email me at [email protected] do not reply here because I won't get it I will provide picture to all serious inquiries. Thanks for looking and have a great day.
pucho is offline   Reply With Quote
Old 03-16-2005, 02:47 PM   #11643
Trader Rating: 198 (100%+)
Where can I find parts for Xray on the net. For US sales?
dodgeguy is offline   Reply With Quote
Old 03-16-2005, 03:41 PM   #11644
NVisible's Avatar
www.speedtechrc.com
NVisible is offline   Reply With Quote
Old 03-16-2005, 05:16 PM   #11645
BlackKat's Avatar
thanks
For Carpet? Sure!
Front:
Spring: Red
Shocks: 1 Hole, 30wt XRay oil, Outermost hole on Shock tower
Toe: Straight
3 degree C-hubs
Either 0 or 2 deg kick-up (Mod you need 0 deg kick-up)
Droop 1 at the kingpin screw head
Camber: 2 deg
2mm spacer under camberlink (between rod-end and c-hub)
Rear:
Spring: Violet
Shocks 1 Hole, 30wt XRay oil, Either of the middle holes on the tower
Toe-in: 2 or 3
Droop: 4 at the outer hingepin
Body: Mazda 6 works nice. Caddy kinda hard to drive
Tires: Purple-Orange Fronts & Purple Rears
Jilles Groskamp suggested 3 holes open for the shocks and a front swaybar because I was having problems with lifting the inside wheels.
Enjoy!
-Dan
BlackKat is offline   Reply With Quote
Old 03-16-2005, 07:17 PM   #11646
rdub202's Avatar
Trader Rating: 19 (100%+)
Send a message via AIM to rdub202
www.ashfordhobby.com
robert is a good guy check them out
_|Team Academy GV2 Pro_|_Team Academy SBV2 Pro|_--->Losi xxxbK2 (FOR SALE)
_|Factory Tracks Midwest Series_|_www.factorytracks.com|_
_|Team Upgrade-RCid_|_www.upgrade-rc.com|_
_|MRC/Team Academy_|_www.modelrec.com|_
rdub202 is offline   Reply With Quote
Old 03-16-2005, 10:25 PM   #11647
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
So, no idea on the 4.5 deg C-hubs?
Speedo is offline   Reply With Quote
Old 03-16-2005, 11:26 PM   #11648
Originally posted by Speedo
Anyone know the release date on the 4.5 deg. castor blocks?
You could get the aluminum 4.5 blocks from teamtamale!!!
Joneser is offline   Reply With Quote
Old 03-17-2005, 04:33 AM   #11649
Team-RTR's Avatar
Originally posted by BlackKat
For Carpet? Sure!
Front:
Spring: Red
Toe: Straight
3 degree C-hubs
Camber: 2 deg
Rear:
Spring: Violet
Toe-in: 2 or 3
Enjoy!
-Dan
thanks, but i was actually after an ashphalt setup, sorry about the confusion!
Old 03-17-2005, 05:36 AM   #11650
Check this link for the recently announced new option parts: http://www.teamxray.com/teamxray/pro...kategoria=1297 . The announcement includes 1.5 and 4.5 degree composite caster blocks as well as new hard composite 1.5, 3, 4.5 and 6 degree caster blocks. Also announced are hard short lower suspension arms. For availability dates I suggest you contact your distributor.
Tony Vredenberg
tonyv is offline   Reply With Quote
Old 03-17-2005, 07:56 AM   #11651
kidDynomite's Avatar
TeamTamale chubs rock! They keep me racing. Bullet proof stuff. I'll be ordering the 4.5* so I can start experimenting with pro-dive.
kidDynomite is offline   Reply With Quote
Old 03-17-2005, 10:40 AM   #11652
kt racing's Avatar
Send a message via AIM to kt racing
I have a problem with my car that I haven't been able to figure out with the FK04 With the car running and the tires turned full left or full right the drive train will get a horrible shudder in it but it doesn't do it with the tires straight and it doesn't do it with the tires off. I have torn the car apart 2 times I put all new bearings in it and disconected the rear belt and the problem still exists. The only thing I haven't checked is the bearings inside the diff. But the diff feels awsome so I do see a problem there. It almost feels like the old style asc cvds when you would turn the tires the cvds couldn't turn anymore so they would rub on the axles. But on the FK there is aoubt 3mm of room with the tires fully turned. Also the belt isn't rubing anywhere.
thanks
keith
kt racing is offline   Reply With Quote
Old 03-17-2005, 10:49 AM   #11653
your tires are rubbing on the shocks
mtc3od is offline   Reply With Quote
Old 03-17-2005, 10:58 AM   #11654
kt racing's Avatar
that isn't it either I have already checked that.
Old 03-17-2005, 11:02 AM   #11655
do you have the black outdrive deals on your cvds? Also check and see if you have a bent cvd
