Xray T1
Originally posted by Formula1fan
I just got another xray. I haven't had one since I sold my last one 6 months ago. I wont be able to get the new one for a few months. Is there anywhere I could pick up the T1fk bulk heads?
What do I need to do to convert from pillow ball to c hub. I looked for a while on here from the beginning and just ran out a paticence. Thanks
Give me a call when you get home Chris I will show you what you need to order.
Edit: I actually may have a few pieces for you too.
http://www.teamxray.com/teamxray/pro...&kategoria=528
Dom
Upgraded Bumper
Does anyone have any recommendations for an upgraded bumper for a T1R? My son and I are new to racing and keep breaking the upper and lower stock bumper braces. Will the composite bumper work better than the impact bumper that comes stock with the car?
pdub bumper, rubberneck or i had an alex racing bumper on mine... no idea on what part # though
frist race with xray
this t1 fk is awesome i run my frist road race sunday at marshals qualified 7 and finshed 4 in the a main this car is the best onthe market any one thinking of getting one do it!
Re: Upgraded Bumper
Hey guys I finally upgraded my T1R to close to FK with short arms and what not. I notice that on the FK the lower pin holders have some sort of a alum nut, bolt or something like that. I assume this is to make it possible to change a arm without taking the bulk heads off. unfortunatly I dont have these and I wondered if they sold these sepeatly or if I should just pick up some longer screws and nuts?
Also I converted to a BMI chasis at the same time and now I want to know what is the best way to mount the front camber links to the shock tower.
I have instaled a sway bar in the front. I want to know if when not in use, should I remove all the parts ot the sway bar or can I just remove the bar and leave the rest attached.
I know that these q's have been answered because I have read them before but I dont want to read through the 150+ pages I have read in this topic.
Re: Re: Upgraded Bumper
Originally posted by greencactus3
what is the difference between composite and impact? does composite mean not foam? and i dont worry about cracking my upper bumper brace. is that bad?
The composite being a solid piece of plastic, the impact being slotted
Edit** Lookie here:
http://www.speedtechrc.com/store/ebp...?catmainid=193
Upgraded Bumper
The upper and lower braces are both composite. I do plan to get the P DUb foam bumper as well. Spoke with Xray today and they recommended I try the composite bumper part # 30 1200. I will everyone know how it works once I get some run time. Thanks for everyones input.
Originally posted by new92
I am interested here too since I am on my way to doing this same upgrade.
Re: Re: Re: Upgraded Bumper
Originally posted by NVisible
i believe the composite/impact bumper is the bottom piece, under the foam.
Edit** Lookie here:
Edit** Lookie here:
Re: Re: Re: Re: Upgraded Bumper
I replace it once it breaks to provide highest level of protection since my son and I are new to racing.
oh i see. i use the impact one since it was thje one that came with it. i have noticed it has a crack running down it. when do you replace it?
